Turbo crx problem
Old Jun 11, 2008 | 11:57 AM
BlakeJ53's Avatar
Default Turbo crx problem
NO my car is not tuned I don't want to here get it tuned I know. I have a check engine light that I want to get rid of first. The car is a 90 crx with a sohc non vtec motor converted to OBD1. It has an internally gated t3 and dsm 450's. So the car wont rev passed 5500 in all gears whille driving for like 5 minutes until it kicks a code then it pulls to redline no problem. I have tried to check the code but when I turn the car of and jumper the ecu and turn it back on again its not there. Any thoughts would be appreciated. Thanks Jordan
Old Jun 11, 2008 | 12:41 PM
turbo-crx's Avatar
Default Re: Turbo crx problem (BlakeJ53)
you have to jump the service connector. blue plug on the passenger kick panel.
Old Jun 11, 2008 | 12:59 PM
H.A.R.T B18C1EG6's Avatar
Default Re: Turbo crx problem (turbo-crx)
get it tuned
Old Jun 11, 2008 | 06:39 PM
HondaCivicSiR1's Avatar
Default Re: Turbo crx problem (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">get it tuned </TD></TR></TABLE>
that helped
did you wire the service connector up from the ecu jumper harness?
Old Jun 11, 2008 | 07:19 PM
dbiker207's Avatar
Default Re: Turbo crx problem (HondaCivicSiR1)
dont shut off the car before you jump the service connector. the code is probally a map code because if the stock ecu sees boost it will throw a code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">NO my car is not tuned I don't want to here get it tuned I know. </TD></TR></TABLE>
you dont know, have fun with the pile of scrap metal from boosting without a tune...idiot .
Old Jun 11, 2008 | 11:05 PM
BlakeJ53's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">don't shut off the car before you jump the service connector. the code is probably a map code because if the stock ecu sees boost it will throw a code.
you don't know, have fun with the pile of scrap metal from boosting without a tune...idiot .</TD></TR></TABLE>
A stock ecu does NOT throw a map code when it reads boost. The stock Honda map sensor can read 10 to 11 pounds with no code throwing. My ecu is not stock it is chipped and running on a base map.. Reading OWNS YOU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx &raquo;</TD></TR><TR><TD CLASS="quote">you have to jump the service connector. blue plug on the passenger kick panel.</TD></TR></TABLE>
I know that. But no I have not wired it in on the jumper yet.
Old Jun 12, 2008 | 05:54 AM
dbiker207's Avatar
stock ecu will throw a code, a chipped ecu on the other hand wont. you never said that your ecu was chipped. i know a stock map can read up to ~11 psi.
a basemap is only for starting the car to check for leaks and to get it on a trailer. if you continue to drive it you WILL blow it up.
Old Jun 12, 2008 | 06:43 AM
nsxmatt's Avatar
I know that. But no I have not wired it in on the jumper yet.</TD></TR></TABLE>
You want us to eat glass and **** a crystal ball so we can fix it for you? Fix the damn car and check the code. You know the answer and you look like a idiot for even asking.
ryan_crx
Oct 8, 2007 08:03 PM
stocker2shocker91
Jun 26, 2007 07:56 AM
slammedef8
Sep 6, 2005 11:41 AM
Chronicsinners
35
Jan 28, 2005 04:35 AM
Neukin
Jun 10, 2003 04:32 PM
