View Full Version : Tech / Misc
- Forcing/Maintaining Open Loop Operation
- tuning tips for 90-93LS
- Stupid Question - Automatic Tranny Fluid Dipstick?
- Honda Help Needed With ABS!!!
- engine swap
- transmission in 1997 cl 3.0 acting up.
- engine trouble
- Would the engine idle real low and have slow pick up with a bad tps?
- Integra stumbles off the line????????
- low oil pressure, full oil, too thick?
- what causes code 22.
- main relay
- My compression test resluts on my B18c3
- Hardwiring the walbro 255 ????
- power problem, 2k revlimit, and no light on s200b???
- Spring Compressor Does Not Fit
- ys1 gsr rebuilt? DIY?
- Exhaust-smelling Fumes Coming From Radiator Cap - Need Opinions ASAP!
- ES LCA Bushing Part number?
- A simple yes or no will suffice...
- B series oil pan gasket number
- About to do GC/Koni install - have some questions from those that did it themselves!
- help!!
- B18C into EJ1 with minor problems. (searched)
- tdc...should i try to fix this?
- Tranny question for my B18B1 swap
- my temp gauge got me stoned
- IM port polishing truth
- Best Brake Pads?
- RHD Conversion
- fractured water jacket...wtf
- b16a2 problem
- HEPL ME URGENT B16 HEAD IN B20 BLOCK
- What Cams fit in a B20??
- blown head gasket?
- VAFC+SAFC questions Injectors anyone?
- vafc question
- timing
- What speed sensor will i need for a b16 cable tranny?
- HELP B18 won't start and smoke come out of the intake
- ATTS Breather hose
- civic 96 weight reduction
- B16 timing help
- Installing an MSD SCI w/ external coil
- fuel pressure too high?
- Car bogging..smells like gas when i get out
- Full cat-bck vs. Universal muffler
- Need help w/ GE oil adapter plate (OE oil filter fitting won't come out of the block)
- Stock flywheel weight
- obd1 ls ecu for lsvtec??
- B20 / B16 A2 head how it work
- How many more CFM's should a PnPed head flow?
- CTR pistons w/b16 rods into a GSR?
- Which distributor to use???
- Tuning after compression and displacement change
- Injector problem
- PR3-J51 ECU Questions
- No vtec, code 22.
- Is this catch can setup possible?? (pic inside)
- quick compression and leakdown tests question
- Chapping noise from under rocker cover.
- Cruise control mod. Vtec controller manual?
- cracked radiator anyone have any idea why?
- Any shocks available for the 2003 Civic 4dr LX???
- N.O.S. bottle opener instructions?
- Can an Alternator kill the car?
- b20 eagle rods w/ arp 2000 bolts, torque spec??????
- rebuild shocks
- HELP!! Skunk2 coilover height adjustment....
- Tranny Shop In Nor Cal?
- is a girdle really really needed???
- Wiring Problem
- how to 2layer gasket?
- help: strange clunking type noise from engine
- Tranny fluid gone BLACK?
- B16 turbo problem
- Code 15: Ignition Output Signal
- Engine MisFiring 1 2 3
- anyone know of a nice wheel with 44mm offset for a good price?
- Cleaner from Stop-N-Steal
- clunking sound - bushes?
- Engine Cleaners
- H.I.D. problem
- All 4 injectors are locked open and motor filled up w/ fuel
- Shift Linkage Broke In Transport......
- Failed Emissions Need Help Experts!!
- Could I reverse the heater/air fan to suck through the vents instead?
- oil pressure from breather filter
- Running a little rich?
- Got a D16X6 and need some experienced input
- 1990 civic b16 swap help
- help! my car doesnt start when theres warm/hot weather!
- Apexi repair?
- Sources for rebuilt axles?
- SAFC VS. VAFC
- ITR/GSR diff in H22 transmission?
- Has any one seen a standard header that looks like this?????
- Looking for Forged PCT PISTONS
- steering box
- B18a1
- tranny shims
- ls crank into gsr block...which main bearing?
- RS machine
- B20 Info
- Burnt(really) obd1 p72 ecu (pics included) Please tell me if this can be fixed
- walbro pickup filter question......urgent
- No VTEC and oil light flickers on/off
- LEXAN PRICE
- block gridle install???
- do i need to Replace head gasket?
- Im stuck and dont know what to do
- B16 swap has me stumped . Gloing cat ?? No over 3000k
- Where do I hook up the water temp gauge ???
- how hard
- is my ecu broken?
- Oil change... no smoke, no nothing... Less than 2 quarts !!!
- my car cranks and cranks, but wont start... i need help!!
- Torque for head bolts????
- Air Fuel Gauge - Possible to Wire Directly to ECU?
- crank fluctuation sensor
- why would you need to balance your crank when you rebuild your motor?
- Miss fire problems! help!
- I need tunning advice for B20/vtec
- transmission info
- H22 Valve Adjustment
- Change 5th gear in a JDM Gearbox?
- Bucking CRX
- Strange timing problem.....HELP!
- how to get 400HP +
- ARP studs on a d16y8
- b16a2 motor swap in ek9...
- Technical question/discussion - How does a wideband work?
- Car keeps poping out of gear
- quik ecu/chip Qs
- !!Brakes Vibrating Badly!!
- B18B1/B20 cams - same or different?
- block gridle???
- speedometer help..
- B16a1 Vs B16a2 Differances in block? and wiring A1 for OBD2
- Overheating Guide. Hope this helps.
- Axel probs
- where can i find oil line kits for a ls-vtec
- hey a lil help hesitation
- obd1 motor in a obd2 car
- A/F Ratio Gauge Suggestions
- CHROMING A VALVE COVER....
- Winding/whining noise
- car vibrates really bad when stopped
- new set up> for my 95 coupe
- Has anyone dyno'd a CTR exhaust manifold?
- need some pics
- looking for crome info
- !!!Frame Damage!!!
- Trouble on the car, pls help..
- Oil pan bolt question....HELP
- How does this happen (HELP)
- Intake
- Coolant Temp problem
- car bogs after 7k
- OBD2 and afc
- Tranny help!!!!!!!!!!
- Functional Key Lock Hood Pins?????
- Setting up climate with dash conversion
- Please confirm crankshaft pulley bolt torque (link inside)
- eliminating power steering....
- Type-R tranny guts in GSR case?
- Lost to a CHEVY SS by 1/4 of a car rematch next week.......
- Engine question
- what are the largest injectors you can use with an obd2 ecu and vafc?
- ENGINE KNOCKING!!!!!!!!! FAWK
- '97 Accord EX 4 cylinder timing belt and water pump procedure?
- h22 vs k20
- engine question. need help!
- Suspension question?
- Distributor: OBD2 --> OBD1
- Want to do a swap but HELP IS NEEDED
- SKUNK2 S2's VS My stock EK9 CTR Cams
- High Idle after wreck, but no CEL's...
- tuning issue?
- Bearing and Seal Kit (tranny)
- Distributor Question?
- Suspension noise, not squeeking but knocking. Shocks or bushings?
- Remember to change your fuel filter!
- Transmission identification help please!
- runnig problem
- Throttle Body Mounting
- big problem!!!!I NEED HELP
- gas mileage
- is my shiftlankage upside down
- Brake Problem??
- Suspension help
- Timing belt shredded! HELP!
- HELP: Cam gear removal
- air/fuel gauge
- ** INstalled LSD in a GSR and now the Axel won't go In anymore ** Oil leak
- compression problem
- What is the correct gauge wire?
- Engine Check light
- Change from Honda oil to other ?
- HELP COOLANT LEAK
- ACT CLUTCH Problem
- Skunk2/Mugen Wierd Timing Hump
- `Coupla Qs re: reman CV axle swap`
- All wheel drive
- HELLP!! DISC BRAKE CONVERSION ON CX
- Brake bleeding problem
- Cable Trans Syncros vs. Hydro Trans. Syncros
- Wierd Knocking In GF's '94 Civic DX?
- b20 vtec b16
- throttle body spacers
- B16 Idle Problem
- Heater and/or blower motor suggestions needed!
- Single point injection into multi point?
- Exedy Clutch
- EG GSR swap NO SPARK WTF?
- Hondata Q??? Helps Guys
- idol funny
- safety concerns with my car
- What does it mean by BLUEPRINTING
- Different between Peak & hold Injectors and saturated injectors
- Changing shocks, but what about springs?
- gsr block with ls crank... which rods?
- NEW PROJECT! NEED HELP FROM THE PROS
- tach install snags???
- engine problem help!
- Trailing arms on EF rear disk conversion?
- Air Bypass Valve
- How 2 Manage an N/A and Nitrous Setup? *Fawking Detailed*
- d16y8 intake manifold
- What's the best engine oil for Honda's VTEC engines ?
- Need Opinion On Tires!!!!!!!!
- Necessary to bore???
- help with modding, going for all motor
- Compression?
- where do the two vac hoses go after doing the multi point swap
- very odd misfiring problem help!
- Car wont turn off, totally stumped
- Crower 404 Cams *HELP*
- amp draw -- "1G" fuse under hood.
- B20 or B18 LS/V?
- Can someone explain "larger valves"
- Arias pistons on B series?
- magnet crank trigger
- Strange Clicking/Fluttering/Tapping Sound... HELP!!!
- Who Can Give Me a Compression Ratio? COMPLICATED
- Somethings Binding! *HELP*
- Little Red: My project car (lots of pics)
- d16y7 into a 94dx EG??? Which engine harness? ob2 or obd1?
- Throttle body query
- ROD TO STROKE and autocross
