View Full Version : Tech / Misc
- VAFC tuning, what are the basics?
- LS dipstick longer than B16?
- How do i test my distributer... DOHC external coil..
- horn problems please help asap
- Someone I need some advice/input!!
- what do u guys think of my B20 setup
- help please with idling
- steering whell question!
- could someone post a pic of their proportioning valve (4wheel disk).
- muffler hanging too low?
- work involved in installing aftermarket cam gears on stock cams?
- man WTF... CEL light is on.. cant get it to blink
- Redline MT90 ok for `93 Accord?
- Should I port/polish intake manifold?
- valve adjusting method
- car shakes when first started up...........
- quick valve lash Q
- Rear motor mount firewall clearance
- obdII to obdI
- Dyno plot hump at 4500 rpm
- Help with MSD 2Step Module (See Pic)
- Tuning S-AFC
- Windshield Wipers w/washer??
- Axle question
- Info regarding catalytic convertor
- Generic OBD1 to OBD2 Harnesses: Do they work? Are they worth it?
- difference in ride quality between H&R and Neuspeed sports
- How do I read this Toe Spec (Alignment)?
- B20
- How can I use OBD2 ECU in OBD1 chassis?
- Fuel rail question (b-series)
- B16a valve springs and retainers
- O2 C.E.L on ny help, OBD2
- OMP Road&Sport brake pads - experiences???
- All b-series oil pans compatible?
- Does anyone know if you get b18c5 motor swap...
- estimated power gains
- problems with windshield wiper.........
- 92-93 Integra PR4 ECU is OBD-1 and should work with B20b right??
- is the b20a5 in the preludes an open or closed deck
- Need some help... VAFC hack and now the car runs like shit
- D17 Engine Management question
- Recommend NRG to any one in NYC who needs hondata tuning....
- gsr, not lsvtec??
- OBD2 version 2 p72 HELP ME intake manifold
- msd 6al
- DYNO: B16 cams vs. GSR cams
- 12.5lb or 8.5lb flywheel?
- What are the differences between OBDIIa and OBDIIb?
- Turbo for a JDM Sohc ZC.......
- Crazy Idea..........Turbo Questions.............
- what did i do wrong
- Will a wiring harness from an AUTOMATIC car, work on a manual one?
- Motor Mount Measurements
- B16B Engine Assembly into a b18-b20?? Pros and Cons
- Who has experience with making speedy F23's? Anyone?
- dose any body make a final drive kit for a b series cable tranny??
- wtf did i get the wrong pins?
- What does 'intialize' on an S-AFC do?
- Exhaust cut-out in bumper...Any Advice or suggestions?
- Need a picture of a GSR Block (Helms manual picture)!!! Please Help!!!
- how should i adjust my timing for nos
- Did valve adjustment now idles wierd... HELP!!
- VTEC and Turbochargers
- 3 ECU's w/ Mostly Stock B16A3
- 90 Civic DX Electrical Help
- Is a 92 Integra OBD0?
- 93 si injectors/fuel rail/intake manifold on a 94 cx?
- sometimes i cant get back into first gear.
- Looking for B18c1 cylinder head
- ITR to EK?
- 98 civic lx header
- HELP!!! Question I just dropped a b18b1 into hatch it idle's at 2000 rpm whats up
- i have a b16 a1 engine and lsd tranny in my 1991 civic
- JDM P13 Speed limiter
- What are some of the best ways to beef up a 97 civic engine without swapping
- D-17 Crank into a D-16
- i have a oil leak in my b16a1 engine
- i have a b16 a1 engine and i have a leak by my vtech selenoid im not sure if its that or from the mo
- Consequences of driving a car with the thermostat stuck open?
- difference between b20 and b18
- b16a swap 4 my 4dr integra
- i got a autogauge tachometer in my 1991 hond civic hatchback
- act flywheels prolite vs streetlite
- check engine code #18????
- OT: Buzzing from Brake MC area when braking??
- what should i get??
- Is the Digital MSD SCI+ worth it?
- headgasket leak
- OT: should we run out and buy gas?
- Recommend cat converter for my application.
- why are electric fuel pressure gauges so damn expensive!?
- old shcool rsm apexi extra wires
- Piston Rings
- help with piston ring size
- Can you put a Type R LSD in a s4 case?
- d15b2 + si head? what do you guys think...
- S1/J1 tranny mated with a LS b18?
- 4.785 Final Drive with LS 5th in 2000 GSR
- why my car wont start....
- micropolishing the crank
- Can you chip a non vetc ecu to a vtec ecu?
- check out this cam review!!!!!!
- where to install in line fp guage
- Anyone remove there Climate Control from a 96-00 Civic? I have to change a Bulb.
- 94 teg dash in a 2nd gen??
- Symptoms when timing belt jumps teeth?
- H&R 15mm wheel spacers...
- What are these holes for on a B18A???
- quick ? bout spring rate for dd
- does anyone know a good alinghment shop in LA area
- oil guage
- Boost and WS?
- Jun valvetrain w/Skunk2 stage 2 cams????
- ? regarding CTR pistons
- flywheel
- Need Help with rim!!!!!!
- stalling after startup
- what spark plugs should i use for nos?
- cant tune jimfab ?
- what cams are better???
- Code 13 ( Barrometric Pressure ) ??????? Whats the reason?
- need input on this tranny
- To members with SMSP cat. converter...
- what causes bump steer?
- why wont my car start? =(
- Code 10, help will be greatly appreciated!!
- Are D-series and B-Series alternator pulleys interchangeable.
- strut bar
- Best place to get rebuilt Accord auto trans
- B20 into EK wiring woes part 2: B20 distributor connector plug into stock '96 EK harness?
- Engine flow rate???
- B20 into EK wiring woes: OBDI ecus look for crank fluctuation sensor?
- Crank pulley tool for 88-91 engines??? 92-95 size the same?
- Headgasket/idle problems......HELP!!!!
- Oil on my spark plugs - Is this bad?
- ITR intake cam only or intake and exhaust cams ?
- crimping??
- Injector Questions???
- the search for the no where to be found vacuum fitting.help
- disabling Apexi VAFC?
- obd0 to obd1 wireing
- tokico Illumina shock/coilover noises...
- Installing Apexi Power Intake
- Clutch help.
- Front spindle/hub question
- Web Internals??
- OEM Piston selection.. need input
- which transmission for a turbo ls?
- Whats ur opinion on cusco roll cages
- Idle problem, need help!
- apexi rev/speed vs g-tech...question for apexi r/s owners
- Cv Shaft Install help
- OT:...... what do you think of MAZDA cars/motors
- What ring gap do I want ?
- rotor and cap for b16b?
- Shocks
- When i try to start my car it makes a rapid clicking sound why wont it start
- About to do my first strut replacement...
- Testing obd1 ecu with convertion harness
- how to install DSM 450's
- H22a4 Throttle body on 97LS
- h22 swap INFO
- Question for DA people!
- will jdm swap in civic pass smog in MD?
- ES Master Bushing Kit Installation on an Integra (DC2)
- does anyone have infomation on the honda V8
- B18c1 crank in b20???
- Broken Knock Senor (Help)
- I need intermediate shaft and axles for b16
- Skunk2 intake manifold question, please help
- Are all B Series Axles Identical? Need Help.
- 205's or 195's?
- i need help on a camber question
- How to mount AEM AFPR w/ JE intake?
- are all OEM o2 sensors interchangeable?
- EXOspeed motors, any good?
- Check engine light after 160kmh???
- Installing Hyper Ground Wires type-s for 5g Lude
- Jdm Itr Cat
- Suspension/Coilovers Where and What to buy?
- A'PEXi WS exhaust
- Newbie Suspension question...................
- b16A2 with type r cams, aem cam gears, type r manifold dyno @ 109HP??? I need Help!
- Installing Nitrous Express Questions!!!!!!!
- easy way to lean car out??
- HELP!!!! need swap help asap ...
- question for pro engine builders
- degreeing jun 3 cams
- No reverse w/ 99 si tranny
- Exposed cam gears/timing belt. Bad in the long run?
- gonna do my B16 swap soon, and I got a Q.
- Noisy valvetrain soon after adjustment..
- ITR springs question
- Puck style clutch for daily driving??
- JASMA header
- will jdm pass smog in MD?
- in car DYNO?
- Brake problems
- has anyone ever had any experience with...
- How do you polish an intake manifold?
- No Vtec in 3rd Gear
- What axles for B20 w/ GSR tranny in 4th gen Teg
- is a type r strut bar able to be fitted onto a da (90-93) integ
- vtech solenoid, gsr vs. si??
- JDM Header on a b16a
- how do you know what cars will get a SMOG ONLY STATION smog check?
- Profec B took a shit!!!!! HELP PLEASE!
- D16y7 TB to D16y8 TB
- help with wiring headlight buzzer!@
- Is there a certain way that you have to apply fog-x?
- aftermarket muflers
- My rota Paint sucks
- My skunk2 titanium retainers.
- Legality of stripping the interior of a pre airbag car
- need help asap going nuts
- cam gear instalation question..
- Bolts for Engine Stand
- msd wiring instructions???
- Dust boot on strut with Skunk2 coilovers?
- Wheel balancing eights
- GSR cluster HELP.........................asap
- Who has the TWM short shifter?
- Adjusting coilovers so each wheel is even
- ..... sohc TDC .....
- trouble under load? Please help!
- Piston to wall tolerance?
- what a difference....
- Will a B16A2 distributor work on a obd2 ls
- Oil Pan Drain Plug
- Quaife/Carrier bearing install, how-to?
- A DIFFERENT CTR piston in B16 question (I promise!).
- building a block for boost
- Which tires to get for 17 inche wheels 205/40/17's
- hi flow fuel pump question
- Building N/A block project... 2.0 b16 or b18c
- Suspension Techniques
- Vtec kicking in to early.
- ****Extrude Hone***
- Head milled 35thou,which head gasket????
- Voltage slightly drops during idle
- proportioning valve
- need help
- engine wont start...
- all spoon accord+h22a= will beat what...????
- 91 hatch w/ 94+ GSR rear suspension???? Will it work???
- Best brake disc
- Skunk2 cam install then the OIl LEAK After math HELP!!!!!
- b16 head ?
- Getting an alignment... some questions.
