View Full Version : Tech / Misc
- itb's on a d series??
- d series mounts...
- trouble starting in morn.
- Type R Cable Tranny for CRX?
- Fuel Rail Noise?!?
- Question on gsr sleeves?
- HELP WITH A DISTRIBUTOR NOISE 90 CRX
- oil change question....
- Brembo does not make cross drilled + slotted rotors....
- Complete Y7 block and head ...and either Y8 or Z6 vtec head needed to id
- advance cam gears would technically advance timing degree?
- problems repainting valve cover
- Does Crank Sensor affect VTEC?
- Hesitation problem..Can't figure it out.
- Clearance Issues
- CRX instrument cluster wiring
- Weird B18C1 engine noise
- RPM Bounce/Drop
- feb. 2005 issue of honda tuning magazine
- Automatic transmission slipping, hard shifter
- Cam line bore
- cam gear / valve adjustment question - decked block
- 90 crx door panels
- Important clutch question
- MSD 3bar MS work with uberdata
- i will pay for somone to tune my car
- my car keeps makin a horrible grouning sound :(
- Intake accessories - where can i get em?
- Most useful socket set for working on Hondas
- 97 ex, horrid gas mileage
- wat diffrent wif ek9 ecu n eg6 ecu ??
- LSD Install, What Parts To Replace
- Tranny prob or not? please help
- Intermediate shaft wont bolt up!
- Starting issues... I need some insight
- GSR tranny problem
- b16 new
- looking for a good JDM B16A OBDII 99-00
- having a little trouble
- questions on gsr build up? please help!
- OBX 5.5qt oil pan
- setting my ECU up for datalogging
- governor for civic si 03
- Alright... is it just me or is this weird wear for a rod bearing?
- Where can i find 16awg SHIELDED wire? (for o2, distributor) porn!!1-->
- compression ratio
- 91 vs 92 b18a block differences
- Help Engine Problem Well.. kind of
- LOST MOTION ASSEMBLES LMA'S!!???!!!???!!??!?
- can't get o2 sensor out
- Can anyone identify these sleeves. Picture.
- Question about cold engine warmup
- **CALLING ALL ECU GURUS**
- Brake Light and Brake Fluid Flush Question
- b16 timing belt help
- Best pistons and rods for boosted F22
- Exhaust/Intake valve seals.
- having crank welded up???
- JDMDOHCPOWER EBAY STORE BEWARE!
- GSR WONT START
- new rings in stock b18a
- Quick Question... What sensor is this?
- NEVER DRINK AND DRIVE
- Brake fluid question for random idea of mine
- vtech head swap?
- fuel pressure
- ATS final drive, strange sound
- Fuel rail problems, need help ASAP
- Going to pik up part in 5 minutes...need answer asap!!!
- car runs like garbage
- ?? Piston Dome Displacement of USDM B18C5 Piston (P73-A0) ??
- obd2 - does it really negate your mods?
- Valve seal replacement Question, honest answers
- Help! missing bolt on valve cover?
- throttle body gasket
- Is there anyway to check if your wristpins are good?
- Alternator Question...
- Local Mech needed
- Possible to reassemble tranny w/o clutch allignment tool?
- Purge contril soliniod for B18C1
- 99-00ex with b16a2 Distributor Wiring
- Transmission help
- NOS kits (dry) not to sure ?
- Need some insight on a leak I have going..
- Tuning questions with Crome/Uberdata/BRE
- help wixh axle install
- v-tec solenoid
- getting ready to hot tank
- balancer on axle?
- Q about 4x114 typr conversion.. Parts specifically..
- CAR WON'T START!!! STARTER PROBLEM?
- ABS & k20 swap
- Need some help...please
- LS/VTEC Do I use B16 crank pully or ls crank pully? Please Help!!
- p30?
- How to tell
- Switching B16A block to a B16A2 block... Rear block problem..
- how often do you change your oil drain bolt washer ???
- B18c1 Stock Valve Springs
- bearing part number question
- Got some maintance done BG induction service and valve adjustment
- apexi turbo timer/wideband
- obd0 to obd1 question
- WTK : ECU QUESTION
- Universal Bosch wideband oxygen sensor connected to Apexi turbo timer. accurate??
- I need help and or advice
- HOW-TO: convert the OEM fuel feed hard line to braided flex line for AN fittings
- removing abs in my eg coupe EX
- Transmission help needed. Tranny pro's please take a look.
- SOHC vtec heads
- Alright you techer bastards, figure this crank out.
- Flip over your JDM b-series valve cover
- flex pipe
- my car keeps shutting off
- Need Help with 1st gen b16 head setup,Buddy club spec 3?
- B18 water pump GPM spec?
- skunk2 stage 3 valve lash specs
- HELP, What axels to use, i need to buy new ones EF b16
- Burn the ECU
- Too much oil??
- Taking crank pulley bolt off with the motor out...
- jdm dc2 headlight/foglight question need help
- hawker odyssey pc 680
- P30s or P73s?
- VALVE SPRING COMPRESSOR FOR HONDA/ACURA
- help cars sputtering and idles bouncing
- Imobilizer swap?
- Check Engine Light???
- SOHC VTEC ?'s
- CEL CODE 43 did a search still need input
- ECM engine temp protection
- whats the tecnical name of this exhaust section?
- changing valvesprings
- Swapping B16A block to B16A2.... Will I run into any problems?
- Deshrouded combustion chamber??
- anyone tryed one of these? just as good as hondata?
- Mounts Ej8 > Em1 Help
- DC2R - Noise at 5000rpm Approx.. Help.
- Speedo Problems
- short shifter ?'s....
- advantages of obd1?
- displacement on demand . . .
- head stud question
- Suggestions for rebuilding B18 for 200 whp?
- jdm info
- looking to get lsd for my delsol b16 tranny.. which is good.
- #3 cyl
- o2 sensor
- Help I do not know what is going on with my b16 Tranny!
- CRX FRONT END CONVERSION ON 91 HATCH...HELPPPP PLEASEEE!!
- removing hondata blue box as a theft deterrent?
- Does a Carsound Hi-Flow Cat Dampen Sound AND kill power?
- 1.7 gsr block..question..
- Crankcase evacuation question-- OBD2 LS/Vtec PCV system??? I need help!!!!!
- ITB tools plugin for Crome
- D15b8 crank pully on d16y8 block..
- Honda MSDS Material Data Safety Sheets
- VAFC AND TPS QUESTION!?????
- Built GSR motor, NEED HELP ASAP.
- data cable
- AEM fuel rail
- Hows this look for the center crankshaft bearing?
- Bought a new PCV valve and....... look!!!!!
- Hondata S200 Question
- P30 in a GSR?
- what is a good program for my p30???
- repeated failure of ignition coil on 97 Civic LX
- car wont start
- 96 GSR motor going into 97 Non-vtec RS??? Need help
- Hondata
- Drag launch?
- bodykit
- engine tools
- Question?? Ls block
- how do i remove my dash?
- Tuner Toys rods only good for 8000rpm?
- B series Secondary O2 sensor work on a D series?
- Installed Walbro 255 HP pump and it raised my idle
- Help Identify these cams
- Apexi V-AFC Install Help for 90' RHD Civic SiR (EF9)
- injector q. need some help
- Here We Go: Idle Problem, Searched, Tried Fixes, Details Inside
- GM 3 bar map sensor and AEM standalone issue
- Questiong about JDM GSR LSD
- B16A REBUILD?? WUT ELSE DO I NEED...PLZ HELP..
- Piston Rings...Just a Question...PLZ HELP!
- WTF!!!! 89 CIIVIC HATCH WONT START...
- Stock lsd differential
- Anyone know of a cheap fuel pump to use with a fuel cell?
- swap trans, now slight grind when clutch is depressed
- rod knock..
- do i have an air leak? please help!
- Where to get a cheap block to practice on?
- Engine Compression/ ratio????
- A.T.I DAMPNER?
- Car doesnt accelerate as fast when vtec kicks in ?
- Effects of O2 reading by increased overlap or "blowthrough"
- dizzy?
- exhaust recomendations?
- Aftermarket retainers locks?
- Trouble with OBD1-OBD2 ECM
- Help... I want an Intake Manifold...What's best for B16?
- type r throttle body
- CRV Clutch 4wd?
- YOU HAVE $$$5000$$$ WHAT IS THE FIRST mods you shud do TO UR RIDE !!!!!!
- Exhaust
- Dead Battery In My Prelude....Why?
- ATTN EXEDY Clutch owners!!!!!!!!
- k series tranny help
- D15B EK3 MODS (performance parts wanted
- poorman type r
- Vtech controller on d series
- Idle screw all the way closed, still not 450 +/- 50
- What Wire?
- cable clutch/pressure plate.....same as hydro?????
- D16A6 Automatic? i put the last thread in the wrong place
- can i put my 92 ls ys1 fifth gear in 91 jdm b16 s1 tranny?????
- d15b JDM problem install? PLease help quick
- rev change holder question.
- ELD (ELECTRONIC LOAD DECTECTOR)
- Can you use forged pistons on factory B-series rods?
- lsvtec compression ratio question
- jc whitney 150 cell cat
- Oil Pressure Light On?
- 91 integra will not rev over 3500 rpms...help
- WHAT FUEL SYSTEM FOR NOS SETUP (200 SHOT) direct port.
- alt/mph fuse keeps blowing?can't find short.
- HELP!!!can anyone read wiring diagrams?
- FASTEST 3.2 V6 CL, TL TRANNY INSTALL
- need help
- pros cons of a b16 84mm and 89mm crank
- Does a decked block affect my timing?
- BHP vs £ which mods are worth it?
- ACT 4-puck questions
- Brake Disc Upgrade question?
- AEM, Apexi??
- Si tach in EX cluster?
- HELP Intake mani question
- put head on , now what?
- Moroso Oil pan and OEM Honda Oil Pan same height?
- problem after a/c install
- just swaped a b18 into my 95' hatch,and it's f@#!ing slower then the stock engine.
- Is it ok to use LS water pump in GSR?
- Need help ASAP, headgasket question!
- CKF harness bracket placement
- Plug my oil squirters or modify them? B18c1 Problem with Wiseco Pistons
- stock radio help
- 04 civic coupe swap k20 r
- West-coast Turbo products???
- quick question: are 92-95 front knuckles the same as 96-00????
