View Full Version : Tech / Misc
- Need answer to EX Wiring Harness question?
- Poor mans five lug conversion ???
- JDM PowerBand Problems
- Swap of Japanese internal coil to American External coil distributor
- gauge pods on the pillar
- b18a vs b18b (Short Block Differences )
- is my gsr pulse 1 or pulse 2
- Crank pulley removal
- www.flashoptions.com
- lsd
- ingalls camber kit prob with upper control arm
- common bolts
- 96 itr wheel bearing?
- tips for bolting on a head?
- Fuel pump help
- car stalls while pumping gas
- EG calipers and MC on EF??????
- pisons through bottom?
- p70 ecu?
- Broke a few piston rings....sad story
- Catalyst Sticker?
- What pads to use?
- Got a water leak from behind the cat....why??
- 4-1 JDM header fit a stock civic cat?
- Will rear drum setup from an eg fit on an ef?
- wheel bearing/hub/knuckle?
- AEM EMS Tuning Questions/Problems: Turbo GSR/Civic **Please Help**
- E brake cable Question!
- Help Driver rear sits lower than rest of car!
- Help! Voltage surge!
- Code 43 Lsvtec Sputtering. Limp Mode. Suck Mode.
- ECU
- new Engine in my 90 Civic HB
- Suzuki GSR ITB's?
- I have helpful dumb question.....
- H22 into a CIVIC
- throttle body ? 65 JG edelbrock
- quick question about fried ecu
- Fuel Cell Question? (Searched)
- How to remove stock steering wheel - 90 civic si
- Replaced IACV 3 Times and still getting code 14/CEL
- ECU CODE #2
- Where to Rebuild a 88 CRX Si short block....
- newbie about rims setup???
- when upgrading this can I do that????
- This doesnt belong here....
- Problems after toda cam install
- cranking problem
- modifing a OBD1 diz to OBD2b ?? help
- Skunk2 Adjustable Cam Gear - Help!
- Setting up tach;Custum.
- d16z6 distributor diagram please
- PLease help need A quick wire diagram for wiring a resistor box in del sol
- Exhaust question
- If you had Nankang NS-1 Tires please respond !!!!!!
- fastest way to cut a bolt?
- "dead" spot?
- Virginia performance shops......Performance Direct?? Any good
- close to finishin my b18 project, i need your help!
- what size is mitsubishi mirage blue top injectors
- Mandrel-Bent Exhaust Performance Value? Survey
- will eg exhuast fit on ek?
- is it possible to have my ODB0 pr4 ecu chipped for a dohc vtec ecu?
- How strong is a K20A swap in a 02 Civic (em2)?
- 91 Civic 4dr 190k, dead?! driving and it died...
- How do you read a vin #?
- CEL 14 help
- AEM Pulley size ??
- Valve Lapping
- running on 3 cylinders
- VAFC II: post your settings to compare
- ??? about 94-01 Teg/99-00 Si rear brake components the same?
- Integra brakes on eg, few question.
- help don"t know what to do
- PART # ON A WHITE PLUG?
- Deck Height
- Has your car ever jumped timing 3 times and never damaged anything?
- Throwout Bearing Compatability
- 99 gsr with 96 gsr motor swap problems PLEASE HELP
- Axle replacent Q.
- Cross member were to get it?
- Help Installing/Modifying JDM SRS Momo Steering wheel to fit 95 GSR
- power for the exits
- weird engine noises what can they be?
- Losing Oil Pressure
- Hard Motor Break-In
- catch can and pcv once again
- Anyone with KYB AGX shocks?
- Need oxygen sensor help quick!!
- replacing my struts! ran into a problem i need help asap!
- PCV valve
- b17 vafc tunning ?????
- my computer freezes everytime I try to go onto apexi-usa, can anyone help in writing the wiring diag
- anyone on here have their car flooded with fuel.....
- OPTIMUM compression/octane question
- Steering Wheel shakes when I brake???
- oil rail
- Oil leak?
- disk brake conversion
- sway bars and strut tower braces
- JDM ITR final drive into USDM cable YS1 ???
- I have a few tech questions
- quick driverside mount question!!
- Sleeveing Maching Work
- Whats vehicle is this intake for? (pics inside)
- HEAD SWAP PROBLEM!!!!!!!!!!!!!!!!!
- What kind of OEM bearings do I use?
- 14in tire recommendations
- h22a swap
- ???New SI seats in an Integra/Civic????
- check engine light with obd1 conversion
- blinkers don't flash...
- Clutch Bolt Size b16 vs d16
- Shot peening OEM oil pump gear alternative to Toda?
- Compression test on Hondas
- Choking/lagg b18b
- Hondata fix choking/lag
- Yellow Type R valve cover???
- what does "open deck" mean?
- Turn A/C on..Power drain..what the
- what would be best shocks to invest in??
- Bypassing wather, Closed deck sleeves....
- autometer
- I searched and maybe I didnt search enough!! (B20 Qs)
- 3 inch exhaust for eg?
- new tire question
- is GSR tb better than SI tb ???
- 16X7 or 16X7.5? What do you think?
- How do you tell if a P28 ecu is 5spd or automatic?
- tire mounting cost
- spark plug question
- ecu question
- whats max booost....
- getting fuel and spark but not starting.....
- turboing a choking car?
- hondata tuner needed
- Will this 02 sensor work?
- trans question
- power steering...help!
- What Ohms for fuel level sender??
- Check Engine light. can't check it
- Car Choking?
- B16A1 use B18C-R Cam
- crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable????
- Hondata Tuning help
- Headgasket?
- anyone have pics of tein s on there si
- ls vtec
- just got done with swap.......have a few questions about cel's.......
- Ajustable fpr question
- Help Me - AEM Fuel Rail Obstruction!
- Rev limiter
- Nothing Special, Relay wiring diagram for when using an aftermarket higher current fuel pump...
- ITB's what are the differnce?
- how to test injectors???
- Car Won't start...
- body work
- Swaping OBD2 B18B into OBD1 Civic need help
- 99 civic si b-pipe same as 00 itr?
- Walbro + B&M + Big Cam = Fuel pressure problem? please help
- Automatic to manuel conversion
- Coolant in the little tank!?
- Just dynoed my non-honda: 213whp, 245tq
- First Gen B16a Question
- 4.40 to 4.7 final drive question
- Chipped P28
- Drivetrain ratio's??
- Blown headgasket in under 25 miles.. help *** already searched***
- OBD 0 injectors from a 90-91 ls integra in my OBD1 92 gsr???
- Need some help please...
- Whats the smallest tire size you can put on HX rims?
- Exedy Clutch question
- need ctr cam help!!!
- Welding a dart block? Can it be done
- Loctite on the block? Cleaning threads?
- need help with engine problems!
- Bad CV?
- increasing power with rpms
- 02 sensor placement. no spot for bung!
- Throttle Body Spacers
- shaved cylinder head
- Intake Filters - Top Fuel
- Intake Arm length???? help!
- D16A6 valve specs
- Engine valves, all the same?
- fireing order 91 integra ls b18
- HELP!!! motor revs high at start
- intake manifold
- No cruise control with hondata
- LS Head on a B16 block, i know, dumb idea-BUT I NEED A MOTOR
- Code 20: disabled ELD in ecu and still throws it...
- field's vtec instructions
- Helms Manuals
- How long before gas goes bad?
- Low compression results??
- using Timing light to time '88 Civic hatchback? proper idle advance?
- Installin springs, hard?
- VAFC (APEXi) Tach Question??
- OBD wiring question?!?!
- rod and pinion???!!! dont know whats up please help!!
- Input Shaft Bearing
- diffrence between type-R and GSR Crank shafts
- tools needed for ex front brake swap to 94 dx
- CAr Dies for no reAson/....!!
- mini me swap problems
- Look at my spark plugs
- easy question on how a cable tranny works...and hard question for the tranny experts.
- Offset and wheel bearing life...
- Quick introduction
- ITR 'engine stiffener' on B18A block?
- CEL, weird electrical failure, help!
- torque spec ? for valve cover and studs.
- Kaaz differential wont turn.
- idle problems after tb coolant bypass!!!!
- Distributorless ignition with AEM EMS on an OBD I Honda
- weight of a complete B16 Bottom end
- apexi vtec controller wiring diagrams?????
- Header install questions...
- **I need some help..speedo question**
- What rods and pistons are these??????
- rear mount capability?????? help
- Steeringwheel removal
- Brake Upgrade
- DC header fitment (GSR/B16)
- Diagnostic code help???
- Failed Low Speed emissions... pls help
- Do ceramic brake pads squeek?
- shocks/struts
- What is this wire/hose for?
- Sending back Bilstein struts/shocks?
- head gasket
- heater box removal?
- need tips for modding my 2000accord LX i-4
- HOw hard is it to install valve seals, valves?
- Chipped EDM P30 Ecu?
- crvtec nitrous?
- ls block and gsr block, same hieght?
- Need a turbo install
- H22 swap in 5 months, then motor blows before i pick it up, what do i do? HELP!!!
- CAR DIES out for no reason.......
- straight pipe issues, need help
- NEED HELP with Civic 2000 DX VP modifications!
- S1/YS1 Gear shafts into S80 tranny case????
- removing power steering
- 91 civic hb std - shocks / alignment?
- what brake buster & MS
- Will CTR struts/springs fit 1998 GS-R?
- electrical problem....need help please
- electrical short some where need help !!
- Greddy H22 timing belts
