View Full Version : Tech / Misc
- car wont run after its warmed up
- O2 Issues
- should i try it or not?
- hi
- Canadian Engine Stores???
- URGENT: Problems after spark plug/wire replacement
- WHAT IS THE CORRECT DEFINITION OF VTECH
- car wont go into gear need help fast!!! please help
- d15y7 to a d16y8 swap/wireing help
- Crome, Uberdata, Neptune etc. control Vtec?
- lose shifter(clutch maybe?) need some help
- custom a/c line? a/c wrap options?
- P75 throwing code 21 and 22 (vtec solenoid and vtec malfunction)
- help my car will not move. i think its a axle. ppl with expierence HELP!
- crome where to download?
- will 92-95 civic springs fit 95-up integras?
- S2000 Transmission Oil Question
- Clutch arm snapped, WTB stronger one !!!
- timing problem
- saturated or peak and hold
- Jdm itr headers ?
- Whats the difference between b16 intake manifold & skunk2 intake manifold?
- Calculate this c/r for me please!!!
- Triggering MSD 6AL off ECU?
- misfire cylinder #2 after JRSC uninstall
- Will a OBD2A dizzy work on an OBD1 motor?
- Ride height change from 205/60/15 to 205/50/15?
- Really Need HELP!!!!!
- I have a OBD0 b16 in my '90 Integra. I need a new Cap & Rotor. Where to buy?
- puting on a flywheel but
- Fuel pump issues
- D16A6 Refuses to Start - Long read
- All you smart honda guys PLEASE HELP HELP!!
- All you Smart Honda Guys HELP HELP PLEASE!!!!!!!!!!!!!
- Which wideband?
- UberData, GSXR ITBs and TPS
- MFR fix..is it worth it?
- problems running p30's
- DC2 gauge cluster into 90 Si
- problem with the 6al?
- Throttlebody
- Code 30 please help!
- Is there a way to manually roll down power windows?
- ITR lsd,will it fit into a 99-00 si trans?
- LS swap - dpfi to mpfi wiring/distributor problems
- P2E & P2F Wiring harnesses?
- wiper relay install
- civic body kits
- All B crank pullys the same?
- Nitro
- car won't start HHHEEELLLPPP
- radical idea
- Headstud Q
- B20B versus B20Z sleeves
- cold start problems
- wiring problem...
- does anyone have a d17vtec with bolt-ons?
- 1999 SOHC vtec wiring harness on an LS motor?
- zc swap,it truns over but no spark help and check engine glows
- P29 Q's
- main relay question already searched
- Failed emissions 4th TIME! HELP!!!
- tianiume flywheel???
- Throttle Position Sensor calibration question
- any K pro guys with the TODA flash????
- Cleaning question
- Opinions on maximum RPM for LS block?
- engine turns over too fast when starting
- p05 to p28 conversion?
- general question about check engine (self diagnostic system)
- howto properly torque a head
- PROBLEM WITH MY P28 AFTER IT GOT CHIP.HELP
- 1989 accord engine swap
- crankshaft removal
- good way to torque cam gears?
- Where to find to order honda integra syncrhomesh
- Any other pads that will fit the SPOON Calipers besides SPOON Pads?
- DynoJet Vs DynaPack
- How can I regulate electric water pump speed based on temp?
- RHD conversion legal in bay area?
- Isn't this really old technology?
- code P1457?
- CEL P1167
- itr cams and 12.5:1 cr
- Exedy Stage 1 full face organic clutch kit
- question about thrust washers
- brake problem????????
- Hunting idle??
- Valve adjustment problem with Portflow head
- EG Steering wheel in a DC
- tranny help
- Need Help Removing Rear Wheel Bearing Cap?
- will B20 rods work in a B16
- moroso oil pan and stock pickup
- Over heating and overflow filling up
- No Power
- Slipping clutch
- JDM Civic Type R THROTTLE Body size?
- compression= octane
- LS\Vtec Turbo engine problem
- Ignition Timing / Power FC / B18CR 96 Spec / Engine Check light.. need help
- trying to separate dash skin from skeleton...........
- alternator swapping
- Hatch barely idles, sometimes wont start, leans out, please help!
- Weird Sound
- Main relay clicking fast
- problem with pulley
- Firing order
- SAFC II- fuel running rich and low not sure how to configure
- Individual ignition coils to replace distributor?
- Piston slap at startup?
- Did compression test not too sure what to think....
- Forcing Open loop
- Difficulty shifting after clutch install
- Intake Manifold
- Anybody got a good tool, or method to getting out..
- tightening steering wheel?
- Question about bearing codes
- r integra an civic shifters the same?
- Surging, steady throttle and idle
- ************please help me, i have a problem*****************
- Strange Idle/off throttle problem after track day
- ???Proper Way to Put your Car on JACKSTANDS????
- what dizzy do i need for my h22??
- 02 sensors
- H22 Intake cam binding/locking up HELP!!
- Cam Gears 91 GSR into a 94 GSR
- crank wont spin
- Looking for a Tuner for crome or uberdata in Dallas Area
- Transmission Problems with '93 EX
- Need arp torque specs
- Need Your Opinion!
- Clutch Problems???
- shaking under load
- Whose got a good b16a recipe??????
- wiring and ecu gurus.
- compression numbers need help
- Guide to B-series cam specs...
- have a 93 coupe ex, at a dead stop, brake pedal goes soft sometimes, why???
- diesel transmissions and gear ratios
- LSD: gear vs clutch, which is the better choice.
- idle problems all motor d16z6
- Car won't go into gear. Help!
- Engines in, but im OVERHEATING
- Check engine light-knock sensor / code 23 problem
- probably better answer here
- hybrid tranny
- question for the REAL honda techs
- Camshaft hunting
- LOOKING FOR A GOOD SHOP TO DO PORTING AND POLISHING
- Looking for some info
- Car running rich
- AC help.
- Checking codes....... SRS flashing????????
- Are radiators interchangeable????
- 98 Accord to OBD I
- Hmmmm Pure Oxygen?
- some newb questions............
- IAT Sensor Problem on JDM ITR
- spark plugs cause missing?
- Car wont start... Fuel injectors?
- speed sensor
- b16 tb on z6 need help fast
- How to start a 10 year old engine?!?
- ZC vs. B20A5
- doing rebuild, looking for a good online price.
- ABS malfunction please HELP!!!
- Need some advice on a few quick questions. ASAP
- Car won't start
- Compression test results (Turbo JDM GSR)
- d15b turbo/hp question
- Engine Problem (Car dies)
- Is this a lsd trans or not? Please tell that to him....
- OBD0 o2 sensors?
- DC Sport JDM header
- Socal people i need your help
- 2nd gear issues
- Check out my allmotor B20vtec dyno sheet 307 whp
- Delta 272 Camshaft (d16a6) question
- Electrical Problem
- will this fit on a zc shoc
- EFI classes!
- AVCR Wiring Quick
- B18C5 headgasket?
- how necessary is catalytic converter
- motor stalls... won't rev past 4800rpm
- should i DIY
- obd-1 civic and obd-1 integra distributor ignitors the same?
- Camera Car Mount
- Weird 57mm piston caliper that fits on 10.2" discs
- Alternator
- da6 problems please help
- trouble installing obx lsd into crx transmission
- white 2 wire plug on engine harness red/yellow & green/white
- Car will not go into gear
- EG Rear Disc Question
- ys1 cable - hydro interchange question
- Transmission problem (not honda, 91 explorer 4 speed manual)
- oil is spiting out of my valve cover breather!
- 02 civic lx engine tranny swap
- PLease Help B18C AND P28 ECU ?
- any reccomended machine shops in chicagoland area?
- VAFC problem
- B16 gearing question?
- Mini-me timing question
- Help needing chooseing what size honda rod bearings needed.
- Valve lash
- A/F mixture at idle
- I have a problem with my brakes?? 96 civic..
- O/T anyone here work at a Hyundai dealership?
- 90 accord wheel hopping
- speedometer
- VSS, hondata problem. Create a fake VSS signall.
- What is the "Organic Matter" in clutches?
- need some quick help, can i use a VAFC to run VTEC instead of the ECU? help ASAP
- Broken Crankshaft....
- Cheapest dial bore gauge? (ebay?)
- does higher octane make more power?
- B20A5 LS/VTEC Questions
- Is my headgasket blown? (Small Vid Inside)
- Compression Results, Need Feedback Please ----->
- Clutch Grease
- Can/Will a b16 with ctr inernals run a p2t ecu??
- my car wont rev past 2000 rpm
- Crack on top of gas tank, what are my options?
- VAFC 2: Types of Vtec
- chamber cc's measured.... wtf???!!!!
- Annoying clutch pedal releases too late for my tastes
- p72 or p28? what would be better?
- P75 chipped for uber running P28 bin
- 95LS into 93 4DR LX..BOGGING AND POPPING AT 3K
- replacement map sensor for type r
- code 15, i need help
- code 6
- Splice EGT Wires?
- VTEC not loud after gutted cat?
- Tires: (3) 50/15's (1) 55/15....problem??
- D-series: What size/thread pitch are the oil pan studs?
- Dash display
- sending unit compatibility
- B18C5 block, crank, and crank gear... OBD1 oil pump ok????
- which wiring harness - GSR swap
- transmission issue
- where to get parts to make a conversion harness.
- Using Used brake pads/ Bedding in question
- What does mis-firing sound like?
- Question with LS ecu's and Si harnesses....
- non-vtec distributor on a vtec motor....
- NEED HELP ASAP NO COMPRESSION!!!
- should your car smoke......
