Timing for 2000 Si
Old Feb 9, 2002 | 06:24 PM
Herminator's Avatar
Default Timing for 2000 Si
Hello
I got a Greddy kit running on 8 psi with 2 degrees advanced. I got the MSD 6BTM and set it to retard 1 degree. My question is I'm hearing some detonation when it gets really cold outside in the morning and nothing out of the normal when it heats up in the afternoon so..................................
Is the 2 degrees advanced timing causing this detonation?
Should I raise the 6BTM to 2 degree retard to fight the detonation?
What is the stock timing for 2000 Si Cebics?
Should I retard the timing and still use the 6BTM?
Thanx in advance!
Old Feb 9, 2002 | 06:34 PM
b18cTurbo's Avatar
Default Re: Timing for 2000 Si (Herminator)
retard timing till you dont ear any more detonation !!! maybee your fuel can be the cause too
Old Feb 10, 2002 | 09:36 AM
2000_Civic_Si's Avatar
Default Re: Timing for 2000 Si (mikvtec)
Put the base timing to stock (16 degrees) and leave the BTM Set at "1" If you still hear detonation put the base time to 14 degrees and see if you still detonate, continue this method until you hear no more detonation. You could probly set it to 14 or 15 degrees and be safe with the BTM set at "1" This is the mothod I use for my freinds cars. Seems to work well. I use a digital timing light so I know that the timing is dead on. Just my prefrence.
jwlson
Jul 19, 2004 08:35 PM
infinate bound
Mar 18, 2004 10:35 AM
boostedcivicLS
May 12, 2003 09:39 PM
wrXtian
Mar 25, 2003 03:55 PM
John
Oct 25, 2001 10:49 PM
