wideband o2 sensor help
Old Feb 10, 2002 | 05:44 PM
89turboteg's Avatar
Banned
Default wideband o2 sensor help
does anyone know who makes a wideband o2 sensor and where to get one. im looking for one to use for tuning at the plave ill be working out of in March so im looking for a good on and price isnt that important as far as quality goes. dean
Old Feb 10, 2002 | 05:46 PM
b18bturbo's Avatar
Default Re: wideband o2 sensor help (89turboteg)
get the motec one that hondata sells works well.
Old Feb 10, 2002 | 05:47 PM
d mafia's Avatar
New User
There is the blitz A/F Analyzer and the Motec PLM. both are about $1000.00+.
Old Feb 10, 2002 | 05:56 PM
89turboteg's Avatar
Banned
Default Re: wideband o2 sensor help (2FAST4U)
i used one when i dynoed my car just dont remember which one it was. doesnt Haltech make one too?
Old Feb 10, 2002 | 06:03 PM
GruvyTune's Avatar
New User
you can do it yourself and only spend 180 bucks for the same thing:
http://www.techedge.com.au/
i cant speak for it since I just ordered a kit myself.
Old Feb 10, 2002 | 06:10 PM
b18bturbo's Avatar
Default Re: wideband o2 sensor help (GruvyTune)
thats based of a stock o2 sensor if i am not mistaken. You can easily tap the o2 voltage and check using a digital multimeter for less.
Old Feb 10, 2002 | 06:19 PM
89turboteg's Avatar
Banned
Default Re: wideband o2 sensor help (b18bturbo)
the systems ive seen use a different oxygen sensor that is more sensitive. stock ones that come with cars are only accurate at stoich. 14.7:1. the further you get the worse it is.. we want accuracy all across the board. isnt that the point of a wideband?
Old Feb 10, 2002 | 06:34 PM
GruvyTune's Avatar
New User
not true.
based on the UEGO sensor that you can get for $120 from partsbin (the Bosch version). Its a 5 wire wideband sensor using a Nernst cell.
Its the same one the Motec PLM Lambda meter uses.
Old Feb 10, 2002 | 06:56 PM
89turboteg's Avatar
Banned
so then whats the point of the wideband? what are you paying $ 1000 for. has anyone ever seen a comparison between the $1000 one and the ones you can make for less thatn $200?
Old Feb 11, 2002 | 12:06 PM
Xerxes's Avatar
New User
Which kit did you order? the techedge one?
89turboteg check out this thread here: https://honda-tech.com/zerothread?id=102755
I just got the FJO wideband this morning and will be testing it out over the next couple of weeks
-Xerxes
Old Feb 11, 2002 | 02:46 PM
GruvyTune's Avatar
New User
Default Re: wideband o2 sensor help (Xerxes)
yes
Old Feb 11, 2002 | 03:49 PM
DC2R714's Avatar
ANy opinions on the FJO wideband? I am looking into getting that when I go turbo in March. Just curious if anyone has had good/bad results with it. Thanks
Old Feb 11, 2002 | 04:17 PM
Tapp's Avatar
New User
Default Re: wideband o2 sensor help (DC2R714)
I have the fjo wideband, very happy with it.
Old Feb 11, 2002 | 04:48 PM
LsTurbo91's Avatar
Default Re: wideband o2 sensor help (Tapp)
Has anybody actually built the DIY Wideband controller and used it?
Dustin, I know you bought the kit if im not mistaken? Any news?
Old Feb 11, 2002 | 05:10 PM
89turboteg's Avatar
Banned
Default Re: wideband o2 sensor help (LsTurbo91)
wow thanks for that thread. Im still a little confused but ill look into it some more. Im just looking to use it as a tuning tool on a car that I install turbo or nitrous on. Ill be getting into an established business in about a month so im looking for all my tools from now so i can start off on the right foot. at first the cars are going to be using regular bolton kits or any custom kit that I make, but from there the sky is the limit. I want to be able to use it for base kits as well as with standalones. thanks so far guys. dean
Old Feb 11, 2002 | 05:36 PM
LsTurbo91's Avatar
-Xerxes
I just looked at this site you can purchase the controller/input kit for around $450. Will this work with the honda wideband as I can see the connector is the same?
Old Feb 11, 2002 | 05:37 PM
Xerxes's Avatar
New User
How are you using it? Did you just get a bung welded onto your exhaust? I assume you've used it for other cars too, how did you mount the sensor for those?
89turboteg:
If you've got a wideband and are tuning customer's cars, you can use it for nearly anything! If they have boltons and something programmable like an FPR & VAFC then you can tune them for max power and they'll love you
-Xerxes
Old Feb 11, 2002 | 05:58 PM
Tapp's Avatar
New User
It uses the honda wideband sensor that came in some civics, plugs right in-the connector that comes on the controller is a honda connector. And yes you just weld a bung into your exhaust or install it where your regular o2 sensor is now. (before the cat)
Old Feb 11, 2002 | 06:05 PM
89turboteg's Avatar
Banned
there are so many names and different sensors and stuff. now im not sure what to get haha.. sounds like the motec is the best one....
Old Feb 11, 2002 | 07:07 PM
GruvyTune's Avatar
New User
http://catalog.eautopartscatalog.com...on=++&usemake=
Old Feb 11, 2002 | 07:19 PM
98Psi ITR's Avatar
use a wideband off a ULEV Honda 2001.
lsvtecracer
Feb 3, 2008 11:54 AM
ThePro
May 25, 2005 12:08 PM
NeXtLeVeL_TyPe_R
Mar 19, 2002 03:54 AM
fastestdriver
Jan 19, 2002 08:04 PM
ILOVEGIRLS
Nov 5, 2001 01:05 AM
