Question for Eagle Rods
Old Feb 13, 2002 | 04:27 PM
SpeedMonkeyRacing's Avatar
Default Question for Eagle Rods
What's the bearing code equivalent # the eagle rods are?!? i was told it's #3..is that true?
Jeff-
Old Feb 13, 2002 | 04:35 PM
JimmieD's Avatar
Default Re: Question for Eagle Rods (Corporal-Jeff)
you still havent installed those things???
Old Feb 13, 2002 | 04:40 PM
MackSpeed-616's Avatar
Default Re: Question for Eagle Rods (lsinteg)
maybe they are installed... and he just wants to verify before he turns the key
Old Feb 13, 2002 | 04:44 PM
Default Re: Question for Eagle Rods (TurboR616)
it's been rebuilding for the LONGEST! Decide to go all out w/ fully built motor ($$$). so what's the bearing # guys?!?
Jeff-
Old Feb 13, 2002 | 04:45 PM
Darin D.'s Avatar
#3 for everything but the b16 and h22 rods.
Old Feb 14, 2002 | 08:30 AM
TurboR1391's Avatar
Default Re: Question for Eagle Rods (Willis)
The guys at the Acura dealership do not know what a #3 bearing is. They tell me that they are all color coded not numbered. Are you guys referring to the #3 cylinder? Someone please enlighten me here on this infamous #3 bearing for eagle rods.
Old Feb 14, 2002 | 08:54 AM
civictom's Avatar
Default Re: Question for Eagle Rods (Vonte')
the rods have a number and the crank has a letter....then there is a chart for which color bearings you need using the number/letter.....and the Eagle rods are all number three so then you'll look at your crank and if it has like a B stamped on it then you look at the chart for 3B and it says you need Green bearings.....thats where you tell the dealer what color you need
Old Feb 14, 2002 | 09:33 AM
ArizonaTurbo's Avatar
You will need to know what color bearing it is according to size. Each color code has a distinct thickness. You will need to check clearances with plastiguage in order to tell which bearings you need.
the.hamburglar
Mar 3, 2007 11:08 PM
nicklk
Feb 9, 2004 06:41 PM
Killer_B
Jun 25, 2003 11:06 AM
BLKCRX
Jul 17, 2002 08:55 AM
