View Full Version : Tech / Misc
- RSX clutch master cylinder ratio?
- what size socket for knock sensor?
- obd2-->obd1 conversion can screw up your idle??
- What IACV for a JDM B16A?
- 89 dx block and CLUTCH ,will93 HYDRO tranny bolt on?
- LSD or ITR Tranny?
- will 90-93'integra rear disc assembly work on my eg civic?
- '00 B16 Manifold on 90 B16a1 motor!
- Just replaced tranny, can't get axles in
- obd radar detector link?
- low compression head gasket?
- headgasket r&r
- stock injectors for my setup?
- VAFC malfunction....PLEASE HELP
- carbon fiber hood
- 95 h22 in a 96 accord lx wiring Q?
- GSR motor into EF Hesitates really Bad
- Valve Adjustment Specs
- Merry X-mas All
- Tsudo N1 Catback Exhaust system?
- Toyo Proxes Tires
- d16a1, dohc zc question
- Who has hondata stage 4/chip burner/dyno tunes near chicago????
- Pulling metal chunks from tranny (5 pics)
- why does my b20 idles funny after going OBD1?
- Who uses the Hondata shiftlight?
- shock and spring install
- arp head bolt application
- are all 94-01 clutch the same?
- wiring vtec for my ls/vtec? please help, please?
- best tires??
- what cars distributors can i use on my b16a1
- fuel pressure regulator busted?
- ECU Problem
- ECU problem for a swap
- Ls/vtec build finished now for the problems???
- Help Diagnosing
- Where to buy Hondabond?
- will a 93 hydro tranny work with an 89 SI motor and flywheel and clutch?
- Please Help
- MSD Ignition
- what to do with head
- question about hondata
- Y8 distributor
- Engine Overheating Need Help
- Tach electrical problem
- Anyone here get the VAFC harness from Boomslang?
- B17 in '90 CRX DX. Which cat.?
- Why are my intake ports oily?
- Can I fix it?
- will taking my rear section of my apex ws exhaust during road racing event give me more power
- quick question on full rollcage
- Is the problem my IACV?
- vacume box by battery????
- Fuel rail with out area for stock FPR?
- Number of O2 Sensors on a 96 Blazer?
- SS Brake Lines
- loss Of HP?
- vafc or v-tec computer
- 1990 Honda accord..
- APEXi VAFC vs. VAFC II
- Header... whats the different between a ebay one and a DC sports one?
- VTEC WIRE IS CUT
- jacobs nitrous mastermind help
- Custom exhaust problem,what to do?
- p30 ecu installed. Where characteristically does this ecu run rich and/or lean???
- a stupid question
- Converted to OBD I what scanner do I use. OBD I or II
- HELP....Problem with gsr built turbo eg
- Dash/Console lights going out...if its not a fuse what is it ???
- where does this go (please take time to look
- Whizz sound?
- Rebuilt motor. Should it be consuming oil?
- APEX VTEC CONTROLLER PROBS
- how long can i ride on dead strut...??
- B16 and longer rods
- Springs Help Please!
- what cam gears will work on a zc motor
- dohc head on sohc block
- General timing question
- B16 head better than B18C1? (SI over GSR)
- Another engine choice poll!.. BUT.. i need help PLZ!
- My motor has a very loud tick...
- Longshot - Shore rating for the stock Honda engine mounts.
- Can worn Engine/Tranny mounts cause bad/hard shifting?
- Brake/Vacuum issue
- WTF is uberdata?
- started car and idled funny...
- Variant idle/high idle on my new y8 swap
- problems with cluster guage
- flywheel dust cover install?
- limp mode but no CEL (yet)...
- coolant lines to heater core
- Help...Surging idle.
- s2k head on accord?
- Moroso Oil Pump Single Stage, what happens to the stock oil pump?
- Anybody using Whiteline coilovers?
- jdm final drive
- reving up
- Bigger rotors or bigger calipers?
- help getting bolts out!
- Want to swap auto to manual
- Anybody have Pics of Type-R Head vs. B16 Head... Where are the ports touched???
- JDM DC 4-1 header ground clearances???
- Vacum leak anyone can help B16
- heLPp Hid not lighting up properlyy
- steering wheel w/ airbag REMOVAL
- intake manifold install gone wrong...hydrolock???
- Building a head... can i do this?
- Finally B20 VTEC buildup
- Having Problems with Local Machine Shop!!!
- Sweet new piston design!
- fuel regulator in a 93 dx would be.... where???
- Skunk2 kit ball joint "Boot"
- i need help bad
- Flange Dimension Question
- Piston slap/knock sensor/vtec
- tps sensor!!
- Leaky distributor
- Anyone know of any good fabricators / weldors in Orlando FL?
- On Jason's OBD0/OBD1 harness. Evap Purge??
- Itr TB install
- will exhaust leak affect AIR/FUEL ratio?
- what sway bars to get? for a dc2
- honda civic runing rough
- 91 CRX SI timing
- mini-me and cam timing - help
- cvt tranny?
- Perfomance & Body Shops
- Motor Smoking After Rebuild? Any Ideas?
- Jasper Engines and Transmissions (you got to read this)
- What parts to look at when you suspect TOE problems?
- closest tranny to the b16?
- Turbomanifolds for ITR
- Help, my car leans out. Could it be my ecu? ------>
- alternator sparking/ car dead
- Possible dead clutch in a 96 Accord?
- question on Oliver rods and arp bolts (searched)
- tightening a/c bracket
- Anyone did a Disc conver????
- How much do motors wear with just age?
- CIVIC SI B16 AEM CAM GEARS ANY RECOMONDATIONS ON HOW TO TUNE
- Engine parts
- J1 tranny questions
- Cutting springs
- 93 hatch dx where does the map sensor wires go to on ecu?
- Difference between Pr4 head and P75 head?
- oil catch can=power steering fluid reservoir...can it work?(DIY)
- Cool air intake?
- mini-me swap
- Do I need valve spring retainers?
- help, my car pulled some weird codes.
- D16Z6 pistons???
- need 95 gsr girdle and main torque spes.
- I need a chip(EPROM only)!
- erratic idle after headagsket job...
- Play in rear brake assembly? Loose spindle nut or bad wheel bearing???
- 02 sensor
- v afc question
- ls crank and rods in a GSR block...oil squirters?
- problems with alignment after putting on tein ss coilovers
- SWAPING Gears NEED HELP!!!!!!!
- 94 b18c1 (usdm) with a 90-93 integra cable tranny which clutch
- D15b Prob
- alternator problem
- neuspeed sports vs. ctr springs
- JDM B18cR idling problems...
- oil seal
- I need help with OBD2-OBD1 conversion!!!
- Help! need to borrow someones crank pulley tool in NYC area
- Engine Cooling Question
- Japanese NPT to American NPT?
- mini me bogs (isearched)
- D16z6
- Has anyone used a new V-AFCII??
- Engine operating/water temp
- No Vtec Sound???
- new rods no squiters?
- What sensors does JDM ITR have vs. USDM
- which engine.......sooooo many to choose from
- i need to take out my tranny fill plug, is it a 3/8 drive?
- MSD 6A Ignition box... Any downside?
- injector ?
- ignition timing control????
- b-series tranny gears to handle 600HP??
- 400hp street car, how to keep it down.
- anyone know how to convert duration @ .01" to .05 or vice versa?
- Different size tires? ANYONE?
- idle problem
- GSR crank in Ls motor? can it be done
- Change Transmission Fluid After Grind?
- Setting the timing without removing the pulley
- Will B16B pistons fit in a B16A2....QUICK YES - OR - NO
- p75 b20 head, anything good?
- crane stage three b-series cams prt#253-0014 good or no good?
- Who makes the "Reactive" headers? do they make it or somebody else....
- connecting rod question?
- Ingalls CK installation
- New Honda oil filters
- White Underbody Neon Install (not mine, show car)
- motor swap 1992 Prelude H22
- Wiring obd1 b18a1 into a obd0 crx Si
- STAGE 2 OR STAGE 3 CAMS
- JDM LSD...where to get parts for?
- flywheel question
- Pros and cons of a Integra A/C compressor vs. SOHC A/C compressor
- LS/VTEC HEADSTUDS?
- CTR cluster problem!!! HELP!?!?!
- D16Z6 failed smog. High HC's. Need advice, help, smart-ass comments, etc.
- Backlight & Instrument light fuse problem!
- My GSR has no bottom end power, HELP!
- JUN B16 cams in a B18c? What should I pay for them?
- 60 shot of nos dyno graph... have a question?
- hondata crx ??
- Anyone using 20-50wt. synthetic oil?
- What do look for in a quick release steering hub?
- Is it worth getting GSR camshafts?
- i think my rings maybe gone
- Upper rear strut bar questions....
- LS 5th gear in b16 tranny
- Do i have OBD2 or OBD1 injectors?
- An-R and Headertech Header Questions
- Broken 450cc fuel injector?
- Having Fifth Gear Problems
- WHAT'S WRONG WITH MY CAR?!?!
- Honda manuals in PDF forms.
- Anyone know of a place that rebuilds this type of coilover?
- Installing VAFC (yet another post)
- wires wrapped around axle...in deep kim chee now!!!
- Power from free mods
- shift light didnt work
- Motor Oil in Transmission?
- need to get rid of check light, help!
- Axle is too damn short! B16 in a EG
- jdm b18c water pump bolt torque
- One wire hook up
- crank fluctuation ?
- Thermal Wrap on SS Headers
- calling all d16y8 experts!
- Need help: Two problems :(
- i keep throwing a code 21!!!!!
- LS all motor monster? Help!
- checking cel for a soft code
- When buying a full engine swap is it best to get new?
- Comp cams for Dohc Vtec
- machanic gloves
- B16 won't start
- Quick B17 Question. Just to be sure.
- Rebuilding my D16,+ tranny, Questions
- Buying car with very low mileage?
