DSM Injectors
Old Feb 13, 2002 | 07:57 AM
TurbodCX's Avatar
Default DSM Injectors
does anyone know if these injectors will work ina 92-95 honda civic??
are the plugs the same??
i am pretty sure that i have to do alittle modifaction to make them fit but im not real sure.
any help is appreciated
thanks
Old Feb 13, 2002 | 07:58 AM
VTC_CiViC's Avatar
Default Re: DSM Injectors (TurbodCX)
Need a resistor pack from an older Honda to convert to P/H.
Old Feb 13, 2002 | 08:00 AM
TurbodCX's Avatar
Default Re: DSM Injectors (VTC_CiViC)
ok so where doe sthis resistor pack go?? on each injector?? or inthe harness??
Old Feb 13, 2002 | 08:04 AM
VTC_CiViC's Avatar
The power wire from the injector harness (all 4) go into the box, them come out the other side and into the injectors.
Old Feb 13, 2002 | 08:12 AM
Hybrid's Avatar
yup they work but they are peak/hold injectors. Get yourself a resistor pack off a 4thgen civic and your set. Although running larger than 310cc injectors (I think, correct me if I'm wrong) on the stock ecu is not going to happen.
I'm picking up 450cc DSM's off a 1G talon for free. Next winter I'll buy a hondata, pop them in and I'm good to go.
Old Feb 13, 2002 | 12:49 PM
RGAZ's Avatar
New User
Default Re: DSM Injectors (Hybrid)
You can also get the resistor pack from any 2nd Gen (88-91) CRX Si or HF.
You can run the 450's on stock ECU, but you will need to turn down the fuel pressure and you will run rich as the dickens. A SAFC can solve that problem.
Randy
Old Feb 14, 2002 | 09:32 AM
RAWB's Avatar
So are ALL DSM injectors Peak/Hold? I know alot of folks run the 1st gen injectors, how about the 2G ones, from a 99GSX? I have a PRE 92 so Peak/Holds are what I need. TIA.
Old Feb 14, 2002 | 10:26 AM
Rob03Pro5's Avatar
Default Re: DSM Injectors (integracon)
I believe the 2G and 1G 450cc injectors are the same.. someone please verify this.
ceemarun
Aug 7, 2015 05:21 PM
LUiS010606
May 3, 2010 09:58 PM
1SicLS
Engine Management and Tuning
Dec 15, 2008 04:16 PM
mortificationrock
Jun 10, 2007 09:05 PM
abstractdevelopment
Apr 21, 2006 12:47 PM
