obd 1 plugs
Old Nov 27, 2003 | 06:52 PM
drunknbass's Avatar
Default obd 1 plugs
anyone know where i can find the female side (ecu side) obd1 plugs.. like the pieces in the side of the ecu.. i need to make a conversion from obd1 to obd2+ (rsx) and need plugs that my exsisting obd1 plugs can plug into. i contacted hondata but havent got a reply yet..
also thought of buying a cheap obd 1 vtec controler to cut the plugs off of but they only tap into 2 of the 3 plugs so id still need 1 plug
Old Nov 27, 2003 | 06:58 PM
wickedEFguy's Avatar
Default Re: obd 1 plugs (drunknbass)
I would talk to katman, newman, or blown90hatch
Old Nov 27, 2003 | 07:00 PM
dohcnotec's Avatar
I get obd0 ones from dead ecus I have laying around when I make obd0-1 harnesses. My advice is find a dead ecu and desolder the plugs... May I ask what this is for (RSX???)
Old Nov 27, 2003 | 08:39 PM
drunknbass's Avatar
yea ive tried desoldering the ecu plugs out of the board but its kinda sketchy when soldering new wires on cause those pins are really close together and dont take much to break... but if thats what it comes down to ill have to do it.
and its to put a k20a in a eg6 without cutting or repinning the eg6 harness in any way
Old Nov 28, 2003 | 10:32 AM
dohcnotec's Avatar
Default Re: (drunknbass)
are you using the stock fuel system?
Old Nov 28, 2003 | 07:31 PM
drunknbass's Avatar
for a month or 2. im sure the fual pump is suffecient enough for that since its supposed to run a b16. im putting this motor in a real eg6 jdm hatch
JUN.
Mar 28, 2008 06:00 AM
Brian_92GSR
Jan 17, 2005 06:41 AM
hybridb18
Jun 19, 2003 08:49 AM
b16aeg6
May 3, 2002 12:26 PM
