View Full Version : Tech / Misc
- Best way to change main seals?
- HELP! car wont start!
- Stock gsr internals with ctr cams
- 4-wire O2 sensor?
- Good compression numbers... but I'm using oil.
- ek swap with a/c
- is the IACV sensitive???
- Looking for more info on carb'd B-motors
- is my jdm R ecu better than chipped p28?
- obd II distributor for obd I set up?
- To header or not to header
- Going Turbo----Few quick questions------>
- 2000 gsr into 2000 civic ex automatic!
- Compression Tester fitting stuck in spark plug hole...UUUGGGHHHH!!!!
- Pre 97 and 98+ Master Cylinder interchangeable?
- tru power pulleys rsx
- ABS problems....
- Cleaning the inside of the Head?
- front sway bar install on EG civic
- Hondata doing crazy things
- CEL On, No Codes, No Start
- OBD1 GSR distributor problem
- exhaust leak...
- Do I need a "Flange" for my setup?
- need help asap w/ shiftlinkage and pin (tranny) on d16y8
- Axel install please help!!!!
- cam gears
- bleeding procedure for 96 civic hatch
- Quick Question
- 2.5" Exhaust Options
- HELP! engine problem...
- Bench Bleeding brake MC
- 94 Ls cluster in a 92-95 civic coupe?
- Engine Light at 3k
- mysterious CEL 73 on GSR
- CTR specs VS ITR specs -- CAMSHAFTS
- Bay Area look
- Gs-R missing up high.......
- how much to resleve a block..
- integra dash swap wiring help...
- Upgraded Engine Grounds
- clutch release forks?
- Wiring experts
- Topline Connecting Rods?
- B16a1 is misfiring at low RPM?? Higher RPM runs way better..
- what do u guys think about this muff?!
- Welding question
- buliding custom exhaust.. 2.25 inner diameter or 2.5 inner?
- non-MTBE gas?
- JG edelbroch intake mani with Holley 68mm throttle body
- cx wiring harness for a b16a question???HELP
- adjusting FPR without fuel pressure gauge...
- burnt out headlight
- tps voltage measurement...ok?
- ? ? What is the Eibach spring rates ? ?
- crower or skunk2 camshafts?
- Timing advanced to 18 from the stock 16? Anything bad.
- which valvetrain can support Skunk2 stg2 ?????
- in line fuel pump question
- Same Fuse Box???
- Engine Temperature and Gas Guage are not working properly after doing auto/manual conversion
- Motor Swap Question???
- b16a head w/ b20 bloc?
- Installing oil pressure gauge: Where else can I tap?
- Moroso oil pan on a B18 motor: What is true oil capacity?
- do cranks or cams warp from heat?
- cops giving tickets, aftermarket exhausts
- I Have a Question
- ctr motor in a 96 hatch
- Positioning / installing an ignition control unit
- Advice On Changing Brakes?
- To keep or not to keep gas charge...
- YS1 trany parts
- Engine light on?
- ITR throttle body --> GSR IM?
- 2 simple questions??
- check this motor out for me
- 6200rpm gauge converted to 8200rpm
- balanced and blueprinted....
- honda tech messageboard question
- gsr seats in del sol
- Shot peening, who has done it?
- Pulsating idle?? Why do some performance cars have this??
- loosing air in tires frequently
- need help!!!!! please
- NoS or Venom
- J&S Safeguard Question.
- Nitrous Junkies
- Tuning after headwork
- Help with fuel rail
- help with clutch/tranny problem
- Which one to get?
- hey stokring a b18c
- Ok people try to solve this !!
- how too check for air/vacuum leaks?
- gsr seats in a civic coupe
- Measuring O2 sensor voltage...
- Eagle Rods and Stock Pistons?
- Does AEM EMS replace the ECU?
- MTF Change.
- 1st gen rex??????
- Jack points on center line
- swapping from auto to stick?
- No CAT = more smoke?
- Pinging from Over REV
- N/A or Turbo
- LS/vtec rods???
- wheel bearings
- ZEX Vacuum Line
- NA Vs FI $$$$$
- HELP car wont start
- valve adjustment question
- installing pistons
- holley airmass ceramic headers??
- Malfunction Indicator Lamp" stays on while I'm driving
- Honda MTF
- Body shop needed in San Gabriel/Rosemead Area (So. Cal)
- trouble starting
- Banjo Bolt Tightening (Fuel Filter Related) *HELP FAST AUTOCROSS TOMORROW*
- Fun with Motor Mounts!!!
- what is purpose of purge valve???
- Q? : Affordable B series Drive Axels. Expert opinions wanted!
- troubleshooting: friend's car dies after a battery draw
- type r master cylinder
- extermely low gas mileage
- Compression Test #'s to CR?
- 75.5mm bore/ solid aluminum one peice tapered piston ring compressor.
- bad smell and no response...what might it be?
- Quick suspension intallation question
- Need dyno charts or help deciding if stock bottom end LsVtec
- Two Stage VTEC?
- Micrometers? Where to buy?
- Need Help just got new motor installed.
- How to powdercoat?
- About to install a Skunk2 Intake Manifold wih 64mm TB on a b16?
- Salvage / Junk Title ??
- gsr to crx dx wiring.
- Holeshot cams?
- CRX and Si....same ecu???
- Removing bypass valve in CAI
- CHECK engine light!!! HELPP!!!!!
- Probe rods & pistons?
- GS-R what color connecting rod bearings?
- ls final or 5th
- ??? about valve clearance
- ran into another prbolem wit my sawp
- custom spring rates
- anyone with an EK civic using type-r rear swaybar?
- going to dyno my car tomorrow anything to prep and do before i go?
- Cold Idle Problem
- exhaust piping
- Field SFC Hyprer-R Controller...
- two d-series cam gears work on a b-series?
- 1.7 SOHC
- Torque specs for flywheel
- timming sux azz
- Tranny Swap Need Info!!!!
- Best way to build a B20 non VTEC
- Siezed Bolt on rear compenstaor arm (caster help)
- Car lags in 1st and 2nd gear...
- Headlights connected to Radio?!?
- Question for the Tranny experts...
- Eagle Rods.... bearings to use???
- What cams are these, I think I got ripped off
- Radiator pressure problem?
- Cam plate torque specs for a 1st gen B16
- is thier a way to bypass the Cranshaft fluctuation (CKF)sensor????
- Timing
- looking for tech info on v6's
- no cat..How much hp gain?
- timing belt and cam question
- 15 w50 performance motor oil?
- GSR valve spring question?
- 94 Integra LS Hesitation Question
- O2 Bung Size?
- VTEC vs vvTi
- P/steer help! ID this object
- how to tell its a CTR tranny?
- Motor's so rich engine won't start...
- 1st gen B16a Ecu Tips
- Sensor problems...help!!1
- does any one have pics of a hydro to cable conversion???
- need help with rod bearings
- My flywheel bolts are different lengths...
- Eletrical help!
- Crower Stage 1
- air temperature sensor location on b16a
- Need Help! I am fed up, just broke pro drive axles,who makes the strongest axle.
- ecu specs?
- finally done the rebuild, hope to hit 170 whp
- All gsr tranny parts fit ls tranny?
- axles question
- coilovers
- Which timing belt? (Did Search)
- 99 ls head
- FRONT DC2 shocks on EK?
- What does it mean...
- Procedure To Install New Wheels; Running Without Balancing?
- stroke & bore for a d16y7 and Combustion on a d16y8?
- i juss did a swap but when i press the gas it dies HELP!!
- Help with weird MIL buisness...
- D16Y8 intake manifold differences
- a couple questions...
- Exhaust Piping Question on 97 Accord I4
- using FPR to save gas...
- skunk2 I/M w/o cams?
- oil leak
- 2 Questions
- would a 96 gsr apexi n1 cat back exhaust fit on a 93 civic coupe?
- help with clutch problem please.
- idle goes down...hondata question.
- plug on back of block(what is it?!)
- Camshafts
- how can you tell?
- Intake Manifold Info please.
- no freeway miles in break in period
- Anyone Have a B16B with the Spoon/inlinefour.com 1.8L stroker kit?
- location of coolant temp sensor
- throttle body (dashopot diaphram)
- distributor ?
- Transmission Question.. More of a "What happens when"...
- Difference between Starters
- Help anyone!
- 2002 si problem
- Anyone know which wire the VSS wire is on a '90 PR4 ecu?
- Header Wrapping 101 with pics
- dpfi to mpfi having problems in civic
- Do GSR rings fit ITR pistons?
- Mini-me w/new cam, breakin period? also timing belt question
- IAT sensor resistance, modification question
- OT: Guess what kinda engine is this...hella hardcore
- Question on alarm
- Sequential Transmission
- fel pump info?
- cel 1 for a 2000 civic Si
- clutch engagement
- Stock LS Cams = Stock B20 Cams?
- B16A Question
- vtec head on non-vtec block
- Valve adjustments
- suggestions!
- Final Drive ( ATS ) swap in a B18C1 tranny
- lightspeed exhasut
- BRAKES not Breaks!!!
- Aerodynamics
- how to install and remove the rubber boot on the ball bearing?
- Quick...have a Final Drive Question!!!
- 88-91 CRX Si w/ swap getting low fule pressure.
- Bonehead check - LSD
