sohc running 12's
Old Feb 12, 2002 | 09:13 PM
blowncivic's Avatar
Default sohc running 12's
im trying to get my 97 sohc vtec motor to run 12's with a t3/t4 turbo. im going to have the head
ported and polished but what is the best valve job to get? the place that is doing it says 3 on intake
and 3 on exh. but another guy tells me just do the exh 3 degress. i need opinoins or someone who already
knows who has done something like this before.
i plan runnin 10psi daily and 18 on the track im gettin 9/0 comp. pistons but also what sleeves should i get any help
would help out alot.
Old Feb 12, 2002 | 09:36 PM
Kamin's Avatar
Default Re: sohc running 12's (blowncivic)
First, i wish you ALOT of luck
12's on a sohc is very very hard to do
golden eagle sleves are the best.
Old Feb 12, 2002 | 09:49 PM
93LSivic's Avatar
Default Re: sohc running 12's (KAMiN)
Heh, I was thinking the same thing.
I wouldnt worry so much about the different valve jobs. I would worry more about how much each bolt and nut weighs in your car.
Oh yeah, GE's are great sleeves for the money.
Old Feb 12, 2002 | 10:55 PM
B16A's Avatar
New User
12.8 - 12.9 on a Turbo Charged SOHC EX has been done with a fully built block at 14 psi.
Old Feb 13, 2002 | 06:07 AM
VTC_CiViC's Avatar
Default Re: sohc running 12's (B16A)
I'm tickling high 13's on only 10psi on a tiny GReddy turbo in my 100% full interior 6G coupe. Built, tuned, on a larger turbo (looking at either t3/t4 or t3/t04e) 12's shouldn't be incredibly difficult. Most people just give up on their SOHC's before they get there, i'll take it all the way
Old Feb 13, 2002 | 06:42 AM
TurboSedan's Avatar
New User
Default Re: sohc running 12's (VTC_CiViC)
Yes, do not try half *** to do a big task. Take it all the way!!!!!
I do not want or need 12's, I will be happy with 13's on mine. It is a daily driver anyway. I just want to smack down some ego-ridden F-bodies around here. hehe!
Old Feb 13, 2002 | 08:49 AM
JFK78's Avatar
Default Re: sohc running 12's (97CivicFerio)
With a t3/t4 at 18 psi on a built block, low 12's should be easy as pie.
My bro's '94 CX with a stock D16Z6 did 13.5 on stock tires at only 8 psi with the greddy kit. With 10 psi and slicks high 12's should be no problem.
Is this motor going in a coupe or hatch?
Old Feb 13, 2002 | 08:59 AM
SlowTeg's Avatar
Don't listen to alot of the people here, they don't know what they're talking about. 12's should be EASY w/ a built d16y8, and a t3/t4. Just make sure it's tuned decently and you have slicks. Just because the dohc motors make more power, no one gives any credit to the sohc motors.
-Mike
Old Feb 13, 2002 | 09:06 AM
uglyasscivic's Avatar
I ran a 13.07 with a SOHC up in the high elevation of S.L.C. Utah. I was running a built up bottom end with crower rods and srp pistons,stock head and stock cam at 12psi.
I would not worry about getting headwork or anything head related.You should spend that money on a standalone and injectors.
Old Feb 13, 2002 | 11:31 AM
Hybrid's Avatar
Default Re: sohc running 12's (Ugly assed civic)
Yup have faith guy's. Some people don't have the DOHC option to turn too.
Whats impressive is a 12 second SOHC
I have a mild ported and polished D16Y8 head on my D16Z16. picked up a turbo recently along with some other hp maken goodies.
Next winter its the fuel and ignition upgrade, then the winter after that its complete motor rebuild. Hopefully parts will be cheaper.
then look out 12's, who know's, I could be knocking on 11's. Rregardless of that it will be a mean sleeper in a city impregnated by cubic inch dinasours don't ya think.
Old Feb 13, 2002 | 02:35 PM
D-Man's Avatar
Default Re: sohc running 12's (Hybrid)
What's even more impressive is an low 10 second SOHC civic such as Jason Whitfield's D running 10.2@142 or James West's D running 10.4@140
Old Feb 13, 2002 | 02:46 PM
jinxproof99's Avatar
New User
mat3t4 (honda tech) used to run 12's in his coupe with a sohc. im him.
CALM_AS_A_BOMB
64
Mar 13, 2006 06:35 AM
hair_rice
71
Mar 7, 2004 12:06 PM
speedehatch
Feb 12, 2004 02:49 PM
speshuled619
Aug 4, 2003 04:52 PM
TurBoXBirD16
Jan 20, 2003 04:02 AM
