Turbo timers: APEX'i vs. BLITZ (pics)
Old 02-11-2002, 08:19 PM
Sh4rky's Avatar
Default Turbo timers: APEX'i vs. BLITZ (pics)
Okay, so I'm deciding between two turbo timers. I like them both but I don't know which one to choose. I know it's probably no biggie, but I'm frustrated and I need your opinion!
APEX'i Auto Timer is one choice:
The A'pex auto timer features a compact interface design (4 x 3/4 x 5/8 inches) with a separate control unit that can be hidden away underneath the dash. The Auto Timer is also the first timer with an integrated air-fuel ratio monitor. The unit reads O2 sensor signal from the ECU and extrapolates and air-fuel ratio value. The Auto Timer can detect the engine load before shutdown and adjusts the idle time accordingly. Finally, the Auto Timer has a safety/security feature that immediately shuts down the engine when the parking brake is released.
BLITZ FATT DC is the other:
Features: * Compact screen design * Air Temperature Display * Voltage Display * Manual Timer * Auto Timer * Adjustable bar display * Can be virtually mounted anywhere * Stop watch and lap timer * Contrast Adjustment
They're both small and nice, but which one is the better one of two ?
Does anyone know any benefits of one over the other? I think the BLITZ's green background will look better with my blue gauges and white dash backlites, on my Integra. What do you think?
[Modified by Sh4rky, 11:24 PM 2/11/2002]
Old 02-11-2002, 09:09 PM
Type-ARR's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (Sh4rky)
I run blitz, very small and fits nicely on my steering column
Old 02-11-2002, 09:29 PM
Sh4rky's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (TurboR481)
TurboR481, you have the FATT DC or you have the one with built in boost gauge?
dragnGSR's Avatar
Old 02-11-2002, 09:30 PM
Sh4rky's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (dragnGSR)
Nice! Thanks for the pic
Old 02-11-2002, 10:13 PM
dragnGSR's Avatar
No problem, anytime!
Old 02-12-2002, 03:20 AM
New User
TurboSedan's Avatar
I have the Blitz FATT, I like it because it was small enough to install where I want to install it and it was pretty cheap. ($80)
Old 02-12-2002, 05:45 AM
Apex i ITR's Avatar
Location: Toronto, Canada currently residing in ATL, GA, USA
The Apex'i auto timer is about the same price. Haven't used it yet. Still piecing together my kit.
Old 02-12-2002, 06:15 AM
riot's Avatar
It may be just me, but I like the Apex'i Timer
Anyone have experience with either of these and an alarm? Everyone says, "just get a relay to fix that problem" ...details? How DO you get around the alarm problem.
-ryan
Old 02-12-2002, 10:33 AM
New User
Xerxes's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (riot)
I've got the Blitz FATT but it's the older larger one, not the DC model...
Basically most alarms have an ignition wire input that they read to tell whether or not your car is on. You want to make sure that the wire that your alarm gets is NOT left on by the turbo timer.
Most turbo timers keep IGN1 and ACC on, therefore you will want to hook your alarm up to IGN2.
-Xerxes
Old 02-12-2002, 03:44 PM
cyan1de's Avatar
personally i like the old design of the apexi better... but that's just me.
Old 02-12-2002, 05:46 PM
riot's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (Xerxes)
-Xerxes
Thanks I'll keep that in mind.
Old 02-12-2002, 05:56 PM
New User
SilverLudeSi's Avatar
You can hook up any tt with an alarm. The relay is shown is this thread: https://honda-tech.com/zerothread?id=92570. It is a pretty bad drawing but I just did this last weekend with a greddy tt and it works perfectly. Let me know if you need any clarification.
Old 02-12-2002, 06:37 PM
csufweed's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (SilverLudeSi)
they both work the same... it comes down to which you think looks better or is cheaper. I like the looks of the APEXi.
Old 02-12-2002, 06:56 PM
turbopanda's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (csufweed)
the A'PEXi turbotimer is much smaller than the blitz. I'd prefer that over the Blitz as I have enough meters and stuff as it is. The A'PEXi can be mounted practically anywhere without being a nuisance.
Old 03-13-2004, 06:20 PM
XxAlan274xX's Avatar
does anyone know how to wire up the apexi turbo timer? cant find directions anywhere...
Old 03-13-2004, 06:22 PM
Moderator in Chief
Muckman's Avatar
Can the Apex unit display my AEM wideband output?
Old 03-13-2004, 07:15 PM
onelowchef's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (Muckman)
i would personally get the apexi turbo timer because it also gives a pretty accurate o2 reading, which is better than those autometer gauges.
Old 03-13-2004, 07:59 PM
Dee
Dee's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (onelowchef)
The Apexi doesn't give a more accurate reading because it uses the OEM O2 sensor! Yes, I own the Apexi timer!
Old 03-13-2004, 11:59 PM
Alchemist's Avatar
Get which ever is cheaper. They both basically do the same thing. I doubt that youre ever really gonna use the other randomfunctions of the timer. Bump....I d also like to know how to wire the 5 point relay.
Old 03-14-2004, 12:18 AM
Dee
Dee's Avatar
Default Re: (Alchemist)
https://honda-tech.com/zerothread?id=48042
https://honda-tech.com/zerothread?id=571828
Old 03-14-2004, 07:26 AM
Default Re: Turbo timers: APEX'i vs. BLITZ (Dee)
how do u wire it into a honda?
Old 03-14-2004, 08:47 AM
rocket256's Avatar
Default Re: Turbo timers: APEX'i vs. BLITZ (XxAlan274xX)
I say Apexi. I have one.
Old 03-14-2004, 08:59 AM
Vu
Vu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Can the Apex unit display my AEM wideband output? </TD></TR></TABLE>
This person used an Innovative wideband with the Apexi to display wideband readings.
http://www.innovatemotorsports...apexi
Old 03-14-2004, 09:33 AM
hybridzOr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxAlan274xX &raquo;</TD></TR><TR><TD CLASS="quote">how do u wire it into a honda?</TD></TR></TABLE>
http://www.apexi.com
they have instructions on there sight...
o yea..
BACK FROM THE DEAD
Quick Reply: Turbo timers: APEX'i vs. BLITZ (pics)
