gsr turbo problem
Old Jun 17, 2008 | 07:20 PM
gsrtpower's Avatar
Default gsr turbo problem
i have a stock gsr turbo that is runnine rich and is idlin bad..i took it to work and it worked fine, but when i went back home it feel like ****. alot of miss fire, blog, very low idle, afr showing 10.0 afr, and sometimes it dies....i took off the spark plug and it was black. someone told me it be a bad relay but am not sure. i was thinking if it could be a bad o2 sensor cause when i drove i heard something POP in the exhasut...i think the o2 sensor couldve crack in side but i dunno. let me know if this happen to anyone......i dont know whats wrong..i dide valve adjustment, leak down test, replace new spark plug, and vaccum leak test...so am out of ideas...no check engine light whats so ever ......this is what i have for my set up.
stock gsr turbo running CROME
full race stg 2 turbo kit
3" full back dp and exhasut
rc 750cc pLA hold
victor x manifold
stunk 70mm throttle
thx
Old Jun 18, 2008 | 07:12 AM
PrecisionH23a's Avatar
Default Re: gsr turbo problem (gsrtpower)
Was the car properly dyno tuned or are you running some base map you found on the interweb?
Old Jun 19, 2008 | 05:56 PM
gsrtpower's Avatar
Default Re: gsr turbo problem (PrecisionH23a)
i had it dyno tune and it ran fine.....i personally think it could be the resistor box...cuz when i pitch the fuel line....it idle alot smooother and the engine sound alot better....what kind of trouble can u encounter with a bad resistor?..my buddy told me if the resistor fails, the injector are set wide open...which cuz it to over rich, idle bad, and foul the plugs...let me know what ya guyz think about my opinion...thx
07Lxcoupe
Feb 23, 2011 06:31 AM
patrick4588
Engine Management and Tuning
Aug 6, 2008 08:47 PM
Topdawgg
May 29, 2007 07:42 AM
rhdune16
Nov 26, 2005 09:33 AM
the.hamburglar
Jun 12, 2005 03:47 PM
