View Full Version : Tech / Misc
- Honda rev limit
- ecu help *pics
- oil leaking from corner of head/block....
- d15b6 light knock
- WTF? My GSR driver side engine bracket is weird, and can't swap motor
- best fuel cleaner treatment?
- civic si mods
- what cams would you recommend?
- looking for an answer to what happened to my bottom end
- 93 accord ex, gass in tank ? is it normal
- 1993 accord ex , gives jurk when i put parking to drive d4. why is that ? helo
- Honda B18 Oversize Bore Service Limit, 81.25 or toss the block??
- Carfax Please
- Cooling issues-symptoms inside
- What would cause every cylinder to misfire?
- Any online stores to recommend for close ratio gearing
- 2007 honda civic si
- reconmend a good street cam for d16y8?
- port and polish?
- torque specs for drivers side mount bracket/ bseries.
- P/S Pump Problem
- i think i have a bad IAC???
- Civic 06 Sedan FM tuning frequency problem, tunes only odd freq. !!!
- d16z6 into a 91 civic dx
- looking for more power
- ame ems
- Master cylinder fitting help!!.....
- K24a2 (TSX) engine experts: VISUAL differences-'04/'05 vs. '06>newer
- Correct SS Hardlines For Brake Tuck?
- Low Oil Pressure Light on
- Hondata S300 AF atalog display incorrect
- misfire pulling my hair out.
- Auto/Manual Conversion
- NYS inspection quesiton
- grinding into third gear.
- High Idle when WARM B16, Full Details inside.
- Anyone have or know of a good motor rebuild diy?
- Walbro in tank fuel pump question!
- CEL 36
- Missing Syncro in B16 tranny?
- 2006 Si or 2006 600RR
- 36mm vs. 32mm 5 lug bearing question
- rpm matching while shifting/driving
- KA-POWER N1 muffler?
- Removing OEM Diff Bearings
- trans poped out 5th gear
- newb needs help-99 si w/cmas and tuning
- Window keep blowing fuse
- Oil cooler vs Aluminium Radiator??
- d15b2 zc camshaft stage 2
- not starting might be a problem, help !!
- Altering primary cam lobe profiles for high swirl
- Shift fork bearing plugs...trq spec?
- Helping friend. Car wont start. Good Spark, Fuel, Grounds, Battery NO CEL HELP!!
- Solid cel in my civic ..HELPPPPPPP PLEASEEEE!!!!!!
- Transmission problems..syncros or clutch?
- Need info Does a GSR and a B20 oilpan mix match
- help.. throttle body??
- Valve Seal Question
- ectune questions
- 90 crx si tranny problem. clutch is out, but car won't go anywhere!!!!
- Timing Belt Change / Charleston,SC
- Valve cover filter purpose?
- !Help! P30 knock sensor ECU pinout
- ACL ROD BEARINGS
- JDM p30 7k rev limit!?
- Nothing happens when Key is turned to start car
- This is driving me nuts!! Help please!!
- Target AFR's for drag cars?
- CAR RUNS ROUGH AND ALOT OF WHITE SMOKE, HELP PLEASE!
- OBD II code 67
- Extended Oil Drain Analysis: Lab Comparison
- HONDABOND PART NUMBER????
- Wire Color??
- OBD1 knock sensor issue
- pluging in a laptop to my car
- please help car wont start.
- Bad shake 20-40mph
- Are These Authentic Spoon Sports Header?
- b18 non-vtec valve spring compressor?
- *TUNING* Never seen this happen before! HELP! -CROME-
- Air Recirculation Tube on 98 civic ex - AEM V2
- Propylene oxide : Any of you guys know anything about it?
- ENGINE SWAP PROBLEM, HELP PLEASE
- obd2 to obd1 injector clip question *searched
- B18b Compression test results,Need input
- Need help on disk pads?????
- What can caus e my car to start to break up and sputter at high rpms?
- H22 obx lsd install
- Is a jumpy tach a sign of a bad distribuor???
- STRONG GAS SMELL
- 96 hatch with b16..whats wrong with my wire harness..
- Question regarding brake lines?
- best d series cam gear
- Tuning a car for gas mileage
- Tranny Problems......5th & 6th gear issues?
- converting an auto ecu to manual???
- stock 92-95 Civic fuel pump rate
- Piston Hone-Which Type is the best for Honda's?
- ECU/ TPS question
- hondata on ls
- K20A2 Knock Sensor??
- did tranny swap on my 88 crx si d16a6 all new clutch kit & cv's SLIPS WHY
- 14" fan on a stock eg civic radiator, Is it possible?
- New engine smoking
- eg4 brake upgrade using itr brakes
- '99 GSR Tranny: Broken Mount Hole??
- Wierd wideband issue turning off sporadically.......
- oem haedgasket mod
- Replacing Coil and Rotor (DISTIBUTOR)
- flywheel quetion?
- 1997 Civic si sputters then stop if I turn the car off and on again?
- Clutch surface
- ATTN: B Series Transimission Help:!!!!!!!!! No 2nd gear or Reverse
- d15b i NEED HELP
- JG cam install, car wont run now. Getting gas/spark/etc... HELPPPP
- Type r axel back on gsr piping.
- Power to manual steering
- My car dies out when i let the clutch out? Need some help
- MSD Digital DIS-4 for what cars?
- Best oil filter for honda?
- which side skirts for 90 da
- Pulleys
- Gas mileage modifications!
- bad starter???
- looking for a good tuner in the louisiana area
- A/C compressor took a dump...
- Tachometer DIP switch settings?
- Timing belt bolt hole strip....
- install a differential ..
- 1st gen b16a + 99 spec B16a2 inner springs on exhaust + 99 spec B16a2 lma's + PCT cams = ?
- Rods bearings.
- moving the battery to the back of the car a nice and clean way to doit in a 2003 civic si ep3 body
- Vtec water pump question
- Running on 1 cylinder
- Transmission Oil Leak
- Question about sleeved block ?
- How much power do you think I can run>?
- BAR question
- HAVE BEEN ONLINE FOR WEEKS HELP A GUY OUT
- Strengthen B20 block
- Car sluggish & Oil light takes long to go off
- Help identifying rear seats
- eCtune vs. Hondata s200 --> who is using eCtune???
- P28 ecu problem ??
- stock cam shaft on a built head any problems?
- 2 block questions
- head gasket reusable??
- Code 36, JDM P30??
- vacuum routing????
- H22A Fuel Pressure too low???
- greddy e-manage
- Hydrogen Injection ?
- Vtec solenoid?
- Tools For Build
- Billet Aluminum auto-trans flexplate possibility?
- Oil light on but oil pressure ok?????\
- how do you know if the vtec is working on a single cam?
- VTEC PROBLEMS PLEASE HELP
- swap question!!!!!!!
- Don't have time to resurface flywheel. What can I do?
- motor mount question
- Transmission parts interchange
- Car starts up, but immediatly shuts off????
- 99 civic with p0740 code
- gsr alternator b16?
- Need Pro Help w/ My VTEC Problem
- quick question bout busted car
- Which ecu would u use for a H2b swap
- 93 Prelude 4WS revving at idle problem
- PLX M300 wiring question
- help
- rack and pinion question
- Help Please.. Civic Hx
- Tach Hop and Power Cut Out - Please Help!!
- apexi v-afc wiring ?
- Is my Fuel Pressure Gauge (Pic) installation okay?
- Question about ARP stuff
- Engine builders and tuners ???????
- NEED HELP WITH CRX SI HARNESS IN 91 HATCH DX
- OIL LEAK.......NEED HELP FIGURING IT OUT!!!!
- input needed ctr cams in b16a timing idol???????????????
- PLX M300 install question
- b-series tranny for sand rail
- Is there an engine diagnostic scanner for obd0? If not, how do I see what code I'm throwing?
- brakes
- skunk2 Mega Power Exhaust pipe Diameter?? Help!
- how polished??
- B16a/a3 low idle on cold start, Don't have a freakin clue to what's causing it!!!!! HELP!
- Abs light
- Transmission to Engine Bolts
- INJECTOR FLOODING CROME CHIP HELP!
- can someone tell my why my car runs better with the TPS unplugged?
- CVT Help pls
- throtle cable for b18c1
- Advanced PMTR build....need advises...
- Torque Specs ??????????
- Clutch disc thicknesses
- H22 EG mounts.....removing pass mount??
- ECT Gauge?
- P1259 Vtec Malfunction Problem
- camshaft help
- e manage ultimate w/PRofec e-01.
- Intermediate shaft issue.
- Help with my rebuild problems White smoke and #4 dead
- Another Ac question
- best rockers?
- Injector swap questions
- Valve Seals - B16 & B18 - same?
- Can someone identify these three sensors for me please?
- 87 honda accord, no start
- Cant Split the case on my D-series
- Distributor Issues with a B18C, what are my options?
- info please on toda c
- strange tapping sound
- Buying transmission what to look for??
- b18 non-vtec or b16?
- Greddy E-cut (HELP)
- I smell gasoline while I drive. Help! searched
- How to rip DVD's to Mac with HandBrake
- Irratic idle
- B-Series Fuel Rail Interchangablility
- Car wont start.. tried everything, have fuel spark an comp.
- Transmission problem please help!
- honda tach signal specs
- what is the difference between a d15b6 valve and a d16y8 valve?
- D-series trans build ??'s - need experienced help, this is a strange one.
- d16z6 startup problem
- "Reverse" mini-me timing belt issues
- trans problems. suggestions needed.
- 2000 Civic LX died while driving
- Cracked block? just the outside
- pistons pins
- possible transmission problem?
- just put ac belt on and its humming now, is this normal?
- bolt pattern for a b18b block
- D14Z2 tuning
- CEL 17
- wondering if anyone can help with ecu conversion stuff, like pgmfi used to have
- b16a head vs b17 head
- HELP INSTALL VAFC2
- Bottleneck Leak?
- LSD vs non-LSD?
- Ls/GS-r Vtech swap questions
- Electronic Ratio Adapter
- OBD0 B18A1 into EG
- B16a1 horsepower record?
- EK Automatic/Manual Cable tranny swap.
- D15B & D16 VTEC Gasket differences?
