whats not efficent enough?
Old Jun 16, 2008 | 12:50 PM
turbo-crx's Avatar
Default whats not efficent enough?
The car tends to heat up on the interstate if i get on it a few times. the temp starts to climb the faster i go. If i drive slower the temps dont rise as high(55-60) when i get off the freeeway and come to a light the temp drops all the way down to normal, but as soon as i leave the light the temp rises quickly and stays that way throught out slow driving speeds.....The only way i can get the temps to go to normal is turn the car off and let it cool back down to normal temp. Im thinking the radiator is not efficent enough to cool the fluid coming into the radiator before returning it to the motor. Any feedback appreciated.
Old Jun 16, 2008 | 06:48 PM
TheShodan's Avatar
Moderator
Default Re: whats not efficent enough? (turbo-crx)
could also be an air bubble in the water coolant system. Those can easily cause strange heating issues.
Modified by TheShodan at 7:45 AM 6/17/2008
Old Jun 17, 2008 | 07:07 AM
turbo-crx's Avatar
Default Re: whats not efficent enough? (TheShodan)
iv let the car idle for like 30 min with the cap off. what lse should i do to get air out?
Old Jun 17, 2008 | 07:29 AM
94delslo's Avatar
use the 12mm bleeder screw to get all the access air out. loosen it for a few seconds and tighten it back up. idle the car at 3k for a min or two then loosen it again for a few seconds and tighten it up. repeat this process until there is a steady flow of coolant flowing out of the bleeder screw. that's how you know there is no more air in your cooling system.
just letting the car idle with the cap off will not work. i have tried that for my self just to see and it didn't get all the air out like the bleeder screw will. it is located near the upper radiator hose. you cant miss it. good luck
Old Jun 17, 2008 | 08:36 AM
Running925's Avatar
Default Re: whats not efficent enough? (94delslo)
many motor's don't come with that bleeder there.
Old Jun 17, 2008 | 09:24 AM
turbo-crx's Avatar
Default Re: whats not efficent enough? (Running925)
yea i have the bleeder screw. No one has ever told me to do that before. ill try that as soon as i get home. thanks man.
Old Jun 17, 2008 | 08:59 PM
94delslo's Avatar
No problem Let me know how it goes.
Old Jun 18, 2008 | 07:17 AM
turbo-crx's Avatar
well i got home and poped the the hood.....and i see no bleeder screw WTF!!!! it must have backed out or something. so i plugd it with another bolt. So how do i bleed the system now?
Old Jun 18, 2008 | 05:38 PM
dephtone's Avatar
what mixture are you using coolant/water? I have read that you should run more water than coolant. specially in an ef chassis as everything is compacted in there the heat has nowhere to go really. i had this same issue with my turbo b20 in my hatch.
Old Jun 18, 2008 | 05:58 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx &raquo;</TD></TR><TR><TD CLASS="quote">well i got home and poped the the hood.....and i see no bleeder screw WTF!!!! it must have backed out or something. so i plugd it with another bolt. So how do i bleed the system now?</TD></TR></TABLE>
um
if the screw backed out, then you have no coolant in the system- i doubt it though.- its prolly factory casting where the bleeder normally goes-
just wait till the car is cold, open radiator cap, and run car for 3 heat cycles (fan turns on then off)
that = bleeding
Old Jun 19, 2008 | 09:13 AM
94delslo's Avatar
Default Re: whats not efficent enough? (nytosc)
Im sure you can get a new bleeder screw from honda or off another engine at a junkyard.
You could try and bleed all the air out with just the cap off and do heat cycles, but i know from my own personal experience that it doesn't work nearly as well as using the bleeder screw.
Karl schulze
Honda Civic (2001 - 2005)
Dec 30, 2017 08:20 PM
aeon
Jul 13, 2006 09:30 PM
Integra Integra
Jan 23, 2006 06:46 AM
WRTEG
Mar 18, 2004 05:51 AM
cool
Dec 31, 2003 07:26 PM
