Removing Thermostat?
Old Jun 15, 2008 | 09:03 AM
the.hamburglar's Avatar
Default Removing Thermostat?
My car is getting a little hot now that I have installed the turbo system. I cant fit a slim fan in front of the rad and I have the puller run off a fused switch. Any disadvantages of running the car without a T stat at all? I hear it will run cooler, but how much cooler even if my fan is running the whole time.
Old Jun 15, 2008 | 09:12 AM
standbackimapro's Avatar
Default Re: Removing Thermostat? (the.hamburglar)
If you take out the thermostat the coolant will be constantly flowing, which would make it hard for the car to warm up which could cause problems
the thermostat, limits the coolant until it reaches a certain temperature then it opens and lets more coolant flow so it wouldnt be a good idea,
Old Jun 15, 2008 | 09:38 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Removing Thermostat? (standbackimapro)
i dont know if anyone has had luck with restrictors instead of t stats.
disadvantages are, you will more than likely be in cold start comps or be running rich because the car isnt properly warmed up.
fix the issue.
Old Jun 15, 2008 | 09:51 AM
Default Re: Removing Thermostat? (boostedcivicsir)
ya that makes sense i guess. Ill have to make custom brackets for the rad then and put another slim fan in there
Old Jun 15, 2008 | 11:27 AM
HiProfile's Avatar
In most cases, you need the cylinders hot enough to create enough seal (piston-wall gap), as well as to help atomize fuel. Unless the motor was specifically built for low coolant temps, you have to fix the issue another way.
724chris
Oct 12, 2010 09:49 AM
suthernbred904
Jan 23, 2010 09:00 AM
hotcivicsi
11
Apr 9, 2009 06:19 PM
tien2
Mar 12, 2009 02:55 PM
Foxcow
Jul 29, 2004 06:27 AM
