View Full Version : Tech / Misc
- JDM EF9 front-end conversion?
- b16a pistons in ls ( i have searched )
- Wooooooops - Some parts I forgot to install in motor!
- DISTRIBUTOR QUESTION!!
- D16z6 head on a d16y8? What would I need?
- Espelir exhaust
- Tranny Problem.. Need Help!
- b18c1 rebuild to stock specs
- some noise comming from block...
- 8mpg to 13mpg
- hondata launch control
- dyno numbers...are they normal???
- i cant make it up my driveway :(
- Do my Dyno #s sound good or can my tuner do better?
- Regarding lightening stock crank pulleys
- Tell me what is going on here?
- Field's Vtec ctrl settings
- rally civic suspension questions... spring rates, sway bars, shocks, bushings
- Lowering An Integra In Jersey
- tranny swap PEDAL ASSEMBLY QUESTION????
- snaped a timing belt
- Theory: Force Feeding My Teggy Hydrogen To improve MPG.
- dsm 440 or rc440 injectors
- ECU HELP.... 98 INTEGRA LS....
- Nitrous Hose Size Question.
- Good sites for learning about cams
- Is the motor shot?
- how can you tell when...
- Has anyone tried this Engine break in method???
- APEXI VAFC / APEXI VAFC-2
- cleaning head and block......questions....
- White Smoke coming out of the Tailpipe
- Shocks and struts?
- need help quick
- squeaking brakes
- need help quick!
- Chipping Pw0... which chip?
- drill accessories that let u drive screws side way?
- is there any diff between DX and SI lower timing belt cover?
- helP with ARP head stud torque specs
- ok dx/si combo is in crx but it stumbles at first on take off?? why
- No Spark in Euro ER EG!
- AEM 1piece big brake conversion, Does the black coating rub off like the gold on the 2 piece?
- Air Conditioning and Hondata, I have a question
- NEED HELP....care won't start, no check engine light...etc...
- is my tranny bad??
- Please help with horrendous screeching
- What do you think I should do?
- Can some help me learn to read ignition and fuel tables? example inside
- any of you techs out there!
- Throttle Body Question....not what you think
- PR3 PW0 in D15B Vtec?
- ECU Problem?
- How hard is it to...
- Hesitation with part throttle/low RPM & idle fluctuation
- Water temp gauge install
- HELP!!! CAR wont start!!! tried everything please help
- how to wire msd?
- DIY sound absorbing install.
- would this mean i have LSD??
- Grease talk: best grease to get rid of polyurethane bushing squeaking?
- really weird sound coming from the front of the car
- Shift knob gram differences
- 65mm or 70mm T/B ????
- someone please name this sensor and purpose
- ?steering rack in 89 crx?
- Block Painting?
- Iriway7 spark plugs?
- loud noise coming from the tranny/ axle area.
- I got a LS, but what to do?? Any help
- Oh man, did i just stick my foot up my ass!
- How Much Till Block Needs To Be Decked?
- how to torque down arp rod bolts
- Does anyone know if DSMs and hondas share oil filters ?
- Lose any power from resonaters?
- synthetic to conventional?
- 90-93 integra....AXLES KEEP BREAKING
- B16A on engine stand... how do I replace the Rods/Pistons...?
- 2 questions .about tar removal and the best way to do it
- Raising compression
- b16a1?
- OK i need the group love on this trouble code
- crank problems
- y8 head/ z6 block
- need help? "what happened" situation
- H22A Swap not firing
- honda jacket?
- brake and alignment q's...
- Techies: Can you name this distributor? 56k maybe not
- suspension problem?
- Is it possible I jumped a tooth?
- water pump? b16a
- axles / halfshafts
- Map sensor valves.. Anyone know them..
- autometer gauge with wideband
- A Question about stroke
- outter valve springs.
- B20 block or B18C1 block for build up?
- Hard question about TDC sensor, please help.
- how far can spoon chip take me?
- s20 LSd into d16y8 tranny possible?
- Engine life for 2 different set ups
- Tie rod or steering rack?
- where to buy injector clips?
- TDC on a b18a
- vafc problem?
- lower on left than right
- jargons use in HT?help
- obd 1 plugs
- Distributor gear noise
- question about posting?
- Snapped ball joint bolt, what should I do?
- looking for a thiner head gasket...
- question about OBD I wiring in EF chassis
- Does anyone with a modded Type R have a vafc
- gear ratios question...
- Skunk2 adj. coilover spring pics please.
- Need an honest answer quick!
- 88 crx d16z6 idle jump
- problems with brakes after integra brakes swap
- Is this a good price?
- proper way to take off/install head bolts. and tq spec for b16 head bolts. NEED ASAP.
- alternator belt keeps heating up
- what offset?
- Will ITR throttle body fit on LS?
- crank pulley timing
- exedy clutch slipping ...can i change just the disc??
- Integra GS-R Driveshaft Info reqd
- head gasket
- fixed the h22 idle.
- Vtec is not engaging. yes another thread about vtec not working:(
- Fuel in spark plug...
- Will pistons for a B16a3 fit on a B16a?
- Lubing Rod Bearings??
- Map Sensor? Does it or is it supposed to click/tap?
- b16 swap into crx 88-91..the hard way...by welding.
- Spring install
- Will a B16 oil pan fit on a GSR?
- NEED HELP!!! PLEASE CRX ques!!!!!
- Beaks Kit and Suspension Techniques
- RC 310's for obd1, fit obd2 clips also?
- $1,500 Home Made Turbo, Any Oppinions?
- Heli-coil on block?
- We have a problem
- yesterday i had some toda b's installed.....then dynoed. now i cant shift.
- How to convert weight of rims to lbs??
- Where can I find some pistons and cams?
- Meziere Water Pump. Car won't heat up HELP.
- Changing o2 sensor plug?
- code 43
- car goes into gear but grinds and doesnt move
- a few problems that need to be fixed
- Anyone in the central florida area know of a good shop to swap my piston rings
- cant decide on cam, Help
- tranny
- Accord with no 5th gear
- Fuel pressure?
- mounting obd0 dizzy on z6 head for mini-me
- Need help with speedo please
- DIY steps for b16 head gasket install. NEED ASAP.
- Major Problem, car dies when driving...
- putting si hydro tranny into crx
- How many Valve springs are there in a set? (already searched)
- 11" rear discs
- diagram of crv 4wd system
- 02 Sensor and Air/Fuel Gauge hookup GOT A?????
- HELP: sometimes my car
- removed balancer shaft belt on h22 hatch..........
- off the subject..trial user??
- checked my timing today and it was retarded to 14 degress could this be why my car is missing
- Detonation noises with the car standing still??
- Where to buy braided line to move Oil Pressure Sender? ------>
- OBD 1 and OBD 2
- Removing Rust from INSIDE of Exhaust Manifold ------>
- Why did my diff break during launch
- Honing, piston to wall clearances & "out of round"
- throttle body help
- VAFC cuts off
- what can happen if you use cheap fog lights?
- Surging Problem On LS Motor...
- obd 0 sensor question
- what does the rotating assembly include?
- can integra brake calipers,rotors fit on a 95 civic front hub
- safe to use used cams
- Loud ticking, Plumes of white smoke... Any Suggestions?
- Are there any aluminum welder out there? Or do u know anyone?
- obd1 codes?
- rounded off some of my flywheel bolts...
- headers?
- crap idle after sitting?.....
- HELP! Something is wrong with my driver's side power window!
- Im new! I need your help about swapping a motor!
- Skunk 2 chip install questions
- OBD1 vs OBD@ Block
- Pros and cons of B18c1 head on B16a block
- Calculating final drive based on tire circumference?
- installed new clutch
- obd0 - obd1 harness question
- dmv- satan's workers
- CHECKING ECU FOR CODES!!???
- Poll on electical troubleshooting
- question about legal engine swapping
- 93 d15a6(CX) same as 94 (cx)...
- d15b7 crank in a z6?
- Need help with instaling a new starter in my B16a Hatch
- CTR N1 Crank Pulley!!
- fuse problem?
- Valvetrain components need suggestions
- D16Y8 using oil?
- clutch pedal and rod help.. how does that rod work???
- Brake question
- h23a1
- possible reasons for a spinning clutch??
- Oil Pressure problems
- b16 or b18?
- emmissions type question
- Piston Ring Gap Location
- Code 14 = Replace IACV
- water in head?
- what to about injectors
- MAGNECOR KV85 8.5MM SPARK PLUG WIRES
- FJO question for those who have replaced the sensor.
- Anybody run the p72(gsr)ecu in their h22?
- h22 delsol suspension
- ABS Accumulator question.. which will fit, where is it, and how much?
- axle question
- ej: jdm itr swap. it wobbles when acclerating
- o2 sensor problems
- is b16a swap worth it?
- Difference between EXEDY Thin and Thick sprung-hub cerametallic disc
- Anybody have an accurate idea of compression for PM7/ZC pistons in a D16Z6
- need some moto info
- which spark plug wire is #1 need to adjust timing
- Anyone hd this happen(IGNITION)
- 94 civic dx coupe check engine light code
- HELP! Speedo Freaking Out...
- ball joint for upper control arm poped up?
- ls tranny w/b16
- GSR MANIFOLD THEORY??
- Help-- Idle issue
- Do I need to run 2 seperate breather tanks on B20VTEC?
- rear camber
- Compression test before buying
- oil turns black
- OEM Locking Gas Caps Now Available!!!
- Oil pan for Dart B20 block
- What does a VAFC do
- Drop Zone shocks/struts
- Will a type R sway bar fir my EG if I'm using EX LCAs?
- experience with h&r coilovers?
