BOV Not opening properly
Old Jun 23, 2008 | 02:48 PM
inovative91's Avatar
Default BOV NOT OPENING QUICK ENOUGH PLEASE HELP ME!!
ok so heres the set up,
d16y8 8.5:1 compression, turbonetics turbo, tial wastegate. running 14 psi.
after leting off the throttle excess boost is back feeding out the turbo, then the bov opens just for a split second. as i watch the boost gauge i notice vacuum drops a little slow. i have tried every vacuum source on the engine. looking for anyone who can help me out. im very frustrated, oh yah and its a greddy type-r bov brand new. ive always had this problem. turbo is brand new and i dont wanna mess it up, meaning i cant enjoy the power this lil single cam has. please help me out peeps!!
Old Jun 23, 2008 | 04:12 PM
Default Re: BOV NOT OPENING QUICK ENOUGH PLEASE HELP ME!! (inovative91)
bump
Old Jun 23, 2008 | 04:40 PM
turbodano's Avatar
Pretty much any vacum source will work. If the spring in the bov is to stiff it will do what you are talking about also. You may need to install a lighter spring.
Old Jun 23, 2008 | 04:55 PM
xsi-t's Avatar
Default Re: BOV NOT OPENING QUICK ENOUGH PLEASE HELP ME!! (turbodano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much any vacum source will work. If the spring in the bov is to stiff it will do what you are talking about also. You may need to install a lighter spring. </TD></TR></TABLE>+1
Old Jun 23, 2008 | 09:56 PM
transpro's Avatar
Sounds like you have a tear in your diaphragm. Vacuum drawing down slow might be a sign of a vac leak past the throttle body.
Check the diaphragm yo
Old Jun 24, 2008 | 05:59 AM
chimmike's Avatar
Default Re: BOV NOT OPENING QUICK ENOUGH PLEASE HELP ME!! (transpro)
uh, did you try adjusting the BOV?
FWIW, they haven't made the Type R brand new for a number of years now. Do you mean type RS or type S? I know the type S is adjustable...
Old Jun 24, 2008 | 06:33 AM
Riake's Avatar
You could also try a larger vacuum line.
Old Jun 24, 2008 | 03:54 PM
bov is adjusted completly soft, and i have a hard line vacuum going to it.
Old Jun 24, 2008 | 04:25 PM
redrum781's Avatar
Default Re: (inovative91)
I had the SAME problem. One of the Y adapters for the vacuum source actually had a restrictor in it. It made the BOV see the full pressure too late. Swapped the Y adapter for a regular one (larger inside diameter) and it fixed it.
Old Jun 24, 2008 | 07:16 PM
transpro's Avatar
Default Re: (redrum781)
+1 seen this too. Good call Red
Old Jun 25, 2008 | 06:33 AM
its a real type-r the big one. i know they sale a standard spring for it but i dont know how to tell if the spring in mine is standard or the stiffer one.
attack666
Jul 29, 2010 05:04 PM
inovative91
Jun 24, 2008 10:23 AM
inovative91
Jun 23, 2008 07:32 PM
a1320addict
Apr 29, 2005 06:01 PM
DownBoyDown
Feb 2, 2004 09:19 AM
