Searched, JRSC question.
Old Jun 22, 2008 | 11:03 AM
OMGWTFBBQ!'s Avatar
Default Searched, JRSC question.
Hey guys, searched the forums, checked the FAQ, but no luck. I'm looking to run a JRSC with all the fancy upgrades, the 440cc injectors, Hondata s300, different pulleys, etc. I have a stock 98+ B18C R from the merry land of japan, and I was wondering if you guys with GSR or Type R set ups like mine used the Hondata s300 from Jackson racing, and if the map that comes with it is any good, or if I should just plan on having the car tuned.
I'll most likely run the 6lb pulley for a while, eventually I plan on buying a water/meth kit (cheaper than LHTs intercooler, not to mention I get to carry around Boost Juice ) and going up to the 11lb pulley. I'm pretty sure once I start throwing the meth in I'll have to get tuned regardless, I was just wondering if I'd be fine on the stock map while I cruise around on 6lbs.
My car is strictly a Daily Driven Autocrosser, no interest in drag racing, but I may do some track days at sebring and moroso in the future. I looked into a Full Race Turbo kit with 330s an s300, tune, etc and it ended up being almost $3,000 more than the JRSC set up, so I'm going with the blower unless I win the lottery.
Old Jun 22, 2008 | 11:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Searched, JRSC question. (OMGWTFBBQ!)
the map will most likely work, and may work well, but every engine has different needs, a true dyno tune will never hurt.
Old Jun 22, 2008 | 11:28 AM
OMGWTFBBQ!'s Avatar
Thats what I figured, like I said once I go meth I fully intend on being dyno and street tuned. I was just wondering if Hondata fixed the lean throttle tip in problems that used to plauge the JRSCs, as long as the map from JR will handle 6lbs on a daily basis with no risk to the engine. I would hate to lose my engine because I was too lazy to save up and do it all at one time.
Old Jun 22, 2008 | 05:57 PM
OMGWTFBBQ!'s Avatar
anyone else?
Old Jun 23, 2008 | 07:58 PM
undagroundrican's Avatar
Default Re: (OMGWTFBBQ!)
you dont need to get a s300 its expensive close to $650 plus to get it tuned another $400 i'm running a jrsc and ima get mine tuned with a program called ectune search the name and read up a little. the map sensor will work fine but a true tune is a must and for future advice you might wanna change the pistons and ring when i put on my supercharger on my way to get it tuned it busted all of my ringlands and i wasnt even punching it im rebuilding now . get some low compression pistons and new rings
Old Jun 23, 2008 | 08:00 PM
Default Re: (undagroundrican)
oops sorry i thought u meant the map sensor, yes the stock map they would send you would be ok but get it tuned anyways plus you'll get the most hp from tuning
Old Jun 24, 2008 | 04:49 PM
OMGWTFBBQ!'s Avatar
I'm buying the High boost kit, it comes with 3 pulleys, the Hondata s300, and injectors, for only about $1000 more than the base kit. I know alot about ECTune, but I dont want to change my pistons. I like my 11.1 compression ratio
1_SC_GSR
Jun 14, 2006 05:06 PM
InfamousGSR
Feb 28, 2004 10:02 AM
Brian_TII
Jan 5, 2004 07:26 PM
ATgrills.com
Jul 27, 2003 09:25 AM
Spunkster
Jun 15, 2001 05:59 AM
