View Full Version : Tech / Misc
- just installed groundcontrols!
- What rpm does vtec engage in a 92 hatch SI?
- anybody ever have a leaky oil pan?
- pct vs p73 ecus
- Charcoal canister hookup...help.
- Difference between 1997 GSR harness vs 2001 ITR?
- Where is the oil pump?
- OBDIIB to OBDII wiring diagram for CIVIC
- can 89 si motor fit in a 93 civic h/b.........
- need quick compression calc.. (head millage)
- IAB wire on 99 GSR ECU?
- for those with knowledge
- eg to ef distributer wire conversion
- ECU and VAFC question?
- Help please, radiator prob.
- Distributor knowledge
- launching RPM with slicks !
- Newly installed coilovers
- Vtec not working!! Any ideas!!!
- help!!!!!!!!!
- is there a fuse to the fuel pump
- Opinions on lightened flywheel
- Skunk2 Exhaust??
- dent on crankshaft
- Impact gun too weak for my teg?????????
- CAMS
- compression ?...
- I need an answer about plug wires and applications
- Which camber correction bolts? PICS inside!!
- Tranny change
- What do these polyurethane products do...
- Code 9 HELP!
- Question B20 techs???
- ECU pinout question
- Will i need a motor mount kit?
- Liquid Gasket for Exhaust manifold?
- my swap, (progressive) (56k beware, tons of pics!!)
- Does this thing work?
- does this motor look ok to you guys?
- Does this look ok to you guys?!!
- Plug Gap fer B20\VTEC?
- Good Chicago Tuner
- dual valve springs...
- Fuel Injection/system cleaners
- Help a newbie out
- civic with GSR
- prelude brake booster
- Someone pls answer this
- Does it matter whether I use a JDM distrubutor or not?
- Any tips on a valve cover gasket change?
- problems of boring out b16?
- auto b16
- Piston rings blown?
- Is there a way to distinguish a Skunk 2 Ecu from the other ECUs? Is there a way to tell?
- Anyone have a H22/H23 flywheel in the Chicagoland area?
- removing vtec valve springs?
- Help! I tore a boot doin my clutch install
- how to DIY Oil Catch Can?
- spark plug gap?
- Brake Pad Question.... EG/DC
- Does the thread depth of a tire effect performance?
- My L/S VTEC dyno numbers at Import Builders
- factory sleeves?
- Fast and furious civics
- swappin....
- Skunk2 stage2 cams.
- Help with Y21 transmission
- car idles iracticaly, need help!
- which brake lines to adapt 1" master cyl to non abs eg civic??
- performance or looks
- tuning cam gears without dyno?
- skunk2 install on a gsr...?
- Equation for tire dimameter?
- Help me choose a clutch
- Hay, Help With timing belt
- Hesitation on '94 PRelude VTEC
- Rear O2 Simulator
- Putting first gen B16 back together, ran into a few problems
- (experienced mechanic only) cam timing?
- What plugs for 55 shot with zex?
- getting a car dyno'd in S. Cali
- Good engine dynamic/tech books??
- 1995 Integra GSR Problem
- Help Needed, 92 Hatch
- Quaife or OEM LSD
- Extrude honed intake, worth it?
- How do you...
- Brake Set Up
- I want a definate answer on the "limp mode" myth
- Anyone know the length of B17A1 rods?
- coil over installation
- Injector ?'s (long)
- Wastegate tips... What should I look for when buying a new wastegate for my
- d16a6/z6 CA smog emissions
- weird clutch probs...
- Clicking noise coming from under the car as I put it in neutral & brake. Anyone know what it is?
- What is Koyo's (Aluminum radiator) contact information/website.
- idle
- Throttle Body Question???!!! high idle
- Question that needs an answer!
- DIY camber bolts! Info on strength of bolts! Someone please translate!!
- O2 sensor question
- Kamikaze headers?
- B17A1 rods and pistons on a B16A1 crank?
- forged pistons + stock sleeves (h22a4)
- 94 Accord hesitation
- 89 tranny case vs 90 tranny case?
- Apex'i N1T silencer...
- I'm installing JDM Momo SRS steering wheel....how do I reset SRS light??
- mini me vtec wiring
- Got Idle Problems??? I don't :) :) THANKS "FIXHONDAS"
- d16 Zex Cam shaft with AEM adj cam gear?
- where to get a custom roll cage in So. Cal?
- VAFC installation question
- Does anyone have the Apexi n1 coilover instructions???
- weird noise after exhaust install
- Throttle Body
- what's the best ecu?
- How to disable EGR valve on OBD1 H22a?
- does 99-00 civic si have a crank fluxuation sensor???
- History of VTEC??
- D series clutch B series motor
- V-tec obd1 dist. b16 or b18
- HKS Sport D-1 cat back
- flywheel bolts
- How to get off...
- Tranny parts
- Gauge Cluster Questions
- Tranny issues
- firng order on ZC
- Simple Question????
- Heavy Knocking & Shaking
- do i have to re-time when i remove the distributor ?
- Centerline Wheels....
- Need help with putting on A/C belt
- Gears are Grinding!!
- How do you check the engine code on a obd2 gsr?
- No "caster" adjustment on the 6th gen. Civic?
- Anyone rebuild their own axle? Inboard joint Q
- best piston for higher compression
- best $1000
- ECU types & chiping ecu's.....
- ECU chip questions:
- GS-R or B16 oil pump, LS/Vtec
- Wiwood caliper upgrades...questions / discussion
- I/H/E question ?
- Please help me....
- My alignment reading! PIC! 3 washers??
- somewhat technical sleeve ?
- Questions about suspension
- B18C1 Skunk Manifold Question
- Horn relay WHERE is't in Civic 4D 92
- Who makes these LCAs ?
- putting ITR throttle body on Skunk2 manifold on a gsr
- - ITR manifold to gsr head questions -
- adjustable springs
- Quick ECU ??
- stock knock sensor and forged pistons...
- 1994 Accord 02 problems
- Read if you wanta become smart!
- miny me convertion
- What is the formula for compression ratios?
- Mini me help!
- I NEED A DISTRIBUTOR PICTURE!!! please read
- b20 help doing swap right now almost done
- cam for D16Z6 and D15B vtec
- Ordering parts... Need help!
- Quiet cat-back?
- Cam gear ....bolt torque
- quality on cam gears?
- ITR lower control arm to fit into an EG
- LS Vtec piston options
- JDM 4-1 Collector
- Question About Cams
- HELP CIL Code 10 and Code 14
- Headers exaust system
- Couple of quick question...please help
- sqeaky clutch pedal..
- Re: Honda/Acura Motor
- Torque increase
- what should my compression be???
- All b series starters the same?
- EGT guage on N/A, waste????
- what vtec oil pump will fit in an ls block
- H22A vs H22A4, can someone help??
- Some Tranny Questions
- Which ECU to chip??
- Type R mods
- skunk2 exaust vs apeix n1
- Hondata? Best system?
- B18A block and ITR clutch disc?
- getting my new b18b running
- Are my cams ok?
- VTEC killer cams with LS Head?
- close gear ratio
- how to tell if there is pistons?
- place for fixing SS header
- ITR ITB"S on a Ls head
- V-AFC are they good?
- serious problems with braking system
- newbi question
- Can I perform an LS tranny main bearing transplant to my GSR tranny?
- installing cam gears...?!!?
- Pin location of 02 Signal Wire for 01 integra?
- where to buy h22a short block?
- B16a1 part numbers
- where to get ls/vtec oil line kit?
- looking for the ultimate in weight savings?
- Passing Smog. need some input guys!
- Problems with Webcam H22A inner springs contacting valve stem seals
- Best Way to do a ls/vtec???
- stainless steel brake lines?
- 88-91 Civic/CRX Si cam on newer civic?
- headgasket?
- LS 5th gear in Civic tranny...what parts do I need?
- OEM Spoilers
- Are the Apexi World Sport Mufflers 50 state legal?
- wing... looks or does it help really
- resurfacing head and adjustable cam gears
- Exhaust puffs black
- Quick Compression Ratio Question
- Master Cylinder Braces
- increase ignition timing.
- Brake Rotor Question.
- Where can I go for info on an H22 motor
- Older throttlebody on a D16Y8
- someone please help wit wiring
- clutch switch quesiton
- JDM P-13 ECU programming?
- HELP! no spark no fuel.
- 96 civic prelude swap problems
- Bosch fuel pump specs
- what is wrong with my car
- Engine problem! Please help!
- Lightened flywheel
- problem with my IAV system
- obd 2 to obd1
- tunning afc without dyno??
- Tuning W/ Spec B's
- Car started ran for 15 seconds and then died.
- Minor Exhaust leak question
- Gas tank problem?
- Code 13 need sugestions
- can you remove a B-series engine without taking out the tranny?
- Problem with ride quality
- tokiko illuminas w/ gc's
- Spoon master cylinder stopper q's.
- tach is stuck
- Help Converting 9005 to Low Beam
- correct way to wire 500/1 JL amp to 2 12"JL W3s??
