modifying LS head for turbo??
Old Feb 14, 2002 | 09:37 AM
cornbread's Avatar
Default modifying LS head for turbo??
Ok I bought a separate b18A1 bottom end from a 93 LS for $150 and rebuild it (sleeved, pistons and rods). I also bought a separate 94 LS head for $50 with all the parts from a good friend. I am planning on boosting 20psi max, should I upgrade the head or is stock ok? If so what should I get done? I already a search and was unsuccessful in finding this info. So if someone could please help me out.
Old Feb 14, 2002 | 09:53 AM
Doodoo's Avatar
Default Re: modifying LS head for turbo?? (smokeeeLSR)
Stock should be ok. But If I were doing mine again I would get springs and retainers.
Old Feb 14, 2002 | 10:40 AM
DIRep972's Avatar
Smarter than you
stock head will work fine, but i modified one wont hurt.. u know!
Old Feb 14, 2002 | 10:42 AM
b18bturbo's Avatar
Default Re: modifying LS head for turbo?? (DIRep972)
i woudl go with valve springs and retainers its easy to float a valve on a ls.. especially if you rev over 8200 rpm alot.
Old Feb 14, 2002 | 10:43 AM
bruthaboost's Avatar
Since you have the head off, you could get ss valves (just on the exhause if money is tight). They're not necessary, just more piece of mind.
Old Feb 14, 2002 | 10:48 AM
93LSivic's Avatar
Default Re: modifying LS head for turbo?? (b18bpwr)
I would do exhaust valves too. Lots of heat at 20 psi.
Definetly springs, retainers and holders--to take it past 7k r's.
Maybe a mild port job on the exhaust ports. It'll reduce exhaust speed but flow more air.
Old Feb 14, 2002 | 11:13 AM
Speed PHreak's Avatar
Some tuning, and head modification tips for LS engines
https://honda-tech.com/zerothread?id=126542
Old Feb 14, 2002 | 11:29 AM
rtype11's Avatar
consider doing a port match on the exhaust I notices that a lot of the cast type manifolds are bigger than your ex ports, and consider gasket match port on intake
Old Feb 14, 2002 | 12:30 PM
cornbread's Avatar
Default Re: modifying LS head for turbo?? (rtype11)
Thanks for the feed back guys. I will see how much $$ i have to spend on the headwork.
Old Feb 14, 2002 | 07:19 PM
SIK IN DA HED's Avatar
New User
Default Re: modifying LS head for turbo?? (Speed PHreak)
exactly what benefits would a built LS head do when youre running turbo? excpet for tachin higher... ive heard that there arent any power gains to be made.
matt97
Oct 13, 2009 07:14 PM
Rrm101
Northeast (Sales)
14
Jun 27, 2009 05:25 PM
92HB_HB
Apr 12, 2002 05:13 AM
thejdmkid
Feb 14, 2002 03:44 PM
