b16 or b18?
Old Nov 25, 2003 | 07:00 AM
1JDMDOMINICAN's Avatar
Default b16 or b18?
i have a 92 integra wit a b16a 1st gen in it. i was told that i was better off get a b18c in my car, but at the time i didnt have the money for it. anyway, the motor pulls hard, granted it doesnt have the torque of the b18c, would you guys recommend swapping out 2 a b18c or keeping my b16a...a friend of mine told me to keep my motor and swap in CTR cams and pistons, try all-motor 2 see how i like it, if not then turbocharge the car....what would u recomend?
Old Nov 25, 2003 | 11:27 AM
boondockgtr's Avatar
Default Re: b16 or b18? (mugenda6)
you could just get a stroker kit and stroke your engine to 1.8L
Old Nov 25, 2003 | 02:42 PM
vteczone's Avatar
Default Re: b16 or b18? (boondockgtr)
stroker kits is just gonna cost u more than gettin the b18c... get the b18c.u will love the torque
Old Nov 25, 2003 | 03:17 PM
Kendall's Avatar
Both are very capable engines, and each has their strong points. the b16 has a better head, but the b18c has more torque. Instead of replacing the b16, try building it. Go turbo and have all sorts of fun outrunning the b18's.
Old Nov 25, 2003 | 03:55 PM
lazy bum shaughn's Avatar
If you don't mind headaches, build a B20 block. If you don't like the Frankenstein idea, go with a GSR block with CTR pistons.
Old Nov 25, 2003 | 04:45 PM
Lysawy's Avatar
Default Re: b16 or b18? (lazy bum shaughn)
h22 man don't listen to them..!
Old Nov 25, 2003 | 08:15 PM
Rusty Shackleford's Avatar
Default Re: b16 or b18? (Lysawy)
buy a b18a,b, or c shortblock. build it with high comp pistons, then swap the short blocks. youll have a poor mans type r for pretty cheap.
Old Nov 25, 2003 | 08:42 PM
wickedEFguy's Avatar
I would keep the B16 then I bore it to 86MM then install some CTR cams and pistons which will bump your compression to 12.2:1. that should be really fun and you can still run on pump ****. If your worried about cost then you could always buy a turbo kit and that would be just as fun but that's if you do not want to go all motor like I just mentioned with the CTR cams, pistons, and boring to 86MM
Old Nov 26, 2003 | 04:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">h22 man don't listen to them..!
Don't you need custom mounts or something for an H22 to drop in a 90-93 Integra and 88-91 Civic?
Old Nov 26, 2003 | 10:39 AM
bogus_ek's Avatar
with the motor you already have in there... get a gsr bottom end, get some type r pistons... maybe new rods, sleeves. that will cost the least amount of money compared to a different swap, turbo, ls/crvtec, stroker kit, and it will give you that extra torque you want. if you want more displacement... you can always consider boring out before you sleeve. plus you get the best of both worlds... torque from the b18c block, and that good flowing head of the b16.
Old Nov 26, 2003 | 02:08 PM
veganej's Avatar
i personally would go turbo, but depends on what your plans for the car are.
athbaseball23
41
May 6, 2011 04:05 PM
AZNracerx1989
May 13, 2006 08:13 PM
DarkDragon
Mar 15, 2006 07:38 PM
blmracing
Dec 16, 2002 01:37 PM
PIMENTEL
16
Jun 2, 2002 12:54 PM
