taking the plunge soon with pistons and rods...
Old Feb 13, 2002 | 03:22 PM
AlphaKennyWun's Avatar
Default taking the plunge soon with pistons and rods...
Please add or remove from list of parts as you see fit.
All new STOCK HONDA parts:
headgasket
timing belt
water pump
rod bearings
main bearings
oil pump (is there a seperate seal to buy for this?)
oil pan gasket (this one has been removed several times)
valve cover gasket (this one has been removed several times)
did I get it all? Am I missing anything?
[Modified by SO3Burner, 12:27 AM 2/14/2002]
Old Feb 13, 2002 | 03:30 PM
Darin D.'s Avatar
Default Re: taking the plunge soon with pistons and rods... (SO3Burner)
rear main seal, oil pump seal and oil pump o-ring is all i see missing.
Old Feb 13, 2002 | 04:15 PM
Default Re: taking the plunge soon with pistons and rods... (Willis)
Is the rear main seal the same one I replaced when i changed my tranny?
Old Feb 13, 2002 | 04:27 PM
1fstevo's Avatar
New User
water pump, head studs (ARP), spark plugs, New wires, cam seal, exhaust manifold gasket, intake manifold gasket ( hard to remove), TB gasket.
Old Feb 13, 2002 | 04:47 PM
Darin D.'s Avatar
rear main is the seal around the flywheel side of the crankshaft.
1990 CB7
Feb 27, 2017 11:40 AM
qqhorus
Jan 18, 2013 11:22 AM
laziebun
Nov 4, 2007 04:57 PM
schwett
Apr 24, 2002 08:37 PM
