efficiency rate on a turbo, anyone?
Old Feb 12, 2002 | 04:32 PM
Markaccord95's Avatar
Default efficiency rate on a turbo, anyone?
wondering which of these turbos, t3/t04e 57 trim 63ar or a t3/t04e 54 trim 63 a/r, would run at the best efficiency rate on my h22a, anyone?
Old Feb 12, 2002 | 05:01 PM
DLB1994's Avatar
Default Re: efficiency rate on a turbo, anyone? (Markaccord95)
i think the t3/t04e 54 trim would be best
Old Feb 12, 2002 | 05:03 PM
dustin's Avatar
This depends on boost level... but the 57 is gonna be a dog to spool ...
Old Feb 12, 2002 | 05:09 PM
Default Re: efficiency rate on a turbo, anyone? (dustin)
well, 8 psi max for now, about 3-4 months, 15-20 with the built motor
Old Feb 12, 2002 | 05:19 PM
TurboSedan's Avatar
New User
Go with a T-88, big up top power! (sarcasm)
Old Feb 12, 2002 | 05:25 PM
Nick M's Avatar
15-20 psi? Good lord.
I hope thats quite a build up your planning, thats alot of power with an H22 if you build it right.
Old Feb 12, 2002 | 06:17 PM
Default Re: efficiency rate on a turbo, anyone? (HondaSport)
jesus nick, whos dyno is that??
Old Feb 12, 2002 | 11:14 PM
BlueShadow's Avatar
Say HondaSport,
If that is an H22 do you know what all the guy has done to his valvetrain?
Old Feb 12, 2002 | 11:25 PM
BlueShadow's Avatar
And to Answer the original question...
Markaccord95,
whenever I'm figuring this stuff out with a pencil and paper, I go to this website that I use to check how accurate my figure are. This is a cut and paste from one of my threads on http://www.preludeonline.com
I quote BlueShadow,
I pencil-whipped the numbers and I also used this calculator on http://www.turbofast.com.au/turbomap.html to double check my work.
at the bottom I used these numbers for an H22:
BORE = 3.48
STROKE = 3.62
NUMBER CYLINDERS = 4
AIR TEMP = 95
intercooler eff = 95
for the calculator I used these numbers from top to bottom.
RPM = 7400, 5550, 5000, 4000, 3700
BOOST = 8 PSI all
VE = 95 (%) for 7400,5550, RPM, 80 (%) for 4000, 3700 RPM
COMPRESSOR EFFICIENCY = 75 (%)
I used these numbers first to see if the blips would fall within the highest % comp efficiency and out of the surge limit and they ALL did.
EDIT I changed some numbers.
[Modified by BlueShadow, 5:39 AM 2/14/2002]
Old Feb 13, 2002 | 05:52 PM
Giuseppe's Avatar
Default Re: efficiency rate on a turbo, anyone? (BlueShadow)
ok, i plugged in your data, and i know that the 60 trim
is out of question, two points hit surge limit
but wrt the other trims, how would u select
one vs the other..??
Old Feb 13, 2002 | 08:50 PM
Default Re: efficiency rate on a turbo, anyone? (Giuseppe)
well, i never got into understanding boost maps yet, according to their calculations, which shows more efficiency, the 54 or 57 trim?
Old Feb 13, 2002 | 09:13 PM
Giuseppe's Avatar
im no expert but i say 54
punkracer
May 2, 2011 07:38 AM
Mugencrxsir1
Feb 26, 2006 04:17 PM
Beau Gotti
Sep 27, 2005 06:54 PM
integracivic94
Oct 17, 2004 09:19 AM
graphic
Nov 4, 2003 06:00 PM
