know about JIC Magic stand alone??
Old Feb 9, 2002 | 06:13 PM
c1hatch's Avatar
Default DTA ENGINE MANAGEMENT??
Has any one heard of JIC magic? Its a japan company, if you do a search on any search engine, youll find out about their susp. & exhaust systems. but they have a stand alone also. PLeas give me your opinions. I have a catalog & here are the features:
-Full ign control and amplification for upto 4 cyl. distributerless, 8 cyl w/distributor
-Full fuel control of upto 16 injectors(staged & switchable on rpm in 2 banks)
-Compensation for air temp/water temp/map or barometric pressure on fuel & ign.
-closed loop lambda control
-full turbo pressure control variable by rpm w/ overboost protection
-full single gear traction control(launch control)
-steering wheel button controled start line rpm limit
-full power shift cut
-temperature dependant idle speed control via PWM valve (shared 2nd bank of injectors)
-auxilary output switchable on rpm/water temp/manifold pressure(shared turbo control)
-dedicated shift light control
-dedicated tacho output
-2 stage main rpm output
-dedicated fuel pump control
-data logging for 3/5 mins
-full start-uo feul mapping
-throttle transient enrichment map
-self test facilities for ignition and injection
-diagnostics & peak recording
-real time mapping. no EPROMS required
-software programable for most crank wheels(honda blackbird. rover. 36-1. 60-2 etc.)
-all main 30 mapps(20x14) have user programable break points
-max rpm 14,000
I copied this straight out of there catalog. I'll try & scan it if youd like to see it. Please give me your opinoins on this. I was qouted $1140. from the looks of it its got a windows & msdos based software.
Here are the websites,
http://www.dtafast.co.uk/e48exp.htm
[Modified by c1hatch, 2:45 PM 2/10/2002]
twkdCD595
Apr 15, 2004 12:07 PM
