View Full Version : Tech / Misc
- Anybody with Pictures Of Ferrea Valves (combustion surface)??
- car stalls when brakes applied HELP
- white plugs with zex.....missing something?
- Alternator Adjustment
- best way to know if head gasket is blown ?
- ECU Question
- ACL bearings wider then stock honda bearings???
- which is more important mandrel or ceramic coated
- front axel
- header question
- Help! swap problems
- UhOh, I broke it.....
- How to store a cat......?
- differences b16/b18 headers
- somethings very wrong with my rocker arm...
- Axles & limited slips???????
- Should I get rebars?
- I think I'm having some trouble with my B16A3 bearings.
- whining noise when clutch is pushed in?
- best way to staore engine
- TB Help
- low compression, what can it be?
- REBUILDING tranny, what to get?
- rear disk options which is better buy
- Where do i connect the power wire on my evap purge?!?
- Sohc
- Crankcase Evacuation Systems ??
- Apexi VAFC II (A Few Questions)
- tunning help
- OIL LIGHT stays on and blinks
- GSR oil pan on a LS...
- Stock GSR fuel pressure
- Got some problems!!!
- need some advice, b16a smokes after rebuild
- gsr and ITR parts
- Wired Speedlab Technical Databse Back Online - Hondata 101, Clutch 101, Turbo Tech...and More
- oil pan leaking
- What exactly is the Vtech?
- my shop must be full of idiots....
- Got Fuel Pressure, No Spark?
- Car dies ? was tps, now what ?
- Question About Sport Comp Tach.
- TSX i-VTEC into RSX
- Type r Prop vavle?? HELP!!!
- how do these cr#'s look for a fresh motor
- Venom or STR Manifold-has anyone installed one?
- Question about adding bumpstops to my tokico blues...
- Part numbers for EK9 Type-R
- Can't get RC injectors in!!
- need a how to guide on integra tranny swaps!!!!!
- Snap a stud from the block to intake manifold. What to do?
- What laptop do you guys use for tuning?
- Which Header: JDM RS*R or JG Pro Flo?
- IAT sensors what causes them to go bad?
- SOMEONE PLEASE help me out with my D16!!!!!!!!
- does higher lift cams lower your copression??
- GSR Tranny hard going into any gear
- need help, MAJOR problems with my b16 del sol
- Ef-1 M21 cams vs Skunk2 Stage 1's
- Long term effect of lowering a car?
- Avrg. Amount to assemble a short block
- took apart the motor
- when I turn
- ITR Pistons
- b20 sleeves cracked or cylinder head?????
- has anyone had a problem with blowing fuel pump fuse on thier honda?
- clutch fluid leaking everywhere
- last week oil is full, yesterday almost nothing there
- found this interesting wheel weight list
- having trouble timing ls/vtec
- Power Steering Fluid drain and refill
- Best exhaust for b16???
- need help!!
- AEBS....T-Sleeves, Crank., Racing Cylinder Heads.....I would like to know more?
- question B18C5 cams
- weird spark prob.
- piston removal ?
- what timing belt to use??
- Does a 1995 B18B LS have a knock sensor please help!
- H22 Swap for a 96 Civic hatch
- just did auto to 5 speed on a 94 integra , speedometer dont work ???
- cat back to cat bolts...
- In Dyer need of help
- USDM ITR swap into 92 VX
- tranny blues. PLEASE HELP!!
- 2000 B18B I6 cam cap !Question!
- whatt cc are 1.5L injectors and b-series injectors
- Del Sol question
- Tech help needed please. Motor runs like crap.
- Spark Plug #1 Leaner Than The Rest?
- question about tranny swap!!! need help
- Anyone in Greensburg/Pittsburgh area that can help with b16
- new input on manifold 's
- oem repair manual
- type R with turbo???
- gauge cluster done work!!
- fuel rail question.
- Good Quality books?
- bad compression test
- throttle cable adjustment
- Vtec, VAFC, and oil pressure ????
- Problem with my 92 Hatch....
- New clutch problems PLZ HELP
- msd grounding
- Electronic cut out?
- 92 motor in a 91 ? will it fit
- d16z6 block with d15b2 head???????
- no power
- ATTN: All Canadians - New Magazine
- what do the dials on an emanage do?
- Have to replace my CV boot
- Trouble starting the car sometimes / belt is always squeaking.
- copression????
- B16 in 93 eg no power
- B16 TPS Setting, don't understand
- jdm b16a1 spark plug gap?
- o2 sensor size needed!!
- how to eliminate injector resistor box.
- Rivet Gun
- O2 sensor heater code, is it important?
- 13" 14"15" wheels?
- Timing info needed!
- current Tech forum mod? please IM me.
- Compression ratio = b16a block, stock head CTR overbored piston 1 layer headgasket
- ok i give up, where is that cool D16 sohc vtec thread?
- what's wrong with my tranny?
- STR cam gear timing
- How to replace a front bearing ?
- 93 b16 in 95 civic
- cam clearence
- ???best brake lines for a civic???
- What could cause a BOV-type sound?
- please help with car not starting!!
- b16 timing, need help asap Look!!! :-P
- ECU confusion
- d series tranny
- rear strut busted through strut mount!!!!!
- Need help with two CEL's!!!!!!!!!!!
- Leakdown test in So. Cali???
- Will CEL 41,20 result in open-loop mode or engine damage.
- can't get the top hat off my konis! any help??
- Need some SAFC help.
- 1988 CRX Fan not coming on
- Golden Eagle Block B18b w/ GSR Head 84.5mm Ok to use CRV B20 headgasket?
- how much compresion is to much for boost
- Fuel pump install with Vortech SC.
- Sticking Throttle Plate? - B18/D16z6
- B18B Honing
- Compression/leakdown results
- Axel problems
- Tap size for threads on an o2 bung?
- HELP! My car is undrivable
- Honda engine theory?
- Help!
- What do I need for an OBD1 conversion?
- I want to make a knock sensor display, please help
- Getting rid of Carbon Canister
- Relaiability of H22 turbo vs Allmotor.
- Y7 intake manifold vs z6/y8 manifold on a SOHC vtec head
- car has no power to move itself... LONG STORY but i need your help
- installing cam gears
- si tranny with lsd?
- Help to Identify my tranny.
- good compression, bad leak down!! what does it mean??
- newb ? Hondata question
- Car bogs around 6k...cat started making noise too.
- Coolant drain bolt on block for J30A
- rsx type-s suspension ????
- misfiring since installing a MSD
- Newbie question about gauge clusters.
- Old engine, which guages are a good idea?
- Fuel Injectors for 98 Integra GSR
- ngCouple of newber questions...
- need part # for cam end cap near the distrib
- p28 ecu o2 sensor ???
- PROBLEMS starting after cam install, tech guys plz help!
- Swapping Heads- Do I need new head bolts?
- Some Thoughts on different ECU manufacturers.
- AEM EMS.. Where'd u get urs, $??
- how much Deg. advance timing can you get before having to alter dizzy?
- ac hooked up to your intake~~ sounds crazy
- techies??? 20in bore!!
- need info for obd2 to obd1 conversion
- What is wrong with my car!!??
- Help!
- bad cyl position sensor?
- 88 crx looking to put b18c5 but want to make the car odb2 can it be done? i want to take it to the R
- Header Question?
- want to use si harness on dx 91 car for ls swap is it possible
- HELP...more braking problems
- WTF funny sound from B16 tranny
- Help on Engine problem
- Who knows their car smells?
- keep burning the ecu...
- check engine light code 43
- Engine has low vacuum
- Skunk2 Stage 2 and Jackson Racing Supercharger?
- need tranny help bad
- B16 heads
- h22 timing belt slipping. pls help.
- EF1 Turbo Rods
- Starting problems after installing walbro fuel pump
- Endless vs tein vs srr
- Have fuel, have ignition but wont start
- Don't want to waste the D16Z, so is it possible...
- help me decide btw skunk 2 stage 2 or toda spec b's or c's
- What Psi is the A/C suppose to be set at on an eg6??
- b16 oil pan gasket
- anyone have any experience with allied suspension products?
- need help from gsr owners
- H&R Coilovers.....Need Info
- zc crank tie down vs d16a6
- 95 4dr gsr maintance req light please help
- important o2 sensor location
- how to change axle seal
- where does the filter go in an individual throttle body intake set up??
- head gasket question
- OBD2 OBDII OBD California CARB Ref (All OBDII Related Smog Questions & Answers Here)
- B16 rear main seal
- lsd install ?
- I think I'm going to be ill.
- wiring problems
- Spoon Sports p30 obd-1 Ver5 Spec?
- so i over torqued my rod bolts
- 5" Tach Install help
- greddy exhaust
- B16A2 Fuel Pressure Regualtor on D16Y8?
- B16a motor and radiator issues
- P28 w/S200 on '00 H22a, keep getting random limp mode CEL's.
- Y8 intake manifold on D16Z6.....Detailed instructions
- 88 crx with obd1 b16a (88crx si wire harness)
- ANYONE KNOW DSM'S HERE???? BUDDY NEEDS HELP FAST!
- Strange Noise right before and during VTEC
- jdm steering wheel fittment
- ls motor back in ls and not starting
- Car wont move
- lsd tech
- Wiring Harness
- Question about a stock LSD!! Please Look
- Uberchip Posting
- hondata S200b and vtec contoller
- Where to find the best non-spoon magnetic drain plug?
- h22 crankshaft
- Mechanical fuel Injection? WTF?
- H22a Dual springs
- B20 block Vs B16 2nd gen motor and others... into a 90 crx si
- engine pings on start-up.
- ecu fuse blowing
- dB level on N1 catback with jdm header?
- external coil question
