Tial Wastegate Spring Change
I used the red search feature and couldn't come up with any DIY. Is it pretty much self explanitory or do I need to have it done by a professional. I have a 38mm Tial Wastegate going from a .6 bar to a .9 bar (8.7psi) to (13.2psi). Thanks fellas
I tried that something about a codec aquired issue doesn't allow me to view the file so the search continues. Unless you have a pdf file that futher instructs individuals to swap out a spring?
Re: (TiAL)
Its very simple....easier with two people. Have one person hold the cover down equally with their hands while you take all the screws out. Switch springs....then have the same person hold the cover back in position while you put the screws back in.
Re: (dont_tri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dont_tri »</TD></TR><TR><TD CLASS="quote">I tried that something about a codec aquired issue doesn't allow me to view the file so the search continues. Unless you have a pdf file that futher instructs individuals to swap out a spring?</TD></TR></TABLE>
Hey it did that to me too, but it worked after I downloaded and saved it on the hard drive and THEN played it from the hard drive - wierd...
Re: (pcguy760)
Im gonna be going to a 1 bar spring soon, but I helped my buddy change his TiAL spring, and yes, it's pretty straight-forward as SpoolnG2 stated.
Slick GS-R
08-02-2004 07:52 PM
