View Full Version : Tech / Misc
- Bad Fuse or what?>
- New ls vtec build throwing codes HELP
- Mobile 1 oil filter disapointment
- keyless entry remote not working after battery replacement
- unusual camshaft wear
- cluster swap help
- help with alternator belt..urgent! AC makes squeaking
- guy in the shop had the audacity to tell me to do the job that need to be done is $800.00 WTF
- Strange hesitation
- Need Help with installing JDM folding mirrirs
- Is all B-series axles the same? and will they fit all b-series motors?
- Wideband o2 sensor. Does universal 4-wire work from AutoZone?
- running lean according to plugs... will retarding timing help?
- Timing jumped!!!??
- help me with this fuel filter problem
- Quick! Installing Crane Cams, whats the washer for?
- HELP
- Valve question
- need help with cels....
- different rev limiter in defferent gears....
- nees help on my motor
- Help, Fuel Filter....
- trying something different with lsvtec
- Need help, TPS settings
- what is a p08-2 head?
- Dodgy skunk2 cams??
- Help! Engine Noise (LS/VTEC)... video included
- Fuel Pressure Regulator questions...
- vtec?
- help a noob out
- idles poorly, running badly
- temp gauge and a/c problems.
- Cam Spec Question
- car wont start
- Jagged holes in my HEAD WTF! Vtec intermittently works?
- Timing belt tensioner, signs of it going bad?
- hondata pro's.....could use a lil help....
- Ignition timing when coolant temperature is low
- ok to drive?
- 88 Accord Speedometer and Odometer suddenly not working?
- Civic Si Question????
- no reverse while car is running
- no spark
- Genuine Honda Parts vs. Generic Auto Parts Store Brand
- Vtec wont engage
- Distributorless coil-on-plug conversion
- Question about temp sensor on thermostat housing
- Is it bad to put warm water on a over heated engine?
- just installed 98 ITR guage cluster blinkers arent working. lookin for some help
- idle issue
- gsr radiator leak
- How can you tell
- Dented Oil pan cause smoking ..
- What code is this?
- ~~~NEED HELP~~~
- Is my tranny throwing in the towel?
- everyone read quick. Anyone know if nissans have CEL self diagnosis?
- Should I upgrade my plug wires ?
- Fuel Injectors(please help fast)
- which tranny in better in a turbo set-up? itr or gsr tranny
- no vtec, code 21
- Distributor making belt noise???
- what map sensor clip will plug up to my 99 si map sensor?
- engine size???
- Whats the sensor, and do I need it for OBD1 conversion?
- where to download uberdata 1.66
- B16 Tranny switch? Is this posible? HELP ME OUT PLEASE!!!
- b16 intake manifold and throttle body sensor swap
- oem honda lsd in b16 tranny with ls final drive
- intake mani install?
- How do u convert obd0 distributor to obd2?
- Installing new crankshaft ...
- crank pulley
- b16 valve adjustment with new cams??
- Copper Spray How-TO
- Test Pipe 4 my setup
- PR3 ECU Mod.
- Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES?
- Flywheel bolt Q!!!
- How do you measure the piston to wall clearance?
- need help choosing
- ls in 94 civic ecu help
- wiring problems in my 90 hatch
- ITR cam question! pics!
- Starter spinning freely on B16????
- question about bleeding clutch
- X beam vs H beam vs I beam
- I need a new crank, where to buy?
- timing cover OBD2 gsr what will work
- Mainshaft and countershaft bearing ?'s
- whats this?
- grinding tranny?????????????
- How Fucked is My Engine?
- Manual transmission rebuild
- What do U think? Do we need a transmission forum?
- if you like JDM READ THIS!!!
- bought my CRVTEC swap, need opinions as to what's in it
- stock rods floating wrist pin ??????
- fully-built motor never worked. still not. here's what happened. can you help?
- sleeves need to be bored/honed?
- ECU came with a wire hanging out of it...
- b16 thermostate location and write-up
- CTR brake master cylinder
- ITR Steering Rack Compatability Question
- Where To Put Oil Temp/Oil Pressure Gauges?
- Will a JDM H22a engine run fine on 100LL aviation fuel ?
- what is needed in a tune up
- check engine light
- b16 head vs. gsr head on b17 block
- Anyone running Buddy Club Spec II exhaust?
- speedo needle acting up!
- poor mans type r-ive searched??
- do hondas have lockup clutches?
- RANDOM AXLE NOISE
- need diagram of a/c unit install in dc2
- How much can i spray on a stock block?
- Emanage trouble
- Idle problem
- MAC OS tuning software.
- Stall problem...Engine turns but won't start..
- knock sensor wire! shielded?
- ac compressor... grinding noise
- CTR Cams in GSR Setting please HELP
- Looking for a good header
- ELD, Do I really need it?
- Anyone here have any luck with Grounding kits?
- i need info on my motor!!!
- ECU question... **ASAP**
- Old thread about direct injection
- Cleaning cams!
- Will a GSR OEM crank pulley fit to b18b?
- which dizzy should i use?
- MINI-ME SWAP need help
- what are the symptoms of a bad thermostat?
- who makes the Hondata/Password JDM-style IM gasket that is SOLID ??
- No timing mark on pulley - How do I Set Timing???
- Speed Sensor help?
- OBDI Distributor Differences
- Slight play with full floating rods and pistons.
- ITB Questions (I searched)
- Does oil pressure sender sense before or after oil filter?
- OBD 2 JDM GSR crank sensor ??
- a/f after 9,000 rpm
- "Tuning" what should i do?????
- Black smoke
- I cant seem to Time my integra engine. PLease help.
- 1,2,3......3,2,1 (TPS Related)
- dizzy question?
- Dim CEL? fuel pump not turning on
- Greddy Oil Sandwich Plate
- axel problems?!?
- edelbrock 65mm throttle body specs please?
- piston code? anyone know it all?
- Head bolts stripped threads in block
- smog Gurus: your help is needed
- Misfire CEL 74 Help!!!!
- Are the people at tech edge retarded?
- Can I use internals
- dizzy has oil inside??
- MSD cap fitment problems with a twist...confused...help please!
- OBD1 Injector wiring (Im a little confused)
- can i put a new disk in a used CM clutch hub?
- Replace pistons without pulling engine?
- LSD Install: What is this?
- SI isn't performing as good as it should!
- question 'bout carbs (omg, what r those?)
- anyone purchase a race block for sparkracing??
- h22 oil pressure sending unit
- Daily Driver 1987 Nissan Stanza: Worth it? Reliable?
- z6 block y8 head which ARP headstuds to use? Need help.
- Recently replaced valve seals leaking again
- OOB I to OBD II enginge swap
- OBD2 Mini Me w/ OBD1 (z6 head)
- ???Pulley and Lower timing belt cover on lsvtec
- S LIGHT BLINKING!!!!!!!
- Clutch Questions ?
- Car won't start ... not a starter issue
- PieceofCrapValve
- DIY turbo on EBAY ?
- questions on blox/skunk2 intake mani on jdm b18c
- Putting together a motor...what kind lubricant
- Header coating
- obd0 B16 Did a compression test...
- Having Transmission/Clutch Problem? Help
- ac tension pulley question
- B16 Head on a B18b1 block?
- Backfiring problem
- need to buy a distributor for my crvtec swap
- What does a 00 Civic Si valve stem seal look like?
- KMS Performance
- 1 wire ls/vtec .. vtec oil pressure switch?
- Hx head
- vtec not working. solenoid is fine... next step (s)?
- stripped block help???
- what to do??????keep my LS tranny?????
- Random Starter Problem
- no-name crank pulley question
- Need Advice on possible distrubutor
- Acid Porting
- Motor smokes at WOT ..
- what arevalve lash specs for ITR cams in GSR head
- synthetic or non synthetic oil
- fresh engine rebuild throwing two codes, help me fix??
- repairable block??
- EGT insted of o2?
- looking for a mechanic/shop in the socal.....
- FAKE Skunk2 cams
- Easiest way to run Rywire harness thru firewall? (Without cutting the wires)
- digikey 73hc373
- blue smoke every so often while driving valve seals?
- Tranny is hard to get into gear sometimes, other times its fine?
- b17 gurus -- thinking of b17 block w/ b16 head
- re:tranny parts swap
- Valve adjustment....misfire?
- Installing custom ITBs. RPM increases very slowly. Why?
- P28 vs P72 no low end power
- strange starting issue, Need Help or Ideas.
- Best Tranny for Turbo GSR???!?!?!~~~~~~~~~~
- Anybody know how?
- want to borrow p28 with h22 chip.......
- Dyno
- 89 Accord Rebuild
- Bent valves?
- Is the 2005 type s Primary O2 sensor different from the 2004 O2 sensor
- cel confusion??
- question on engine swap
- blow off valve noise.
- burning oil ONLY on de-acceleration
- crank case venting and my vacuum pump setup.. Need help..
- B18B1, Fuel
- need help with Oregon Title Question??? HELP ASAP!!!!
- Head gasket blown after rebuild.. Suggestion?
- AEBS or Benson sleeves???
- Code 14- IACV need help ASAP, please.
- Complete steel brade brake lines? No hard line system??
- Leinient smog shop in Bay Area?
- Electrical Problem / Fuel Problem
- is it possible to regrind GSR cams to ITR or CTR Cams specs?
- ELECTRICAL QUESTION Does anyone know how to do this
- ((I searched)) and no luck want to do dpfi to mpfi what parts do i need?
- AEM fuel pressure regulator ORFICE SIZE???
- JDM b16 wont start just backfiring
- d16z6 head inspection
- Vetec not activating
- flywheel question
- Axle Problem
- complete engine rebuild kit ???where? can i get one
- What are the differences beteween the F20a and F20c????
- ls/vtec acting like total shyt at 7k, blinking check engine light**WTF**
