Quick AN fitting question.
Old Jun 23, 2008 | 02:56 PM
Turbo-GSR1287's Avatar
Default Quick AN fitting question.
Hey im finishing up my turbo build on my GSR. I have a moroso Oil pan w/ the -10 AN fitting on the end of it. My question is when setting up my return line from my turbo will it be ok to go with a 90 Degree swivel fitting on this or will that angle be too restrictive on oil flow back to the pan. or would it be better to go w/ a 60, or 45 degree. LMK guys thanks
Old Jun 23, 2008 | 03:25 PM
a1320addict's Avatar
Default Re: Quick AN fitting question. (Turbo-GSR1287)
Do a 45º at the turbo return flange and pan as well
Old Jun 23, 2008 | 03:42 PM
Default Re: Quick AN fitting question. (a1320addict)
Cool thanks. so a 45 degree of the pan... is it not good to use a straight down off the pan?
Old Jun 23, 2008 | 05:49 PM
Bump for anymore input?
Old Jun 23, 2008 | 08:15 PM
Stealthmode Performance's Avatar
It's all going to depend on the placement of your turbo in relation to your oil pan. The key here is to have as much of a downward slope as possible. Look at your drain line, and imagine the most radical water slide that your craziest friend wouldn't go down. As long as you have a nice downward slope, it isn't going to matter if you put a straight fitting, a 45, or a 90. They'll all work the same, no matter what internet rumor suggests.
delslow45
Apr 3, 2011 07:14 PM
MurtazaDSM
Jul 18, 2009 11:42 PM
labtec
May 3, 2007 10:53 AM
toolowsol
Feb 9, 2006 01:52 PM
a1320addict
Jul 6, 2005 10:30 AM
