View Full Version : Tech / Misc
- b18 pistons in a b16???
- Overheat and A/C Issues
- changed 2 head gaskets and still leaking and burning oil??
- lsd chatter????
- Emissions?
- Stripped bolts/nuts
- greddy e manage
- diameters of lsvtec dowel pins
- Apexi S-AFC II problems
- Phantom Grib Rocker Arms
- Which ECU to chip for uberdata
- Jackson Racing Map Controller need info??
- Timing question- purpose of service connector jumping when.....
- b16A1 OBD-0 to OBD-1
- transmission leak
- changing the oil pan gasket...
- Timing belt help!! (Experienced people)
- obd1 distributor to obd2 harness
- Boomslang obd0-obd1 harness Question
- Engine Help H22 in 95 civic?
- Prelude CLUTCH Line Problems...!!! Please Read.
- is it jdm or usdm
- fuel injector and ecu question
- opinions....spark plugs / oil / lsd tranny fluid
- Can I ditch the spring bolts at the axle back?
- Automatic tranmission stuttering. Is it going to die?
- OBD-0 --> OBD-1 Pinouts - Correct?
- HONDATA DATALOGGING WTF?????
- b16a rebuild
- welding combustion chamber
- compression check
- B18B1 Overheating
- b16 in my sol b16 not working right???
- Will my stock motor be able to handle a turbo kit?
- 3 Bar Map Sensor What Gm Car?
- Is this tranny to engine bracket necissary?
- vaccuum leak...
- Cutting up an ED into a front clip and back half
- Need Car HELP ASAP!!!!!!!!!!!
- Spent 5 grand on a Golden Eagle motor to get a bad water pump!!
- Problem with acceleration.....HELP!!!!
- Aftermarket Air Intakes without a slash cut - poorly engineered??
- code 13 and 20 in my 90 crx what is it? how do i fix?
- Cold Air w/ Bypass Valve vs. Short Ram
- JE piston rings
- ZC transaxle
- Bottleneck? If it has to happen, where, or how can I avoid it? (exhaust)
- bogging and breaking problem b16 swap
- Will running the rad fan all the tme when car is on suck more gas? (info inside)
- where is the water temp sensor?
- VAFC memory lose if battery unplug??
- hey i need help with check engine light codes for a 93 civic coupe
- Replacing valve train....need some good advice, and good part references...
- b16a with LSD tranny...tranny fluid change question!!!!!!
- Fuel pressure drops at WOT!(help)
- clutch ?
- which type clutch for cable tranny converted to hydraulic
- where can i buy EBC "Yellow Stuff" pads?
- 99 civic si eating alot of OIL and GAS
- B16 block, gsr head how do you do it?
- won't go into gear!
- Honda/Acura OBD-0 and OBD-1 ECU Chipping
- Honda bond on cam caps?
- mil eliminator*** anyone know how to make one and how install
- Turn signals don't work, help!
- Alternator Help
- What size upgraded Fuel Pump for 200 HP LS/VTEC ???
- my vtecs playing up.. help!!
- ***Honda Engine Build up Video***
- Oil leak PROBMLEM!
- h22 cams
- Cam Questions
- Will HP Vary from elevation?
- Saturated injector wiring question
- Installed Walbro 255hp pump fuel pressure dropped.
- -HELP-Wont rev past 3500rpm
- HELP-All the sudden car won't start??? pump primes, then silence...
- Car is struggles to accelerate...loss or power...
- Wiring diagram for Emanage for S2000!! Searched could not find!
- do you guys know any company that makes engine/tranny adapters?
- Oil in coolent, smoke, looses/burns oil... gsr... :(
- check engine light...P0442...what could it be?
- motor mount
- Bolt Size
- NAPA GOLD FILTERS YAY OR NAY
- im going crazy here
- Swapping Gears... a tranny question
- how bad does itb's ruin gas consumption?
- fuel pump no priming...
- 99 civic si LMA into 1st gen b16 head?
- type r head on 1.6
- all my tranny oil leaked out of axle
- Install oil squirter in LS block...possible?
- Positions of Msd Blaster Coils
- whats works good to clean a really dirty engine bay?
- 92 civic hb ls/vtec turbo
- distinguishing between heads
- headgasket swap, compression numbers read 200 205 140 230
- How and what do u have to do to replace cams?
- power steering problem
- head swaping
- QUICK ECU QUESTION!!!!?!?!?
- prelude problems
- car shut off while making a turn
- >1mm overbore, piston slaps, need help plz!!!!!! EMERGENCY!!!
- DC Header swap help!
- Head work in vegas area?
- LS/VTEC making gay knocking noise
- where should the slack be when putting on a timing belt?
- leaking oil from cams on cam gear side
- civic swap map/idle probs
- broke off stud that holds header on...how to remove?
- cutting out when car gets hot...need help
- RESET?
- this is driving me nuts: Clunking sound while turning
- Who/What the heck is Tsudo?
- $15 Ebay Short Shift System vs. B&M/Skunk2 $100 Short Shifter System
- B20 swap questions-searched many hours-still have questions
- ACL out of spec, need oem GSR main
- reinstalling b20 head
- Any way to test an A/C line for a leak?
- replacing the headgasket without remove the crank gear / lower plastic
- RC injectors question
- shimming oil pump fpr higher pressures
- Received head w/out cam caps....safe to substitute?
- Starter wont work, car has power
- pfr6L-13 equivalent????
- engine over reving when the clutch is engage
- what does lost motion assembly mean?
- Recommend me a good brake setup
- vtec solenoid plug
- Stock bore size of a b18b?
- hondata s300?
- Bearing chart for B18c
- Smog experts please Help
- Intake Manifold Design/Thought/Idea
- b18b internals into b18a?
- upgrading internals...
- hood latch is fucked and I cant open my hood
- d16y8 valve train>>>>>>???????
- Any one have any experience with AEM EMS traction control?
- apexi v-afc setup
- bleeding gone wrong
- o-ring crush before retorquing
- b16a ecu mapping
- Techedge WB display problem?
- NEED HELP--cel np codes won't rev past 3500 rpm
- Could someone tell y my vtec isn't workin
- Top Dead Center Locator Piston Stop Tool, How do you use it?
- Transmission vent oil leak (searched)
- battery goes dead
- will using a d15b7 distributor on a d16y8 cause problems?
- misfire, can figure it out!
- shift linkage removal
- Oxygen Sensor Simulator ???
- Crx DX front bumper absorber fit on crx HF?
- slim fan install help
- what ARP headstuds for a d15b vtec???
- MSD 2-Step feature causing problems on my H22 setup...any advise???
- Hondata S300 Info
- fuel gauge doesn't seem to be working right (CRX w/LS swap)
- NEED HELP want both fans to turn on with manual switch(CRX with LS swap).
- Knock sensor came apart, and way to put it back together?
- Does somebody have an Spoon air filter in his air box??
- Cam Tuning noob question
- Camshaft Install
- Pulling IACV plug off, car should stay on or turn off?
- GTech Pro
- obdII tuning and emission questions
- B16a1 vs B16a2
- cat removal question....
- SIze of vtec lobe on ITR cams
- HELP 95 EX COUPE WIT 95 LS WITH AC LINES ??????????????????????????
- B20Z with GS-R internals. What are the advantage and disadvantages.
- B18C head on a B16 block ????
- compresion test???????????????????????????????
- ignition switch?
- disconnected hose on my 1990 maxima! help me!!!!
- Tachometer and speedometer in one gauge?
- IAT Wiring Question for gsr swap
- Car has blown headgasket....getting it to a shop?
- 150 to 200hp
- B16 help please!!
- Lightest B-series cam gears
- 440cc injectors too small
- head gasket
- discount lighting kit
- Any experienced hondata users?
- wat kinda a/c bracket are from a gsr?
- Will the coil from a D16Y8 distributor work in a D16Z6 distributor?
- Distributor question (modification?)
- Will stock GSR TB fit AEBS IM?
- D16A6 coolant temp fittings
- need to know where r located clutch cylinder
- Are ARP Head Studs needed for High Compression LS/VTEC ???
- how many teeths on a b16a2 timing belt.?
- how do you find out what all the shit on the AFC is supposed to be for? what is NE-V point etc.?
- How to tell how much bar my MAP sensor is?
- i need some help plx civic 1.4 gl 16v (dual carb) fittin twin 40's?
- Hiow to identify Skunk 2 Camshafts
- injen air filter quality
- check compression
- Car not starting. Please look and help if you can.
- turn signal works, but parking light doesnt(92 civic)...HELP!
- Engine builders in MA/RI/CT please help me!
- car is acting weird...thinking fuel pump
- obx lsd
- OBD1 Alternator on OBD0 car
- block deck height differences, B18A/B, B16A, B16B, B18C, B20
- Starting problem, '95 B18c, please help
- Transmission Question
- charging system problem
- anyone running PROSPEED P28 CHIP
- Water got into ballast i think, hid's goes on and off
- over heating problem
- Help me out- Low end bogging
- i need help can some one tell me how to set the timing in a b16 asap
- alternator cable, wire
- Do I need new calipers??
- Manual Shift on an Auto tranny
- Hondata and LM-1???
- b16a1 SiR, why the hell are there TWO 02 sensors on the manifold???!?
- Going state ref. Double check for me please.
- shaving b16 rods
- jdm to usdm ecu swap
- how would I find a wiring short?
- jdm H22A in a Civic EK .. ***THROWING lots of ECU trouble codes***
- honda rebuild DVD, anyone order it before?
- i think my A/C compressor went out while on vacation..........please give input
- VAFC 2 INSTALL
- map sensor n vtec ???????????????
- Car wont rev up!
- High flow cats
- Just installed new slotted rotors...did I do them right???
- eg with b18c1 IAT code
- vtec problem ??????????
- Possible blown headgasket?
- NEW EXHAUST WEIRD SOUND
- Searched already... A/C wires with FTL.
- Thermostat
- Header smokin
- Which tranny is shorter geared? The d16z6 or y8,
- Anyone recognize this bolt? HELP!
- LS transmission gear ratio
- car will not start?
- h22a head onto a h23a?
- Compression gurus check in(Turbo D-series)
- ARP main cap studs
- Just did a compression test and....
