Boost problem
Old Feb 9, 2002 | 02:08 AM
pbwill's Avatar
New User
Default Boost problem
I've got a 2000 GSR with a Hondata, T3/t04e, Tubular mani, tial gate, and Blitz sbc-id controller.
For some reason I can't co over 4.5 psi when I'm lucky. Usualy it's 2.5 - 4. I made sure my boost controler settings were right, 2 shops checked it's install as well. I thought it might be me BOV opening under boost as it seemed to on the dyno so I tightened it almost all the way and no change, although it dodn't make the valve any quieter. I turned my boost controller to internal WG mode and it went up to 5.5psi once but slowly, any ideas? The car Is tuned for 8.5psi and I want to run it!
Old Feb 9, 2002 | 06:40 AM
greengangsta's Avatar
Default Re: Boost problem (pbwill)
check your piping again. sounds like your leaking boost. it happend to my friend. couldn't get past 4psi. and had the boost turned up to 10 psi. found the leak, replace the pipe. running great!
061000rr
Jun 14, 2011 04:37 AM
Hondacivic1995
Apr 17, 2011 04:40 PM
justinCO
May 20, 2009 06:11 PM
rudebwoy
Mar 17, 2007 12:53 PM
