Water temp gauge install
Munkyw3rkz.webs.com
ok i did search around but i want to clear it up.
i want to see how people here have installed their Elec water temps on a B18C1.
There are multiple ways to install one of these, but I tee'd off one of my coolant lines with a brass tee that fit the sender inside and did it that way. You can also take the thermostat housing and place the sender in there as well.
Going through the same situation but with a B16. I figured that in order to get the most accurate temp reading, would be to install the sender on the upper radiator hose. But doing that is a bit tricky. So im thinking of putting a Tee where the stock temp sender goes and place the other sender with it. Would anyone happen to know the tread size of the stock ECT sender? Thanx
H4CRXSi
Apr 8, 2007 08:26 PM
monicle
May 27, 2003 10:41 AM
