View Full Version : Tech / Misc
- LEAN
- Question on Hood--can't post in parts area...HELP
- Diff in AEM EMS between 96-99 and 2000-2001
- First swap and need help!!
- LS-VTEC oil line which is best set up?? Guess would work on Turbo also....
- im putting a gsr head on a ls block
- daily driver eg, adjustable shocks or traction bars?
- Good hondata tuner in houston area??
- ebay type-r trans
- itr cam installation problem......help
- '93 Teg B16a (JDM) >>>Ecu help! <<<
- Many problems, PLEASE HELP diagnose what is going on..
- light car batteries in Canada , ontario
- Wire harness Q`
- jb weld question? wideband bung for downpipe...
- Those of you with tucked tires......how can you turn?
- ECU fuse keeps blowing
- will a stock b20vtec blow its sleeves on a 55shot of nos? going to 8-9200k
- Multiple Owner Vechiles
- Fuel Cut Off Near Redline
- Tranny does not turn?
- No snap ring on tranny???
- Piston Question....
- Why does a exhaust header increase hp?
- b17 question?
- HELP
- Anyone have links to good TRANSMISSION swap writeups?
- Help!! Burning oil!
- Wiring harness for '89 CRX
- clutch question?
- New Hasport mounts, Recommended???
- Bad o2 sesor?
- H22A Cambelt Service - doesn't feel right
- HELP: Issues wiht NON-CHIPPED P28 w/ harness installed into 00 Civic Si
- p30 computer
- what kinda tranny 4 b20 vtec?!?!
- tuning v-afc by looking at dyno sheet?
- Suspension Set-up/ New to Car w/LSD help!
- Tranny Problem
- desperate tech help
- engine swap w/ auto
- Anyone have wring diagrams for the OBD2 LS wiring harness distributor plug, and an OBD1 B16 distribu
- horizontal shock/spring mounting: someone help me understand..
- piston size
- JDM ITR SRS steering wheel
- Main bearings....
- b16a with ctr piston ?????
- transmission suggestions?
- Quick Q: radius arm and tension rod same thing??
- slightly lumpy idle + rattling noise + something fell off from under my car!
- WTF: I Give The Car Gas and it drops in rpms like a big gulp then recovers but sputters.HELP
- whats the different weights for differnt hondas?
- 99 Accord V6 Starting Problem. PLEASE HELP!
- Running lean not enough fuel
- Transmission identification help
- SR20 swap question
- axle or steering rack? help!
- OT: Anyone here from the Stamford, CT area?
- ls + boost question.
- Problem: EG w/B16A won't drive
- Can someone tell me how to connect a Autometer Fuel level guage in a 95 GSR??? THANKS
- sleeves or orings on b16a1!!???
- does the pilot bearing contain grease inside?
- crx vtech relay help
- sleeving an h22a
- what ECU to use? H22
- Checking timing (belt) whithout removing crank pulley?
- (civic n2 crx)Swap not starting... pLZ help!!!
- my greddy turbo
- Is this at all possible? H23 in CRX?
- CEL scanning
- Need help with obd2a to obd1 swap
- Phantom Grip amount of force
- Civic w/ITR calipers & itr/prelude rotors
- Bad o2 sensor?
- BIG BRAKE QUESTION!!!! NEED HELP REGARDNG 99 ACCORD EX 4CY AND 97 ACCORD
- ls/vtec problems!
- How to break in a new, untuned motor (or best practice)
- O2 Sensor Gone?
- 96-97 p28???????
- built head question????
- spuddering problem... help!!!!
- What can I use form 93 Integra on EF???
- help with vafc HELP
- good tire?
- any way to identify an ecu?
- vr6 swap?
- car will not start and, spark plugs not sparking
- shorter EK lca's
- jimfab rear mount on an integra?
- Cooling fan issues...
- hardlines v.s. SS lines?
- making my h22 into an h24
- NEED HELP!! setting up Willem EPROM programmer
- floor jack maintenace tech
- Does anyone make aluminum front lower arms?
- Sputtering Question.......need some advice asap ......
- Throttle body gasket - wrong one?
- pcv valve assembly, 2 listed for GSR which one?
- Car overheats when thermostat is installed
- questions:os giken, CUSCO super single clutch disc
- removal of stock brake rotor
- 2 inline fuel pumps.
- apexi n1 coilovers
- HOW TO ELIMINATE RESISTOR BOX. 91' CRX W/ B18A & 92' TEG LS ECU AND HONDATA S200
- engine wont start----elp please
- B16 cam markings??
- JACKSON CLUTCH??
- why does everybody say its all about AREA UNDER THE CURVE??
- Differences between BBK 70mm throttle bodies?
- CA engine swaps - what happens if caught?
- CD STUCK IN CD PLAYER
- Funny noise when turning steering wheel.....
- Ferrea rockerarms
- Drop motor assembled into car?
- Valve Spring identity help needed.
- oil light will not turn off
- glowing spark plug wires
- avenger injectors?
- 450cc injectors installed, running like crap *I searched*
- b series diff. need help NOW!
- ground control spring upside down?
- B18C1 information
- Sub Frame Reinforcemen / Kit A-Spec Racing
- My motor is hungry, why?
- rotor/distributor cap
- stock caliper question
- how do you change brake fluid
- valve adjustment
- Big Suspension Problem
- how to increase fuel pressure in returnless fuel system?
- gsr main caps to b16a2
- GSR Help >>>>>>>>>>>>>>>
- Tranny Problem on 1990 Accord
- poor man's type r emissions
- VAFCII help
- New engine driven.
- Defective IACV...
- vvvvrrrroooooommmmmm BANG!
- SEARCHED LONG AND HARD WITH NO RESULTS: HP vs PS?
- Best PDA/PC Scanner software and cables?????
- Uh oh!!! Stock B16A2: Second gear, 80+mph, ~10000rpm!
- The stock stroke length of a B18c??
- c/r question for gsr/ctr pistons, simple question.
- Spring Rate and its compression
- ecu problem?
- Knock sensor grounded out?
- Tires + rims!
- Might have swapped around my injector clips on accident. Wire color?
- could my map sensor make me throw a oxygen sensor code?
- question on wiring a h22 for a EF
- What grit do you use to hone with?
- What does an alternator pulley do?
- Car wont' start, been through all the effin basics... PLS HELP :(
- NEED HELP ASAP CAR WONT START
- problems with recently built motor (not honda related)
- oem dipstick not holding tight in dart block-- dart dipstick available?
- 96 spec ITR lug converion on a EK 96-00 Civic
- Skunk2 Valve Springs
- Balance Shafts
- any body face plate their trannys?
- anyone used a rx7 fuel pump in their civic?
- b18c1 tranny easy to take apart?
- gsr cams or itr cams..which is better for ls/vtec??
- Hondata Prerequisites
- DSM injector resistance?!
- program 99 ecu to 2001 ecu for BAR puropose
- Understanding CG and Corner-Balance?
- Car takes a long time to start after filling gas.
- for 200 to 250 hp, need not gap the piston rings?
- How to CORRECTLY Break in a new Engine. NEEED Help.
- any input on why/how my ringlands cracked?
- VTEC Wiring Question and MAP Sensor Wiring HELP NEEDED.......ASAP
- Electrical help. Blow fuse?
- 1990 Accord 2.2 L. Timing Balance Shaft
- <<<<Check out the kinda stuff that happens at Mcgrath Acura>>>>
- blown head gasket?
- Alignment Question
- did compression test ?? are these readings ok
- bearing Question (already searched)
- Any way to get rid of speed governor for cheap?
- backfiring
- seafoaming ???? what is it
- Tapping the head for LSVTEC
- HELP Wiring motor question - ASAP Please
- My driver side window doesn't work anymore
- ???OBD1 Vtec Distributor to OBD2 LS harnes??? I HAVE SEARCHED!!!
- the hyrbid engine
- Does this look like a OBDII to OBDI conversion already.
- finally got the sleeved b20. will revving to 8k rpms be a problem even if i can still make power the
- B16A J1 trans & 92 GSR YS1
- innovate wideband quesion...
- The Other Guys Custom "Big Dog" Exhaust Headers or SLP™ Ceramic Coated Headers
- Problem With Installing Indigo Gauges
- Anyone using a SRR rear tie bar with an ITR or skunk2 sway bar on a EK?
- US Castrol Syntec Vs. German Syntec
- B16b rods different length than B18C5?
- what TB to go with
- Install pistons from below??
- Baseline igintion/fuel maps
- Cant figure out smoking problem. here it is...
- 98+ 6th gen accord auto to manual
- type R brakes Vs. GSR difference?
- map sensor?
- VTEC--limp mode with stock ecu, sputters before engaging with Hondata; CEL 3(MAP)
- Driveshaft same as Drive axles for fwd?
- Axle Squeek
- Wheel bearing questions!
- Just Chipped and Solid CEL
- 8 Wire Distributor Vs. 9 Wire Distributor (Please Help!)
- What colour is brake fluid supposed to be?
- Machinegun Backfires?? (changed coil/cap/plugs/no vac leaks)
- Reccomendation for clutch setup on an Integra LS/Turbo
- CEL Problem, dosen't look good...
- Wheel Offset
- tranny problem...
- IMCO mufflers?
- Catch can problem (already searched)
- HELP: Straight Piping
- Going to dyno but concerned....Is there a real answer-Vtec breaking up and soft code in 4th gear??
- Got built ls head...thinking lsvtec?
- Bore and Hone
- Good size for home made ITBs?
- ring and pinion play (91 zc tranny)
- What are the chances?
- taking off clutch?
- cam seal on distributor side?
- 8mm throttle body increase
- Questions, questions, questions.
- Which head studs?????????
- EGR system problem
- autometer voltage reads
- outrageous oil pressure....
- HELP car wont start
- anyone just bolt on a block girdle???
- making itr pistons fit b16 rods
- need advice....
- Dropped VSS into tranny. Need Advice!!!!
- Dyno Tuning in Texas
- any one help vtec uninstall problems
- MPFI Installation on 88 CRX DX
- Where can I find an aftermarket transmission for my a Civic B-Series swap?
- d16 distributor
- any uberdata tuners in the DC/VA/MD/PA area???
- NEED HELP to find a mashineshop in Los Angeles CA
- Is this possible???
- transmission issue
- GSR cams, quick question...
- Anyone Fab a Suspension from scratch?
