boosting a b16
Old Jun 11, 2008 | 04:20 PM
harker's Avatar
Default boosting a b16
hey im new to hondas, i just made a deal with a this kid for a civic hatch with a b16 for 3k he said he would throw in his turbo kit for an extra 200. the thing is i have herd that its alot of work to boost a b16 because of the high comp. is this true? and what would i have to do to lower the comp. and make this work? thanks for the help
Old Jun 11, 2008 | 04:38 PM
rmcdaniels's Avatar
Default Re: boosting a b16 (harker)
You don't have to lower the compression ratio. It's not any more work to boost a B16 that it is to boost any other B-series.
Old Jun 11, 2008 | 04:54 PM
VtecnTurbo's Avatar
Default Re: boosting a b16 (rmcdaniels)
you can run low boost on a stock b16 without a problem. weakest part of the stock motor as we all know is the piston rings.
depending on how much power you want will determine how much money you spend.
Always remember,
cheap-reliable-fast
you can only have two
Old Jun 11, 2008 | 04:58 PM
harker's Avatar
hmm well then that leeds to my next question.. what are the pros and cons of a b16 compared to a b18.. thanks
Old Jun 11, 2008 | 05:07 PM
rmcdaniels's Avatar
Cheaper, stronger rods, better for higher RPM's, makes less power/PSI.
Personally I like a B16 for a low boost (250 or so WHP) daily driver. I have one that I built sitting in my shop that I'm going to drop in my CRX one of these days.
Old Jun 11, 2008 | 08:17 PM
97_coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harker &raquo;</TD></TR><TR><TD CLASS="quote">what are the pros and cons of a b16 compared to a b18.. thanks
Also, check out the article below, it gives a realistic perspective when comparing a B16 and a B18, about halfway through the article he explains how, yes the B16 makes less torque but still makes comparable power to the B18 but you have more usable power that can be put to the ground due to less wheel spin. I might actually start another thread to see what other think about this article as well.
http://importbuilders.com/buildingbestturbo.htm
Old Jun 12, 2008 | 06:19 AM
harker's Avatar
Default Re: boosting a b16 (97_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe &raquo;</TD></TR><TR><TD CLASS="quote">
http://importbuilders.com/buildingbestturbo.htm</TD></TR></TABLE> thanks that article helped me understand alot
Old Jun 12, 2008 | 07:22 AM
Schister66's Avatar
Man U FTW
$200 for a turbo setup does not sound like something i'd be willing to run on my car. Hell, the cheapest part of my turbo setup (ie: bov, wastegate, injectors, etc) are all over $200. I'd be a little hesitant at that price.
Old Jun 12, 2008 | 09:09 AM
harker's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">$200 for a turbo setup does not sound like something i'd be willing to run on my car. Hell, the cheapest part of my turbo setup (ie: bov, wastegate, injectors, etc) are all over $200. I'd be a little hesitant at that price. </TD></TR></TABLE> well it was all part of the deal of buying the car but i dont know i guess ill find out when i have it in my hands.
Old Jun 12, 2008 | 12:33 PM
harker's Avatar
Default Re: (harker)
i think i got my info wrong . i think he said its just a up and down pipe and a either t3 or t4 turbo
DohcVtec77
Apr 23, 2016 03:20 PM
honda_mike
Oct 29, 2008 10:46 AM
nboost
Mar 21, 2006 06:39 PM
blazin
Aug 27, 2002 08:13 PM
shotty
Aug 6, 2002 01:47 PM
