View Full Version : Tech / Misc
- 96 civic
- 96 civic AC trouble shoot
- AEM Fuel Rail FPR Port Thread?
- HELP!!! 2000 honda civic si w/ 5lug swap. Rear wheel bearing question
- d15b7 cant figure out why its smoking so much
- no power to iac/iat valve
- rad fan after AC delete
- Dynojet VS dynomite
- AFR Sensor test
- Lucus oil stablilzer - why not thicker oil?
- Aftermarket distributor any good?
- Car Starting Mystery
- need some info
- B18CR Feels like a B18B, not enough power*Help*
- battery Charging Issue Plz Help
- 044 bosch pump wiring help
- MAP sensor
- h22 head on f20b 86mm
- B18 High Compression Pistons
- Just my luck
- B18 distributor shaft bearing replacement?
- EK Owner Need Some Out Of The Box Help
- b16 swap poor/no acceration in vtec
- LS Vtec Turbo issue
- Buying a CRX after a failed hotwire attempt
- Sorcery!
- ATTN: Machinists! Is my head salvageable?
- I NEED HELP!!!!
- 2006 Honda Accord EX-V6 electrical problem
- ignition problem obd1d15b vtec
- Tapping my VC for OCC
- Help !! Engine vibrates when I press the gas
- extend map sens hose of wiring.
- CD4 accord auto to manual rear bracket...
- 1990 Honda accord is really sluggish! !!!
- R18 fuel consumption
- d16z6 timing belt cover interchangeable with d16a6
- stranded help please CEL 15
- Speedo doesn't work
- D16y8 swap to y7 help!
- Port and Polish Oem H22a4 intake manifold or Skunk 2 pro series manifold?
- How does NRG quick release work?
- Engine importers in or near So.Cal
- got electrical demons with p28 ecu
- California BAR'D Engine JDM B18C Type R - Will this setup pass?
- TPS mounting position on aftermarket throttle body?!
- 94 civic lock mechanism
- CA SMOG for V6 Accord: both mufflers needed to pass?
- GSR Tranny Stuck in 5th gear??
- Oil pan gasket! sealant or no?
- OBD PORT Current Limitation?
- Project Poll
- LS-Vtec vs. GS-r parts ID?
- PR3-1 head what is this? ITR or B16?
- Help Please vsa wiring question
- help... car runs then shuts off... sometimes.
- FTW red Vs M5 need feedback
- its broken????
- Idle/throttle response nightmare!! Help please!
- CTR Headlights for 00 EK
- Gsr - low oil pressure at vtec solenoid - please help
- speed sensor issue, b series
- General question about engine performance...
- Fuel cut off after cranking
- b18c smoke issue
- HELP HONDA ODYSSEY AC PROBLEMS
- 02 Accord Rear Doors Will Not Open From Outside
- Vtec not working
- radiator fan not working
- 96 civic CX B16a2 swap help!
- Can anybody find and or identify this clamp?
- Honda Civic 2001 LX
- 96 integra ac
- d15b obd2
- Jacking points front 1994 accord
- Bad Cat Converter
- Plleeeeasssee helppp!!! Bseries troubles
- motor shutting down issue
- ef exhuast?
- NEED SCHMATICS/SERVICE MANUAL
- Fan issue, please help!
- auto to manual swap issues, chassi harness differant! help needed!
- in@rr numbers?
- In neutral but still in gear????
- fuel pump location 1992 honda accord
- Cheap motor mount replacements
- 94 acura wont start help im a newbie
- LS VTEC oil block plug
- odd shake on my em1.."help"
- Car won't start after changing distributor
- ignition issue
- 90 integra wont start??
- exhaust leak fix
- Thermostate housing + aftermarket temp sending unit?
- passenger door wont open
- Injector Dynamics 1000 install ITR b18c
- air condioner - syrofoam???
- post your diffuser/belly pan pictures
- HD Tutorial: How to install & assemble P.T.F.E & Teflon Braided AN Hose
- Anyone have a possible contact in japan that can order me up some wheel studs ?
- Measuring RPM with multimeter
- missing map.sens connector/plug
- D16Y8 Build...Anyone using B-Series B18 Engine Bearings??
- Code 9 on b20b help
- A/C fan keeps going after shutting off engine on '97 Accord
- 2 different fuel pressure readings at different locations.
- 6th gen auto to manual swap dash harness??
- 2001 Honda Accord F18B, interference engine or not?
- Apexi exhaust taken on "fart can" sound. Why?
- Help - B16 Wiseco/Eagle/Crane/MSD = Weird sound in idling (video)
- d16Y7 cracked head
- something is wrong with my AC. help !
- Identify this intake
- VTEC bolt sheared flush with head
- Honda Civic LX 1995 cranks but no sparks, no fuel
- LsVtec Rod Bearings and Oil Clearance ???
- CAn this head still be used?
- Can k24a2 fit in a 04 honda accord
- 1998 Integra GS B18B1 No Spark, Starter Won't Engage Through Ignition Switch
- cylinder wall thickness
- odd vibration, somehow temp specific
- IDENTIFY THIS ENGINE BLOCK
- Switch Transmission Output Direction?
- Mystery Coolant Loss
- 1995 honda civic fan not kicking in.
- Auto ls into 94 eg4dr has anyone done It?
- Skunk2 megapower r 70mm
- Help me identify these seats
- more or less grease on prise axel
- The rubber spark plug gasket is melted to the plug
- Honda Civic Mk 5 Hatch Coupe interchangeable parts
- coilovers loose perch
- skunk2 ultra intake icav question diff one
- tuning with 2 piece header?
- building a nap gsr
- 93 civic check engine light
- Check Engine light
- painting your own trim screws
- horn wire keeps breaking
- Plugging oil drain passages in head, need help
- All new a/c components...issues
- 1992 honda civic wont turn over or start
- B-Series Header Flange Measurements Needed
- B16B head to B16A bottom end - which head studs?
- my speedometer going crazy
- Fuel pump not priming!! Help*
- BOV won't sound off as loud anymore
- Possible to Replace A/C Thermostat without Removing Evaporator?
- problem during installing stock cams
- 95 honda accord ex f22b1
- Confirm my OBD2 injectors in OBD1 wiring...please
- Zap radiator / gates rad hoses
- D series Turbo advice
- cluster lights not working 93 civic
- oem fuel injectors identify
- Can degreeing problems
- chrome, neptune, hondata?
- Catch can and valve cover breather
- supertech springs wont sit right on oem seats
- how to figure out whats size rod with your stroker crank!
- Question about valve seats and new valves
- Question about ID 1000s
- EJ1 SUNROOF
- bad gas milage
- Which 15x6 will clear Willwoods best
- b18c1 swap wiring ?s
- write up on painting rims with lip
- 2000 Galant Drivability Issues (Stalling/Hard Starting)
- civic wont rev past 3000????
- removing the old gasket en cleaning/sanding it up
- EG4 B16a2 swap witch steering pump to use ?
- 94 civic ABS question
- B18C CRX only starts w/ MAP unplugged?
- Vss problems em1
- Starting a car after sitting a long time....
- over heating problem ls/vtec
- Crank condition
- Grant Quick Release Steering Wheel/Hub and Horn??
- 5th Gen Prelude Fan Switch
- ITR cluster parts
- Help me please!!! Im pulling my hair out!!!
- 87 Civic questions.
- any way to identify stock fuel pressure regulator B series?
- Cluster calibration
- Golden Eagle sandwich plate seal remplacement part number?
- Square peg round hole? H22 CRX
- 95 Civic EX - TURN SIGNALS STOPPED WORKING!
- Vx harness question
- 99 accord hard shifting
- 2000 civic AC
- HP calculator yay or nay ?
- Anyone ever try this product? (cv replace boot)
- crankshaft pully felt on the ground en damged
- Help me build an ultimate high MPG car.
- 00 si door panels on 98 coupe?
- Installed new speed sensor, didn't fix!
- b16 valve replacement question
- turbo hitting ac bracket
- ls/vtec help ...
- how to tell toda oil pump?
- very weird dpfi to mpfi swap problem
- Engine stalling!! Help!
- Need help b16a2 head
- Can you ID this metal in oil pan?
- B18 Vacuum Diagram, for B20v
- B18C1 Jumped Timing
- Fuel Gauge Question
- H22a4 Head Knock please help.
- Questions about Jic fittings and plugs
- 92 honda accord over heating
- Since I Cannot Find An Answer Anywhere...
- non-Honda - small engine question
- need advice on how to fix worn wiring
- Just curious about a 3/8 drive
- matching PS bracket + pump from h22a4 head to f22a4 short block
- sputter at high rpm and no power
- h23a question
- Pilot wont pass emissions. No engine light.
- Cigarette lighter Honda Jazz 2010
- My h22a1 need help..
- Need help with engine code
- Placement of Honda Bond/RTV??
- 1992 honda prelude, hard to shift.
- Intermittent starting issue...
- buddy club fitment?
- Acceleration problem's
- I need some AC
- obd1 civic electrical issues
- H series header question (I didn't search for the answer)
- PLEASE help me finish swap. O2 SENSOR QUESTION
- Need help bad!!!!!!! b16 doesnt have rev limiter.
- need help with an 8 fuel return
- Grounded for life!
- Eagle rod wrist pin bushings
- Bike Rack question.
- Random light stutters?
- SIR EG6 cluster question
- Bad Gasoline Question
- Rev Limiter Not Engaging
- headlight wire harness
- cooling fan issues on my 92 accord ex
- 8th gen poping noise?? Please help!
- 2014 Pilot Actuator and Wiper Problems
- axle boot
- diffuser/belly pan kits
- Will my headers fit the stock exhaust
- DSM Blue-top injectors in LS-Vtec CRX
- Big Boo-boo, help needed with ECU down.
