View Full Version : Tech / Misc
- sqealing alternator belt? cant release nut...any tips?
- do i need to reset my ecu?
- nitrous + motor combo need help
- gsr Motor problem need some help
- SOHC P&P Gains????
- Distributer Problems
- CRVtec Header?
- new guy has a Ecu ?
- 94-97 INTEGRA Bomex STYLE COMPLETE KIT need this style hood were can i see som pics from it?
- Starting engine cold vs. warm after ECU reset
- LOOK QUIck Is this the Flywheel Bolts?
- OBD0 ecu codes please
- Help Please Water Dissapearing
- ARP Rod Bolt and Main Stud Install?????
- head work question
- idle surge questions b20 vtec w/ uberdata
- where to get new JDM Honda parts?
- Gtechpro vs. Escort passport G timer
- [[[wanna get another honda]]]
- what could happen by over tightening the clutch pressure plate?
- PCV valve question
- Differences in d series bottom ends? Specs?
- VTEC wiring need help....
- removing secondary butterfly on gsr IM
- What ECU is this ???
- fuel injectors 91 integra will they work??? help!
- Friend with 98 Civic LX and cracked exhaust manifold
- ecu question??????
- what kind of header
- ls/vtec problems
- JRSC overlap on GSR cams\?
- VTEC louder with stock intake??
- Is it Possible to bypass the Crank-Position-Sensor w/ the Crank-Fluctuation-Sensor?
- Battery relocation question.
- is it a blown head gasket?
- help car wont start
- bogging motor please help!!
- Power steering lines question
- Need obd-1 & obd-2 sensor help, people who know the differences between 1 & 2 please help
- Can I use a 00 SI dizzy on a GSR head?
- FLUIDYNE ALUMINUM RADIATOR Fitting Question
- Attn: VA/MD/DC - Anyone know how to install timing belt/cam gears
- Neuspeed Spark Plug Wires Any Good?
- intake mani ?
- Where can I find these fat-ass's weights?
- Installing new clutch - need garage!
- hydrolock scare. weird noises...help
- ECu code: Fuel Supply system
- Tranny Question....
- Snap-on Torque Wrench questions?
- B18c head vs B18c1 head
- D15B (modification suggestions)
- New guy needs help with engine..
- Cleaning Parts
- Recommendations in NJ NYC for suspension places i.e. alignment, toe adjustment, corner weight etc..
- suspension pros... what would you recomend?
- Civic HX Auto Tranny went BAD....NEED HELP...Please!!!
- need help taking off head.i searched.
- what B-series head is the most popular? My company will make the winner!
- NEED HELP AND INFO ON B-SERIES HEADS. MY COMPANY WILL BE CASTING NEW HEADS SOON!!!
- Swapping Jdm B16a
- What half shafts..?
- ecu problem please help
- water in oil?
- B16 Idling Problem
- Ballance or not to ballance PP...that is the question...
- need help on engine specs
- stuck on which clutch to buy
- Bseries tranny decision problem
- Eagle rods question.
- b-series clutches/flywheels interchangable
- Noise from compressor...can I bypass it?
- h22 teg?
- JG cam gears????
- GSR Cam cap bolt measurements
- D15 B V-TEC
- Caliper fitment?
- quick question about piston and rods
- HELP...anyone swap a obd1 motor into your obd2 car?
- Pictures of stock D16 differential - need pictures / technical information!
- symptoms of scratched cylinders.
- HELP!! electical problem on my 92 hatch
- b16a1 help
- ondI into my obdII (swap)???????????
- car keep dying(94 teg distributor on 93 teg)
- check engine light keeps coming on.... ***B18C5-EH2 help please****
- JDM B18C (GSR) matched with what tranny?
- EGR problems with a 95 Accord!~
- anyone knows how to do uberdata in mn or wi?
- «« Water Pump, T-belt, etc...what else do i need/should do? B16 »»
- chamber work?is it necessary
- What kind of fuel in the usa ( RON, PON or MON)
- Quick Caster Question (searched)
- TIMING/ DISTRIBUTOR PROBLEM!!!!! CEL!!!
- Ignition Switch / Push Button Starter.
- please help?
- 90 integra wont start
- need engine opinions...
- Tranny swap for '02 Hx Civic
- look at my gauge cluster harness and help me find the prob
- Anybody here install a skunk2 manifold on a b18c1?
- What should the compression be on a B20b block?
- Need help with ignition...thinking about going DIS
- axle extentions
- 93 Accord Tbelt/Bbelt tension problems
- need help swapping engine and transmission!!!
- Ive got a fuel problem........ hopefully you guys can help!
- Can u have detonation, when running rich?
- anyone tried this DIY oil catch can for a b20vtec?
- sway bar and lower tie bar question
- Is there a way to tell the difference between.............
- Brake Master Cylinder (95 GSR)
- how many plugs are there for usdm 94-01 gauge cluster
- B16A weird problem
- pic request: back of usdm 94-01 gsr gauge cluster
- Gsr spindals!
- USDM P73 ITR ECU?
- Oil pressure gauge hookup on a DOHC ZC?
- help with sensors
- Gas smell from tail pipes on cold starts.
- ?????????????interchanging tranny parts ???????
- b18c1 VTEC Q's
- o2 sensor code
- tranny fluid +clutch
- Ignition coil bench test
- Vtec? or Non?
- Biggest recommended tire size...?
- Integra spindles!
- rods for b18c1 block with ls crank
- 1987 CRX Si Turbo dyno'd!
- Dismantling the valve train
- Pinhole in my radiator.....?????
- Clutch or transmission problem
- Need some clarification on changing lower ball joint
- did I kill my transmission?
- How many miles are BF Goodrich Drag Radial good for.
- WTF is wrong with the CRX ???
- 1st gen vs 2nd gen b16a block
- Solid cel on my chipped p28
- codes 3 14 and 22 throwin help me out guys
- Searched......what's wrong?
- stock gsr + b16 tranny
- replacement headlight bulb for 1999 Civic Si?????????
- figure i'd get a better response in here for this sleeving question
- 91 accord drivability question
- quick question
- Identifying a distibutor..
- D16z6
- LS swap...
- block and head
- a6 pistons and rods in a d15b2?
- Oil Squirters- LS Crank in GSR Block
- synthetic oil question
- SI ECU INTO HX CIVIC
- Overheating.......fan kicks on late, help please
- Help
- my new project car didnt come with a key, what wires to i jump to start it?
- Arias pistons in backwards?
- JDM S1 Input shaft
- Alternator
- hondata s200?
- Determing Master Cylinders - Wilwood Pedal Setup.
- how do my plugs look?rich/lean?
- rev limiter
- Vehicle Speed Sensor and Differential speedo gear question.
- priming oil pressure for first startup
- Good Cheap Clutches?
- LS/VTEC Help
- tach install infomation?
- NEED A AEM EMS TUNER AROUND PA/MD/VA
- ecu codes
- Direct port nitrous on ITB's
- What material for Sleeves
- p72 or p28?????
- Skunk2 Mani on GSR
- Need help from the tranny cracks :-)
- Help with wiring JDM GSD into 93cx (using 92-05 ex/si harness)
- Suggestions on up coming project
- break in questions na b20/vtec w/ uberdata
- Fuel Pressure Dropping?
- Engine rebuilding
- cat-back problem????
- D2 Coilovers...
- price for gearing
- pistons and valves
- loopey idle on warm up (lsvtec)
- DART Block not sealing head gaskets ???
- what cluch to use
- cable vs hydrolic transmission
- scanning a jdm ecu?
- Innovate RPM converter!!
- hondata socketed ecu(p28) can it run stock ?
- How to eliminate rub?
- help!!!
- b16 issues
- Fuel Injectors
- Honda Bearings galore.
- b16a2 swap into eg- QUESTIONS?!?
- Exhaust Question
- home made a/f gauge questions
- Check engine codes
- Backfire or what?
- is this possible>>>?????
- Who makes chipped P28s and chips on this board?
- Almost done legalizing B16, need your help!
- Oil pressure issues.... (tried searching helped a little)
- h22 valve adjustment anyone know the specs
- Wheel Bearing question
- TCU Repair
- What could have caused my p28 to go south???????
- Are there differences in the newer and older GSR cams???
- MagnaFlow muffler...
- OEM vs Mugen vs Spoon - Oil Plan Q's
- HELP w/ AEM uego trying to log w/ RPM's
- sohc final drive clearance issues
- spoon earth ground kit help
- weird CEL, ECU connections?
- I need help bad!!!
- What Manual Steering Rack will Work in My integra DC2 please help!
- Need help with Head Rebuild
- Transmission Question
- Rebuilding a power steering rack that's been converted to manual. What doesn't need to be replaced?
- Trying to rip a chip.
- Sportshift...
- OK.....I know what an ECU is but what does it stand for?
- need help changing brakes on 2000 accord
- Buy a 95' Gsr with 176k mi?
- different car...
- Determining if ECU is 5 spd or auto?
- Transmission noise?
- Parts cleaner solution recommendations?
- Guys Please help me out !! The fuse just won't stop blowing!
- IACV Problems!! (Searched)
- LS/Vtec mount question
- mini me swap questions
- wideband o2
- Oil Pan interchangebility?
- what size throttle body?
- VSS (Again! PLEASE HELP!)
- Oil Viscocity??
- 94 Del Sol Vtec dhoc. Hard to start, random misses at idle, hesitation when opening throttle
- Oil Pan Still leaking!!!!
- universal cat
- Blinker will not work in 03 civic
- what cams are these?...yes i did search......
- What size is my pistons?
- ABS Fuse
- Apex-i V-AFC or FEILD v_afc???
- Anyone know how to get ahold of Apexi?
- making a gauge list need peps 2 cents.....
