View Full Version : Tech / Misc
- Name this quick release...
- another usual idle prob..
- ls vtec bottom end build
- Anybody know of good shops near ft worth tx?
- Honda powered sand rail
- Ls vtec turbo hellllllp
- Lost Key to 1976 cvcc need help to get it running!!
- Should I get block machined for this?
- mods can you clean up search results?
- Awkward Idle Problem, any help at all would be nice
- GSR starting and running problem?!?!
- does a type r cluster fits on a 99 civic or will i be able t use it any wiring????
- F20B Del Sol CEL 1&9 HELP
- lower control arms
- 93 Ex EJ1 Wont Start!
- Car Intake sounds like vaccum cleaner
- Trouble with H2B CRX...wont start.
- 1989 Honda Accord LX problems
- civic multiplex unit
- Small Dual Exhaust pipes to quiet exhaust vs large one pipe exhaust
- 92 Civic Starting weird, video, any ideas?
- Headers Help
- Window tint supplier?
- p1457
- 08 Civic SI electrical problems?
- 95 civic ex coupe reverse gauges
- 93 Ex Coupe Wiring Problem. HELP!!!
- Simple header question.
- 96 Accord Data Baseline?
- How to achieve this look with an oil cooler?
- f23 to h23a
- G25 to rear wheel drive
- f20b/h22 vss question
- Piston ring orientation
- HELP Bolt extracting
- HELP: IDing skunk2 h22 pro 1 cams
- Camshaft holder/holder plate hole is stripped and enlarged
- Help ASAP Plz New main relay, Solid check engine light, Car not starting
- B16 jumps between 1500 and 2000 rpm @~5-10% throttle
- 1994 integra gsr start up problem
- LS B18 striped bolt hole
- 99 civic 4dr electrical window conversion
- Machining wheels?? How much is safe?
- Catalytic converter compatability
- swapping a B16a from eg sedan to an eg hatch
- Dealer pulling a fast one?
- cylinder #3 detonation
- Heater core
- Console help
- No Start/Backfires
- First B18 EK project
- Check this valve spring compressor out...asking for opinions
- D16z6 oil leak around vtec selonoid/dizzy area
- D16A6 Rocker Pedestal Torque Sequence
- Hasport vs. Noname Motor Mounts?
- rough idle
- Help Car loses power at higher rpm after rebuild
- How to tell if you have a bad fuel filter - striking black gold!
- Low comp pistons
- gutting a catylitic converter
- Stuck in Park -- Removed Deck Lid
- 2.0 Sleeved AEBS GSR ALL MOTOR
- Anti Lock Brake system
- NEED ADVICE
- Piston Question
- 2005 Civic Hybrid - handful of codes; please help.
- Stripped Alternator Bolt Hole
- installed aftermarket steerings, minor horn honk problem.
- did i get 87 octane fuel from an ultra94 pump?
- IACV question
- Speedometer problems??
- low oil pressure 99gsr
- adapting d16y8 vtech head to y7 block
- Can anyone tell me what power im pushing?
- Rhd Type R 4 Door Conversion
- Does my car have an egr valve?
- what parts are usable on a D16a6 with rod knock?
- D16z6 mechanical timing question
- battery and srs light on. electrical issue?
- Replica seat crash pics?
- H23 VTEC NITROUS QUESTIONS
- OBD2 H22 Harness in OBD1 Chassis
- What fuel injectors for a OBD2 to OBD1 Conversion b16
- Help 05 acura mdx rough idle
- Anyone know a good site or place to by manuals.
- Knock sensor orientation?
- delsol cluster question
- 2001 accord engine problem
- oil pressure problem help plz
- vtec solenoid????
- Engine Running Hot When Stopped
- Do you need the ECU for fuel pump to prime??
- 07 Fit alarm light flashing
- Skunk2 cam gears timing marks
- Trojantuning.com - Individual Coil Pack
- Is my ECU damaged?
- Gauges
- hiccups while crusing
- Cell code 16&43
- Help car won't start
- Please help car bogs only when fully acceleration when punching it
- EGR control solenoid for 1995 Civic VX HB
- 2013 6 speed auto fluid level check
- 1992 Honda accord lx
- fuel pump bad?
- 94 civic random shut off while driving, B swapped
- Part on window help.
- New oil dipstick tube.. What's the trick?
- what is the max hp i can make on a stock b16a2 block
- b18a1 crankshaft in b16a2 block
- Double Clutching and Snycromesh
- B series engine guru's, click here.
- h22 COP coil pack?
- Can anyone tell me the material properties of a B series transmission?
- Homelink
- Del sol Wiper cowl?
- buying the right torque wrench
- For all you "What is the best oil for my car?" guys
- Fuel pump wiring.
- Need Help 1997 Civic
- Which Hondata ecu chip is this? HELP*****
- Random vibration
- Integra hesitating to start
- 94 civic Heat not working.please help!
- Unusual TPS problem (looking for flowchart)
- Illumination and speedometer gauge not working
- ITR motor block difference EUDM vs. JDM
- aftermarket cam unmarked????
- stripped head stud
- torque specs
- Bought 2006 Honda Accord EX V6 VTEC
- How to slow down
- Oil pan to strainer distance
- b18 or b16
- Sound-deadening Heat Barrier what do you use?
- full blown dual pump fuel gauge problem help!!!!
- NOOB looking for info
- Dual-Core Radiators in cold weather
- GS-R build help/input/advice
- How much would you pay?
- Sputtering at 3300+ rpm, help please!!!
- honda s 2000
- k20 jetta
- 99 Integra dash harness abs/srs delete
- Help please....
- Lets talk fuel filters. and OEM's quality
- help!! 2.25 exhaust mani to 2.5 exhaust
- Can my electrical cables be the issue?
- 94 Integra ls/v overheated... Engine wasted?
- 89 crx dies at idle
- fuel pump stays priming....
- *NON HONDA* Starter Problems
- No vtec crossover
- Help Identify This Chip
- Question about adding coolant, please help
- HELP!!! Battery Draining FAST. New Alt no fix
- surging motor at any rpm
- 93 Si Hatch Bad Distributor?
- Car turn on and off
- Skunk2 pro 1 cams with brian crower valve springs?
- air temp sensor. help!!!!
- Water coolant level drops quickly
- did couple pulls now tranny wont go in 2nd, 4th, and reverse
- Crankcase bolts smell! Any ideas?
- Another fluctuating idle from a beginner make progress...
- wire tuck issues. cant quite understand?
- D16z6 timing belt replacement need help
- B18c1 98 Civic Hatch Wont Start
- Bearing clearance help!!
- B series best intake/exhaust port dimensions
- How to tell what kind of b series trans I have
- Which Fuel regulator with 2x255L/h?
- 2005 odyseey
- Dynomax Header for B Series
- ECU Pinout for 97 Civic? help please
- A few Skunk2 D Series Intake Manifold Problems/Fixes
- 2005 Honda Element Wont start
- stripped ball joints... help
- Electrical charging Issues 99 Ek Coupe
- Fuel Mileage drop
- Advice on what Honda to buy
- 1997 Honda Accord
- b16a and b16b fuel filters
- cant keep the throttle steady at low speed
- battery draining please help?!?
- 00' prelude obd2-1 distributor issues
- 97 Acura CL 3.0 strange factory radio issue
- 1997 honda accord fuel problem still yet
- Forged piston scratches
- Vendors that carry one piston ring???
- 98' Torneo SIR-T .. VTech and F20b questions ...
- Having problems with 2005 Honda CRV EX Seat belt light/chime. Please assist...
- Weird honda problem!
- dizzy question td42u (yes searched stumped)
- Limp Mode? Bogs at full throttle - B16A2
- Help.. Car runs bad once it warms up
- Vibrant Cat Reviews
- Removing Tubro
- any good performance shops??
- HELP: code 91
- car stall 1st gear
- Build Question
- Integra power steering conversion for my Civic
- Header problems...
- Laptop software
- 98 civic fourdoor power doors conversion problem!!
- 1992 Honda Accord LX
- Broken door panel clip holders
- Brake Pads
- K20 Cyl 4 misfire not due to plugs/coils/injectors. What do?
- 92-95 civic 4dr trunk light not working
- Rebuilt Title
- unknown steering rack in my h22 eg - do you know what it is?!
- Timeing belt Question D15B?
- cluster question
- Traction bar radius rod cluck/creeking
- do i need california or federal ecu ??
- Need help Identifying/solving problem
- Auto radiator for oil cooler?
- crx si harness or non si harness with b18
- Calling Spoon experts - need to determine N1 exhaust authenticity
- How to recognize Drive shaft Level?
- Can't get this plug out
- Problem vtec not kicking in
- piston ring groove, d16z6 motor
- Turns over but no spark or fuel
- no power to fuel pump
- Half Antenna/ Antenna Help!
- HELP 1991 Honda Civic DX hatchback
- Rewiring harness
- installing new pistons in bore TROUBLES
- Autozone or Oreilly Batteries
- 98 honda accord 5 speed/idle low on cold start/idles high when warm
- Need a resource for hood latch cable.
- Tired of playing dukes of hazard.....
- Crx were can i get the plug pins?
- Compression is 185, 170, 170, 210
- D16z6 rattle/tap/knock noise conning from timing belt side of motor
- d16z6 compression numbers
- b16A help
- Help with VTEC solenoid
- Good Type R oil pump?
- After Market Fuel Gauge
- How do I convert auto wire harness to manual?
- Electrical fail- problem
- WHICH HG ON B20B WITH GSR HEAD? PLEASE HELP
- b20swap showing cel code 10
- 86 CRX-Si 16mpg!! help?
- Front Fender Damage...Need Opinions
- Need help with brake diagnostic 1995 H23A
