Sunday's Dyno Pulls
91octane pulls-
314.9hp/252.1tq @ 8psi
346.9hp/285.5tq @ 11.5psi
116octane pulls-
418.9hp/329.2tq @ 16psi
Redline is set at 7500rpm
I am having a problem with misfiring above 17psi around 6k rpm area, I will have to do some work/research on this area and figure out a solution. Then its back to the rollers to making some real power numbers. Im looking to be in the area of 550-600whp.
Engine specs-
95 Accord Ex
H22a1 Block
ERL Superdeck 1 - Darton Sleeves
M2B4 LSD Trans
H23 Crower steel billet rods
JE H23 87.5mm 10:1:1 pistons
H23 Micropolished & Balanced Crank
Ferra Stainless Valves
Stock Cams w/ AEM Gears
Skunk2 Intake Manifold w/ 70mm B&M TB
1000cc PTE Injectors
Precision SC61-T4 AR .60/.68 V-band
Lovefab SST Ramhorn Manifold
AEM 3.5 Bar Map Sensor
Hondata s300
MSD Sport Compact Box, Coil, Cap
Kaizenspeed Balance Shaft Eliminator Kit
3" Exhaust, no Cat or resinator w/apexi N1 muffler -
Modified by hondaracer93 at 5:09 PM 6/24/2008
116octane pulls-
Engine specs-
95 Accord Ex
H22a1 Block
M2B4 LSD Trans
Hondata s300
I made a couple pulls with 2 different sets of plugs and different temperatures 7 & 8's with a gap of .25, and Resistor and non resistor plugs
dep22build
Jan 25, 2010 07:22 AM
dep22build
Mid-Atlantic (Sales)
13
Dec 18, 2009 12:47 PM
