View Full Version : Tech / Misc
- Distributor key
- B18 built block
- Troubleshooting: B-series No Injector Pulse - reopened topic in 2019
- Road Noise Fix??
- type r tb on gsr manifold?
- 99 si seats into ek
- Valve Guide Plug while Glass Beading
- Fuel Rail / Pump sound right? MOVIE INSIDE!!
- ELD Question
- slamming a k swapped integra questions
- h22 automatic belt tensioner to h23 manual tensioner conversion timing belt nightmare
- CIVIC CLUSTER STOPPED WORKING!
- B20A5 Sporadic Idling.
- VSS Part Number
- shops in augusta,ga??
- TIMING/T-BELT PROBLEM
- 90 integra gs code 9 problem!
- Oem gsr intake valve diameter??? Please help
- Update from CA SMOG Ref re: JDM engines
- are these cams repairable???
- arp replacement nuts and washer
- Need help with a y7 engine harness
- Car is smoking after mini me swap! please help!
- Car starts then dies after adjusting FITV.
- requesting info on jdm gsr cams
- B20 AWD swap...???
- performance shops in augusta,ga?
- Wire Tuck Help Needed
- Just how does a fuel gauge work?
- STR web page
- Question about carbon fiber vinyl
- b16 & b18c block deck height?
- *96 GSR isn't strating *
- machine shop????
- question regarding ls swap and other about a rebuild d16y7
- Need help on oversize valve
- first start on fresh rebuilt engine
- Custom set-up, need to know if it will work :D
- Engine.. Good or not?
- Sounds like running on 3 cylinders?
- What is the definition of Cold Start?
- The search continues.
- egr modulator
- machining caliber bracket
- After Market Metal Headgaskets ?
- Distributor Oil Leak
- swaps from zerolift autolab
- strange noise
- Help required to diagnose HR-V oil burning issue from video
- Strange Noise from Head..Need B-Series EXPERT
- distributor-less
- Coolant keeps dissapearing out of overflow reservoir
- Stop blowing fuses to find a short
- exploding reserve tank
- Need opinion on main and con-rod bearings PIX included
- Rough idle 2000 Accord 4 cyl w/63K miles
- oil pressure sending unit won't fit on my block thanks to Golden Eagle!!
- 96' Integra bouncing tach problem.
- TDC F23A1 and other question
- stupid racing steering wheel and hub question
- TOO MANY REASONS Y YOU SHOULD NEVER TAKE YOUR CAR TO RACELINE
- Pickle in gas tank for HP?
- Smog fail. Catalytic converter break in period?
- Oil Leak/Gasket Kit
- Edlebrock Victor X or ITR Mani?
- car idling high after phearable diy chipping kit install
- ACCEL COIL QUESTION
- NIRA Intense Import Drag Racing game. Where can I buy this?
- DD Help!!
- Easy swaps for D15?
- cracked GSR crankshaft?
- failed emmissions
- what size fitting to use at the vtec pressure switch location?
- 1990 honda accord ex speed sensor?
- Scratch on the deck of short block
- Rear main crank seal metal area ?
- how to install after markt seat rail on aftermarkt seats. help please!!!
- Where can I get replacement recaro seat fabric?
- Cel 20 More ELD issues...help please so aggravating
- engine swap starting problems
- wiring 98 civic alternator without computer
- Whine coming from Belt side of motor (video)
- HT help me identify these cam gears PIC
- Low RPM Hesitation under 3k when warm
- walbro 255 and bosch 044 help!!!
- problems with my ej1
- Custom gas pedal assembly?
- Massive vibration at the top of 3rd gear
- Setting TDC Questions
- timing belt issue
- honda civic eg hatch headlight problem
- Does anyone know where...?
- Recently Purchased B20v
- No start, done everything in FSM, any ideas?
- engine hoist / cherrypicker and low garage ceiling
- NEED NITROUS TUNING TIPS FOR BUILT L/S VTEC W/ GSR HEAD
- ******NEED SOME CAM HELP!!!!!!******
- sign of a bad coil??? inconsistant power and revs
- ***Air Conditioning - A/C Guide, How it Works, and When it Doesn't***
- Issues.. Won't stay running.
- help me on door release and more
- my 92 Integra is having strange reactions to a coolant exchange. Need help
- need help id'ing rods & pistons
- k24 wire harness HELP
- Fel-Pro Valve Stem Seals?
- GSR Losing power after 7500 rpms!! Vtec on and off
- No temp gauge "cel 6/bad ect"
- driving with the o2 in the exhaust but disconnected. bad for o2?
- HELP: b18c5 in 97 del sol si (first car)
- water pressure guage for fuel?
- Removing head & timing belt questions
- Jdm tiger engine? good or bad?
- possible alternator problems
- Car wont rev or move but goes into gear help!
- Checking tie rods
- obd1 gsr head on obd0 a1
- Need help identifying this part!
- Need help identifying oil leak
- Parts needed for Valve seals, Head gasket
- b18a1 oil pressure gauge/switch
- new custom O2 sensor part ?
- Weird Honda engines. A list I'm composing. Please add if you have anything relavent.
- Blown head gasket on 1988 Honda CRX?
- how to i set ignition timing without timing marks?
- p0113, still on after I cleared it!
- coating aluminum to resist heat?
- brake lights & horn dont work (no cruise)
- Jdm B18c vs K20/24
- Keep blowing a fuse
- HX O2 sensor Help!!
- How to Find A Good Machine Shop
- Win $5 - Help me ID these cams
- Change name on account
- LS/ Vtech Running too cool ?
- Weird Electrical Problems
- Transmission question
- LF b16-EK swap help
- How to tell if my motor is original or been swapped?
- Direct Vtec Wiring
- f20 blue top and h22 interchangeabality?!
- timing belt tension a built head
- Somebody tell me why my rotor is pointing this way. (pic)
- Replace 01 gsr rear engine mount ???
- Fuel rail
- Piston-to-Wall Clearance/Piston size question
- Gasket sets?
- knock sensor, any difference?????
- obd2a dizzy work with obd2b loom?
- 2.2 sohc rod bearings
- Confirming Front-end
- 1999 prelude with obd1 jdm h22 swap CEL code 6 problem
- white smoke from my radiator?
- How to tell difference in GSR/ITR and LS/B20 oil pump?
- energy suspension shifter bush. ?
- da integra seat help
- Noob with Ls/vtec needs help
- 06 Odyssey rear seat belt gudes
- vtec-non vtec bearing differences??
- LS EG Hatch Failed Smog at CA B.A.R. Results Posted!
- 1994 Civic Ex trans problem
- gsr swap in eg hatch exhaust help
- ls/vtec wont idle right!!!
- Please Help Us With Our Study On Intelligent Vehicle Diagnostic Services
- Turbo GSR Skunk2 Pro 1's: Won't Start
- 1994 acura integra help
- Non Honda question - comments on aftermarket radiators?
- OH look at that! my heater has no heat! =O
- car not starting
- Difference between Civic EX/Si Steering Knuckle and DC2 Steering Knuckles?
- B18 Problems Need Some Help
- walbro pump on stock motor & OEM FRP
- Instrument Cluster Fuse Keeps Blowing
- bseries obd1 vs obd2 alternator
- Vtec STILL isnt working
- 95 gsr head fs
- cars not starting looking for suggestions
- CIVIC CLUSTER help:ugh:
- B16 Swap Downpipe CX hatch
- All stock 90 DX civic - engine suddenly has nasty skip??
- High RPM Idle When Heater/AC is on...
- WHAT KIND OF WHEEL IS THIS????
- Decideing on a lightweight battery
- how to install 34.3mm freeze plug?
- crx keeps blowing coils.
- help!!! engine wont start, will turn over...
- Degree cam?
- Help!!! 89 Civic hatch with B16a motor won't start
- HELP! '92 vx b18c1: knock sensor(code 23)
- EG6 RHD CONVERSION?????
- Does anybody make this adaptor for the B series engine?
- Resource: Measuring Parasitic Current Draw
- Earth Switched Headlamps Honda Vamos
- Weird cel/temp gauge problem in a k swapped car
- grinding noise coming from brakes?
- New vs old Dryflow filter
- MAPerformance Around the Shop -Updated Daily!
- Vtec isnt working !!!
- power steering removal ?
- HELP!90 DA B18A1!
- HELP!!Rich,knocking & shaking engine H23
- CP Piston Rings?
- Severe steering wheel shake in EG with LS swap
- noisy water pump brand new. d15b7
- cooling problem
- 1994 acura integra wont start
- delete
- ef9 radiator hose help
- Gsr/b16 valve seals
- hard freeze time
- HELP!
- HELP: Left Headlight Front Turn Signal
- Lost injector pulse Please help
- Jury rig time! Door won't shut
- D16 idle trouble
- NRG Quick Release and Mugen V3 Wheel.
- Custom LED taillights, would this be bright enough?
- piston ring set from Honda, Question??
- s2000 steering wheel into ek wont fit??? Help..
- OBDII H22a..say what?
- thermo/vtec help! rewiring! 95 hatchback d16y8 swap
- Oil Leak from Oil Separator Box B16A
- Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harness
- broken locks
- Axle Popped Out; Has Me Puzzled.
- Question i really need answering! please HELP
- 91 DA B20B
- rear block plug - allen size?
- car will go into gear but wont drive? (b16 eg coupe)
- B16 Head oil starved? is this fixable?
- Electric war
- Injector duty cycle too high?
- Please help
- help with gauge cluster needs on my em1 ??
- 3m carbon fiber vinyl question
- penzoil platnum ?
- Walbro Fuel pump installation fuel pressure relief question
- Anyone know where i can get a cheap inspection/bore scope
- Can someone tell me what number 12 is on this picture??
- Rear Main Seal on Acura Website has 2 Part Numbers??? Why?
- Doing a Rebuild on my Daily, Question about Gaskets/seals
- checking timing wit timing gun
- 2010 Honda Accord SE acceleration question
- Please help me diagnose my A/C
- Timing Belt Help ASAP
- car not cranking problem (eg coupe b16)
- Failed Smog HC 547 (PPM)!!!
- 92 Accord Ex Wagon Engine Vibrates
- stripped bolt/any other way to get trans fluid in?
- can i turn on my car without driver side axle on?
- anyone use these batterys? Braille Battery No-Weight
