Safe PSI level for STOCK LS engine
Old Feb 10, 2002 | 10:14 AM
TRE_'s Avatar
Default Safe PSI level for STOCK LS engine
I am just getting in to turbocharging and such, so if some of this is kinda off please understand.
Heres my situation: I have a 89 CRX HF with a b18b(ls engine) in it. I really want to slap a turbo on. I know that I need to upgrade some components in the fuel delivery system- i.e.: pump, injectors, etc. Also I will need to upgrade some ignition components- i.e.: spark plugs, wires, dist, coil, etc.
So I have a pretty good idea of what I need to do to make it safe(I think), but heres my question:
I dont have the time or money right now to be ripping the block/head apart and replacing rods, pistons, etc with stronger ones. So what will be a SAFE psi on STOCK LS INTERNALS?
8psi? I really have no idea.
Also, what kind of numbers do you think I will be pushing?
Thanks guys,
Trevor
Old Feb 10, 2002 | 05:08 PM
downpipe's Avatar
Default Re: Safe PSI level for STOCK LS engine (HybridJDMHonda)
search for some posts by "boosted hybrid". i think he's running 12 psi on a stock LS motor...but he is alos using water injection
Old Feb 10, 2002 | 05:42 PM
DIRep972's Avatar
Smarter than you
alright, maybe i can help u..
first, your stock ignition will do fine for street levels of boost, u will just need colder plugs..
the amount of boost u can run on the LS motor is generally decided by the fuel system.. on stock injectors and FMU u r pretty much limited to 7-8psi.. with the right fuel system there are people running up to around 12psi and making 300whp.. maybe u could even run more boost but then u r geatly reducing the engine life.. with the right fuel system, turbo set up and tuning u can make about 275whp @ 10psi.. Personally I feel that is plenty out of a bone stock LS motor..
naler62188
Sep 16, 2008 11:03 AM
hatchyboy89
Dec 16, 2004 06:22 PM
p1ccoloz
May 1, 2003 02:09 PM
B18-T
Aug 3, 2002 10:21 AM
X2BOARD
Dec 4, 2001 04:52 PM
