View Full Version : Tech / Misc
- h22 rpms vs b18 rpms
- what power steering pump to use on gsr swap?
- STR 65mm throttle body @EF8
- built motor and AFC question...
- dyno machines
- JDM H22 O2 Sensor Wiring?
- burnt 2 quarts of oil in 3k miles ok?
- vtec pressure valve (code 22) coming up?
- ANOTHER IDLE SURGE PROBLEM...AHAHHAHAHAHHAHHAHA
- Eibach front strut tower bar.. fitment issues
- how do u check the CEL for ob2 swaps?
- mk3 supra electrical problems.....plz help
- n e one ever reuse head bolts b16a2?
- Tuning VAFC controller
- B-Series tranny question
- removing power steering?
- GM Synchromesh Friction Modified in non LSD
- Any ECU's(USDM) that don't look for CKF??
- Any one know about a thicker head gasket for an h22 ???
- r12-r134?help preciated
- anyone have times for all motor crv
- ECU HELP
- obd2 ecu pinout diagram
- What motor goes in a non GSR 94-98 integra?
- OBDII JDM p72 auto to manual ecu conversion possible?
- what car holds up best over time?
- power steering to manual conversion *link needed*
- MSD btm question
- question.?
- Experience with ZEAL suspension (Function B6 Zeals) in particular???
- Compression test B16A, should I worry?
- Is the Inner timing belt cover important?
- shift linkage question.
- Paranoia? Is this going to affect head gasket seal?
- Big Cams Oversized Vales but sock bottom end?
- D series IM gasket
- JG Engine Dynamics Are they Good or Bad
- HELP ME!!! Can anyone help tune my cams
- shaving head
- Quick question...
- ls obd0 motors
- Nitrous Pressure (Line Pressure)
- Frozen/Seized Lower Spring Seat/Seat Lock on Coilovers
- 1990 b18a fuel rail work on B18c1?
- y1 trannies?
- Transmission / Clutch knocking
- My Lower Ball joint is stuck how can I free it?
- looking for some one to tune tec3
- tech help?
- I need some Clutch help?
- I really do need help!?!?!?
- Need wiring diagrams for 01 v6 accord and 03 CL-S
- d16z6 block with y8 head........what headstuds?
- CEL comes on and off.. I can't figure this out O2 Sensor?
- I need some tech help
- question about gsr valve springs... i did some searching and didn't really find.
- Speed Sensor Code 17?? with b18 swap.
- VAFC settings for stock B16
- Having Problems with Exedy Clutch Engaging....HELP!
- Cleaning Fuel Injectors
- few wiring ?'s about B16 swap into 90 CRX
- removing crank pulley?
- EK LCA BUSHINGS?? WTF!!!! HELP WTF DO I DO?
- 2 different PCV system B18B1?
- JDM cam identification help please....
- VAFC with an LS?
- timing chain
- WILL A JDM TYPE R WIRE HARNESS FIT MY USDM GSR???
- experience with N2O
- Will VTEC kick on??
- code 6
- trouble removing oil pan...
- size of the brake bleed screw?
- just back from the shop (h22, forged pistons, frm, sleeves)
- radiator reservoir
- directport nos on stock b16
- Check engine light?
- B18C -R
- Cable tranny problem
- burnouts?
- where can i get a b16a or b18c for a good price?
- Suspension theories - coil over setup and tuning
- Inlet flange CAD files
- B16 Pulling the head - Got some quick questions (headgasket)
- 1st time dyno...
- Swap related no start issues
- exhaust port question and a TB question
- Poll......
- catalytic converter
- Valve Seal help
- b20z timing issues
- can somebody help me diagnose this problem?
- idle??
- did i get the right engine????
- question about pedal pressure - cable tranny
- wet 4th cylinder? why?!?!
- GSR Transmission Problem
- hood locks?
- honda Site's?
- spark plugs wire order ...
- b16 boring cost
- OIL leak, wtf?
- Hondata Seminar Notes
- NEED HELP PLEASE! I INSTALL A NEW FUEL REGULATOR AND NOW MY CAR WON'T START
- AEM Fuel Pressure Regulator
- Throwing codes 3 and 22!!!!!!!!!!!!!!
- WTF is goin on here!!!!????
- Trying to start a new project soon(building b18c type R)
- 98 gsr turbo oil pressure ???
- HX Power?
- will i pass smog with exhaust leak?
- Did search need help! Not your basic "car won't start" thread.
- help!!!
- New to the scene, need advice and help, Thanks.
- what header ti use on k20 motor in a DC2...
- Set timing?
- 1000+HP HONDA I-4 only! On Gasonline- no alch. I want to know stats and figures! Who, what, when, wh
- starting issues?????HELP???????
- nd best of the best or best of the worst???
- Whining noise from motor....
- Nitrous Vs. Trubos?
- how often???
- smoke on first and second
- Crank/Bearing/ and or Pulley noise?
- 440cc Nippon Denso Injectors
- Western WA people: where can I get a leakdown test?
- '98 Acura 2.3 CL... Boost or Engine Swap?
- droped JDM single cam ZC motor in my crx
- S1 transmission
- is higher compression better for all motor?
- Built d16z6 in 95 dx coupe - almost done, i just need your help
- all the intake valves hit the pistons
- What turbo for b18b EK civic
- tuned.... but still have LOW whp.
- help me with this OBD1 ecu CEL code
- how to raise coilovers...JIC's..confused..IF you have any coilovers, help
- New bearings, hone crank and cylinders 1.5 Civic?
- easiesnt way to remove DA rear bumper?
- Oil sender line?
- cooling fan problems
- GSR Skunk 2 IM owners
- DC stainless
- please help neone, my car just dieeddd on meeeeee
- is the b18c the true jdm motor or b18c5?? need help before i buy the swap
- problems with oversteer/uneven camber
- What cc injectors should I get???
- little help please
- What is needed for LS rods into a D16A6?
- Steering wheel smaller than stock 93' Del Sol?
- Suspension 1/4 mile times?
- Polishing Steel?
- e-manage tunning - need help
- HELP!! broke a water pump bolt
- Smog problem
- Anyone ever get their head "Magnafluxxed"?
- what does M5w30 stand for?
- Map sensor CEL with a Jet V-Force PCM (Help)
- Need ECU pinouts
- any solutions....automatic to stick,,integra
- b series trannies and their clutches
- Reliable Engine Builders
- SI injectors in a EX?
- Help! Ignition Timing!
- Apexi VAFC 2 question...
- strange annoying noise 92 gsr
- Help please
- RSX oil filters
- Quaife LSD Fluid
- CL Type-S with NSX heads... posible?
- b16 head on a b18 block
- y8 intake mani VS my 90 SI mani on my SI. better or same?
- Federal Mogul products? anyone use them? heard of them? good? bad? info please
- safc in an si
- TIMING ISSUES....bad dizzy?
- removing oil gallery plugs on B18A block?
- PR4 LS rods on built D16a6 w/ D16y8 head... ...Weaker or stronger than stock a6 rods?
- WTF is wrong with my engine??? Vid Inside
- Causes of low gas mileage
- '00 si vs. gsr spark plugs?
- How to remove crank gear?
- hx engine--is it vtec?
- injector leak please help!
- o2 sensor problem. Help!!!
- Downforce over the front wheels theory *pic*
- knock sensor not connected on 93 LS swap. will it hurt anythign?
- d15z1 to b18c1 jdm gsr idle issues
- ? about alternator/idle
- 450cc talon injectors
- NEED TORQUE SPECS!!!
- Only reading 3.5V on MAP sensor, what could cause drop in voltage?
- D15B1 Flat on High End
- stripping chassis
- Headlight
- Twin Loop Mufflers
- Crower products?
- how to test MSD products?
- ECU Chips and Programs
- sprial core HT leads?
- What is this gear like thing on the rear hub?!? Please help!
- ECU identification?
- will my car be fast if....
- coating my pistons.
- B16B obd2a /B16b obd2b
- VTEC Solonoid bad? Vtec engages, then dis-engages, the engages...
- some cat tried to pee on my 95 si
- Rust in coolant system
- Brake Line Fitting Size
- Battery Relocation: Charging wire?
- bogging jdm d15b
- b20a 88-91 prelude transmission
- building a B series
- MSD 6a box installation instructions???
- My injector plugs are cut...can i re-wire them?
- Base Map for TEC3
- fastest b16a na
- oversized p29's need help!!!!!!!!?????
- brake light in dash problem
- blocked off IACV
- What should be my 1st upgrade on my car??
- Pinging and Octane Issue with JDM B18c
- Rust+header
- I go at WOT Sluggish WOT performance
- conversion harness help, obd2b
- b20z I manifold ???
- TIRES
- hondata help
- question about oem gsr fuel injectors?
- what a day (long) (radiator question)
- Which order to bleed brakes???
- MAP SENSOR
- 2nd Generation
- Im going to burn my car!!!!!!!!!! Idle Problem.
- BRAKE SYSTEM HELP!
- Is there any difference in 15" & 16" rims?
- sodering?
- Burning oil, oil spots all over the back bumper.
- No Name EBAY shocks, adivce:
- car wont start
- neuspeed sport on teg
- how can you deactivate your power locks?
- This is the part number for a 2000 si..
- Im having fuel problems:(
- Cam Holder Dowel...
- K-Sport coilovers? New to me...
- D15B7 Tranny w/ LSD what axles?
- OEM Timing Belt B16A2
- acceleration not wat it should me
- JDM h23 V-Tec pic
