Oil pump replacement?
Old Feb 13, 2002 | 03:33 PM
boost killz's Avatar
New User
Default Oil pump replacement?
Is it really that necessary to replace on a car with rebuild? Would the car need to have run a certain mileage for the need of a replacement? Thanks guys,
Nick
Old Feb 13, 2002 | 03:44 PM
gtcali's Avatar
Default Re: Oil pump replacement? (boost killz)
Good question, cause I wanted to know the same thing, but If you're building for boost (you are in the FI forum), might as well just change it to be safe.
Although I've never heard of an faulty Honda oil pump (anybody?). I'm going to.
Old Feb 13, 2002 | 04:18 PM
immortal's Avatar
Banned
Default Re: Oil pump replacement? (gtcali)
change the gear
Old Feb 13, 2002 | 06:44 PM
New User
Default Re: Oil pump replacement? (immortal)
Anyone else capable of answering the question? 2 replies? damn..
[Modified by boost killz, 10:48 PM 2/13/2002]
Old Feb 13, 2002 | 06:46 PM
immortal's Avatar
Banned
get the pro drive oil gear. i think the oil pump itself is fine.
$188.10 shipped with the 10% honda-tech discoutn
refer to this thread for why you should replace your gear :
https://honda-tech.com/zerothread?id=67540
This is a set of replacement wheels. I have never heard of a housing going bad, unless of course the broken pump wheels do any damage. The difference between a ProDrive Pump and O.E. is this. An O.E. pump is made up from cintered metal. Cintered metal for those of you who don't know, is an extremely fine powdered metal that is put into a mold the shape of the pump gear. It is then pressed under extreme pressure, removed from the mold and put into an oven with a bonding agent like bronze or something that will melt, go into the pores of the material and act as a glue to hold it all together. ProDrive Oil Pumps are made from Billet Stress Proof material, and then are ground to size. Each pump is made as a set to O.E. specifications per size and tolerance. Many of todays fastest Hondas use them such as Steph Papadakis and Lisa Kubo. Let me know if there are any other questions.
john@prodriveusa.com to order
OaksRacing
Oct 8, 2005 09:52 AM
Trak_Day
Jan 21, 2004 09:04 AM
1stGENGSR
40
Jan 15, 2004 07:50 PM
Boostless97Lude
Sep 23, 2002 02:44 PM
PROFILES2000
Feb 25, 2002 01:17 PM
