View Full Version : Tech / Misc
- Bridgestone Potenza GIII Tire Pressure
- 94+ GSR wit SPORTLINES/TOKICO BLUES ???
- Code 20, wtf?
- ??? jdm (electronic) KAAZ lsd ???
- what to use to clean out a valve cover?
- problem with my N2O system
- are these 2 difffent?? or no
- Question on Apexi Rev/Speed Meter RSM Rev Speed
- gsr obd1 jumper question
- B16's (please own as necessary)
- still no luck with ABS
- gsr axle back bolting to apex n1 b-pipe?
- Valve clearance?
- compression numbers in
- H22A Accord OBD1 VAFC-II setting HELP.
- Does the # of bolts on an exhaust flange matter?
- B16 Swap
- Spark Plug/heat range Q's (help)
- The need for more speed! B16 question
- Get used rotors turned or not?
- NEED link for sleeve posting/pinning
- is this a chipped ECU? *56k no way, big 236k pic*
- Owners Manual
- Milled head+12.5 C/R pistons+Big cams good or bad?
- break pad noise
- air box/intake question
- ARP head studs??? LS all motor build!! Need advice!!!!
- Tools for compression and leakdown
- Can I street tune in one spot?
- Can anyone help me with this idle problem
- DYNO DAY!!!!!
- power steering???
- OEM Wheel studs that are longer than those of a Civic?
- compression test on jdm itr motor?
- Valve Spring Nut missing...is this bad?
- Need assistance
- Need to know all b-series specs. IS there a website?
- What fuel reading do i use?
- hub centers
- B-SERIES T-BODY????
- Honda KAWANI - Honda Best of the Best
- Question about AEM fuel rail
- LS Vtec questions (not noob)
- Duty Cycle
- the proper way to cap the hole on the throttlebody for map sensor?
- d15/d16 interchangability ?s
- whats does a stock 2000 sohc civic ex coupe make at the wheels??
- Engine stalls on cold starts...help please!!
- What's This Sound Like? (Clutch Related/Problem)
- helpp.......
- !!!HELP!!! suspension on prelude.
- srs light still not off....
- Energy suspension motor mount inserts?
- d16z6 pulling a 14.8
- Installin NOS kit
- Swap!!
- bearings and oil pressure
- b20 and LS
- rods which ones weigh the least???
- ECUs??????????????
- LS/VTEC What exactly is it.
- Who makes the best crank?
- lights are flickering what do i do
- is the B16A I found worth it
- OEM cam question
- PORT AND POLISH 95 GSR!!!
- eibach and skunk2
- Injector tech
- 93 Accord EX, length width of a stock CAT
- hose diagrams
- integra rotors on 91 civic dx
- QUESTIONS on LS/VTEC
- too much fuel!! help!! engine flooding from too much fuel?? wtf? tech
- b16 2nd gen in 93 civic ex won't rev over 2,000 rpm
- to the people that installed a sk2 im
- auto tranny with gsr motor?
- will all +94 and up integra cluster fit into 01 integra?
- problem with boging when first crank when not been cranked in few hours
- obd0 to obd1
- Ignition Problem
- ex head swap
- Question about Final Drive's
- Which USDM engine wire harness can i use on a 2000 jdm b16a
- CTR N1 Pulley+B16a= Which belt?
- Exchanging axle-backs?
- Searched: knocking from engine...LMA or rod knock?
- supercharger question
- SFC setting for CO test in 9hrs...urgent!!!
- weight displacement with cf hoods...
- Where to get OEM camshaft specs
- Good Deal???????????
- rod bearing?
- Weird vibration and strange noise in VTEC
- Need some help!
- 5th gen hatch buildup
- need tuning advice. just got a wideband and safc
- How do I get to the tenioner?
- Type-r Fuel Rail Same as b16a3 Fuel Rail ?
- what are u measuring when doing a compression test?
- Jdm s1 tranny
- ~ - - ------------ > VOTE FOR FAVORITE ENGINE SLEEVING <----------- - - ~
- D series fuel cut
- Can anyone explain this..?
- A Little Indight Please
- Change stock oil cooler on a B18C5 when rebuilding after spinning a rod bearing?
- alignment with or without traction bars on?
- Hub-centric ring? any one used these?
- whats the timing setting for a 98 accord f23
- What to do with B18a????(on a budget)
- Integra rebuild project
- Think I got ripped on ITR cams
- LS TB fit on a B16?
- Need information to get my ls/vtec project going....
- TLC for your motor
- fuel pump?
- yea ive got problems
- synchros
- can you rechip an odb-0 ls ecu to run vtec
- High Fuel Pressure
- Vtec not activating with Ls/Vtec setup. CEL codes are listed!
- So Cal Machine shop
- Center Force Dual Friction
- Flywheel weights??
- Look at my clutch!
- Clicking in Valve Train....Its always done it, I'm just finally asking...
- OMG: My valve latch nut came off
- Over Reved?????
- B16a Engine swap - Need Help
- apexi B16 manifold
- Alternator Install
- Anyone had problems with install of oil pressure gauge or can maybe help me?
- engine build-up ?'s
- Which OBD 1 Distributor(s) For B16a Head?
- Swap or a Swap???
- overheating
- I need help lowering my oil pressure
- Tranny tech questions differential swapping and instals
- Retractable Seat Belt issue
- does a 94-00 LS bottom end have a knock sensor?
- obd2 and obd2b whats the difference
- GSR and TYPE R question
- HEAD BOLTS
- BATRONIX SUCKS
- Engine Swap Experts Only. All others need not inquire.
- Engine Code 91.
- Removing check engine light/bulb from dash
- question
- zc block to D16a6
- vibration during hard cornering
- I'm an idiot...fuel lines at filter backwards
- Broken bolt in distributor
- B16a cold start troubles
- Valve Adjustment HELP!!
- alternator noise!!!
- Dynamic Compression
- DA Mounts. 90-91 ~ 92-93. Difference???
- rattle from top end?
- valve cover gasket part #
- Temperature Gauge
- Motor install help
- Exhaust for Mugen TL
- alnt question QUICK
- Piston Ring End-Gap...Is This Right?
- Stroker crank?
- B20VTEC with major problems
- difference between b18a and b18b block?
- Please help guys !!! check engine light then VTEC wont kick in!!!! Help!!
- b18a1 arp main studs???????????
- Need a quick tip...plz (civic Axle nut)
- axles replacement ?
- help me!
- Brake Bleeder Screw HELP...need size..
- ? 02 sensor
- HONDATA
- How exactly do the dealerships (Honda/Acura) bleed our brakes?
- I need greddy a/f gauge install instructions!
- 1st gear?
- dowel pins for ls/vtec. how does it work?
- Tranny removal question (quick question)
- D16Z6 Help
- Burning off oil - help!
- Arp head studs for b18c1
- help..my GSR transmission is leaking oil??
- Ring gap location?
- Need help with timming
- sir motors
- Need help with stock gsr manifold install!
- engine dies when clutch is disengaged???
- Lighten flywheel.....aluminum or chromoly?
- My first LS/VTEC.
- A/c belt removal?
- what is the best master cylinder to use
- Best shop for alignment in Bay Area, CA?
- engine rebuild?
- NEED HELP WITH A HEAD SWAP
- JDM
- Cant pass emissions car dumping too much gas.
- obd1 vs obd2
- What is the Diameter of the crankshaft end?
- Type R motor in 00 gsr: Wiring Question
- Motor mount bolt.
- 89 Civic shifter woes
- MSD SCI-L
- Drivetrain problems with my CRX
- test pipe problem?!
- oil and battery light came on ???
- B16 retainer P/N??
- Suspension installation Walk-through?
- Gear ratios for the 96+ Civic DX/EX Tranny???
- HELP, jdm b18c radles going into vtec
- Having trouble timing my motor.
- obd0 to obd1 extra wires help!!!
- Speed Governor in a JDM H22 with P13??
- enigne question
- Aftermarket heads
- LS/VTEC QUESTION
- Coilover top hats....
- 4 LUG WHEEL QUICK QuESTION!! need answer soon!
- Winter Storage How-To
- b17 : Tranny compatibilities. Which tranny would be the best... stock or c1? or are they the same?
- installing mechanical oil pressure gauge on b18c
- how do you adjust clutch pedal? how to install lsd?
- model number on (california) 95 GSR distributor
- b18b and zc intake manifolds?
- h22 fuel problems?!
- Alternator / Driveshaft / Intermediate Shaft Help?
- Primary/Secondary side of master cylinder?
- Hondata tuner is VA
- disrtibutor
- car idle funny
- IS this hydor lock ???
- b18a/b18c5 interchangeable parts
- exhaust questions....about holes
- SRP 9:1 pistons , dropped valve, reusable? pics
- Can't post anywhere else so....
- FJO Wideband installation problems
- how to get b16 eagle rods to fit ctr pistons?
- Just did clutch install and now car wont go into gear???
- problem w/ this ae86 corolla
- car shaking???
- hub/spindle/axle removal problem
- difference between jdm civic type r and jdm itr headers
- p13 ECU
- Tranny Question
- Hamp oil filters?
- jimfab motor mounts
- rim width VS. tire size?
- timing belt issue, can i do this?
- How to tell which valve stem seals are bad?
