is my tranny bad??
Old Nov 29, 2003 | 04:33 PM
HatchBox's Avatar
Skoobie no more...
Default is my tranny bad??
just got a b16 from hmotorsonline.com and i drove it 2 days then it stated to vibrate bad in the front ...so i replaced the axles. but that didnt fix it...there was play in the passanger side axle. Where is goes into the tranny it wobbles back and forth and up and down..not much but enough for it to vibrate the hell out of my car...i cant drive more then 20 mph ...do i need to call hmo and send me a new tranny or is this a easy fix??
Modified by ind3ciso at 10:46 PM 12/2/2003
Old Nov 29, 2003 | 05:42 PM
HatchBox's Avatar
Skoobie no more...
Default Re: is my tranny bad?? (ind3ciso)
Old Nov 29, 2003 | 07:56 PM
HatchBox's Avatar
Skoobie no more...
anyone. . .
Old Nov 29, 2003 | 08:23 PM
Jim Truett's Avatar
If you can wiggle the CV joint cup with the axle fully inserted into the tranny, then I would assume the tranny needs a new bearing. That would require a full disassembly.
Old Nov 30, 2003 | 05:55 AM
HatchBox's Avatar
Skoobie no more...
Default Re: is my tranny bad?? (Jim Truett)
so its time to call hmo and tell them ship me another tranny
Old Dec 2, 2003 | 06:46 PM
HatchBox's Avatar
Skoobie no more...
well called steve at hmotorsonline...he said that it coudnt be the differental because if it was...the car wouldnt move. he also told me to take off the dust rings on the inside of the hubs. I just did this and still no fix.
I can move the inner joint in and out, and any direction...like its not locking in...i felt inside and nothing seems to be loose that i can tell...sigh...i just want my car to go...pleas someone help..
im about ready to pay someone via paypal if they can help!
Old Dec 2, 2003 | 08:39 PM
Bob_Digi's Avatar
so what did steve say about sending u a new tranny?
Old Dec 2, 2003 | 10:21 PM
mmuller's Avatar
Mad Scientist
Default Re: (bob evans)
Check if the teeth on the axle and diff. are in good shape; if the axle goes in smoothly and if the axle shaft sit in the diff. snuggly.
take the axle and oil seal out and measure the diff./case tolerance.If the differential and/or bearings are messed up the tolearances are going to be off.
Old Dec 3, 2003 | 02:42 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">take the axle and oil seal out and measure the diff./case tolerance.If the differential and/or bearings are messed up the tolearances are going to be off.
sorry but im not too experienced with that kind of stuff how would i got about doing that?
Old Dec 3, 2003 | 02:00 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (ind3ciso)
Old Dec 3, 2003 | 09:57 PM
troyb1's Avatar
New User
Sounds like it could be the differential pin getting bad.. I had the same problem with mine.. The axles would wobble back and forth and then a week or so later it let go and I had to replace the tranny..
new_climber
Mar 27, 2008 05:05 AM
2wheelhunter
Dec 1, 2006 09:04 PM
*Boostwerks*
19
May 3, 2006 09:20 AM
josh green
Aug 3, 2004 07:51 PM
Big James
Aug 21, 2001 10:00 AM
