View Full Version : Tech / Misc
- anaerobic sealant?.....d16y8 rocker arm assembly
- my prelude and suspension?
- y8 manifold with y7 rail, injectors????yes/no?
- Toda Head Gasket - How Many Times can It Be Reused?
- Normal Driving: Gas cuts, on and off??
- Need help with PR4 ECU, Auto -> Manual
- Reading the complicated OHM meter
- How to tell differences between fuel pumps??
- does anybody know....
- how do i replace obd0 b16 distributor bearing?
- Fuel Injectors Code 16....Help!!
- Any parts out for the TSX?
- will 92 95 civic clutch master cyl fit onto 94+ gsr?
- Any clue how the intake cam could jump timing by 45 degrees while trying to hook up MSD
- Which suspension?
- HOW DO I!?
- HELP.. ... . . what hose to use?
- Castrol Syntec
- hondata 2 step with cable tranny
- Wideband Sensor Question
- Synchro's - compatible?
- Question about TB
- WTB: NEED A B16A2 Complete motor soon!
- Any way to get VTEC louder in D16Y8 like a B16?
- Can B16A2 Head be used on a D16Y8 motor?
- NO VTEC?!!!
- What kind of Hi-flow cat?!?! Exhaust Guru needed.
- Anyone know where the "ICU" is and if its replacable?
- who makes the oil sandwich adapter with built in thermostat?
- What is the ELD?
- Methods/Suggestiongs for creating/modifying ROM maps (a la ghettodyne)
- Need some help with my RPM 68MM TB (done search)
- would it fit???
- bogging problem
- typeR cat fit 99 civic si?
- Tokico springs
- What sensors are missing from jdm engines?
- light STEEL flywheel?
- clutch question - ZC motor w/ crx Si tranny What clutch?
- front swaybar fitment question?
- Backfire when switching gears!
- lug patterns
- New clutch installed got questions...
- Why do my Spark plug wires look like this?
- Is this a B16 or B18?
- Help. I dont understand.
- Is sgt on vacation or something?
- 3" exhaust for all motor?
- Electrical Problem!! Need someone who knows there electrical ish!!
- Bent valves...
- BAR STICKER will pass JDM motors??
- anyone ever made thier own RPM activated switch
- I NEED D16Y8 ASAP CLOSET BY OHIO AREA PLEASE HELP!
- which of these 2 engines
- motor swap.
- prelude sh intermediate shaft
- vtec pin on the head
- Need help right this second...
- Higher duration and higher lift with nitrous?
- Differentiate between B18CR and B18C
- maybe clutch problems
- crank fluctuation sensor bypass
- High CR Piston VS Octane
- VAFC w/ nitrous?
- disconnecting battery/unplugging ECU......
- gsr,si ls, shift linkage
- H&R vs. Tokico
- Got code 41, O2 Sensor Heater, how can i correct
- Pics of my engine work (check them out)
- any guesses?
- My Car is Backfiring. FI Guru's please help me
- any difference between auto or manual
- anybody own or heard of McCulloch HID kits???
- wheel bearings??? jdm itr 5 lug
- Anyone got TEIN type Basic suspension on their car, ??
- 99SI with JDm swap...lotsa problems
- opinions on engine rebuild kit
- Tranny Rebuild question: should I be able to turn the input shaft in neutral?
- Acura RSX BUILD
- someone please help me understand honing and what this paragraph means!
- which headstuds to use on mini-me (y7.block z6.head)
- Which Map Sensors can i use?
- My damn car finally runs!!! It was a portflow head problem:(
- Compression test problems!
- When to change your timing belt .
- 91 accord engine/electrical problem?
- "Universal" Camber Plates?
- d series valvesprings...
- Will the JDM 4.7 Final drive work with a stock 99-00 si diff?
- piston to valve clearnce?
- Questions about Swapping motor please help blew mine last night!
- climate control not working..need hellp!!!!
- engines
- A Few guestions from a N00b
- Need Help ASAP !!!!!
- 91 si conversion dx cuts out at 3000!!!! help
- what would happen if you shaved 0.056" off the deck of an H23 :P
- What is a head gaskets Job?
- booster questions
- Ignition timing and temp.
- any DSM guys here... help with my beater
- DISTRIBUTOR
- GSR block with B16a head?
- fuel maps for a h23?
- Hasport Mounts
- recommended lowering springs?
- Air filter?
- overheating honda
- Bad alternator or battery?
- question on itr swap in gsr
- Help with this pls
- AEM V2 intake on a jackson racing supercharger?? possible?!?
- Distributor Troubleshooting (not sparking)
- Extending your o2 sensor wires=check engine light?
- car on lift built engine, starting and idling problems please help(kinda of long)
- Code 23 on LSVTEC?
- Rice a roni, pretty funny, take a look.
- help... puttin on rotor/hub onto wheel bearing
- my alternator/charging system problems
- highest whp n/a engine ?
- fuel pressure supposed to drop to 0 immediately when you turn off your car?
- Wheres the cheapest lace in Daygo to get Catalytic Converter done??
- B18B1 Long Block....Timing Belt Broke....Help
- got spark but no fuel?
- lame question, unplugging a p28
- Spark and Fuel but no start...??
- Engine Build Constructive Critisism
- has anyone tried to make a digital tach or speedo for a honda?
- can u fix a crack in the block...HELP
- first time gapping rings, need some help from the pros!!!
- Defective Dizzy, Will it throw off timing?
- GSR or LS tranny (GSR owners pay attention)
- Car acting up..need help asap
- ignition coil help... I did everything right. Why won't it work? PLEASEPLEASEPLEASE
- b16A engine swap in 93 Cx
- vtec seems like rev limit
- What needs done on a D16Y8 swap to a B18C1 swap?
- Blew my D16Y8 today! Need help.
- Tips, or reference to Engine assembly?
- Eliminating knock sensor...grounding isnt working.
- Honda Tech School
- will i need to bore out my engine?
- Thinking about getting Hondata s200
- Need some help/advice removing LCA bolt
- Question regarding axles and shift linkage interchangeablity
- OMG my exahust is too big (Getting ES Oval) which one ??
- Spoon B16B stroker kit into a B16A?
- DIY spring compressor
- Installing obd1 prelude injectors in obd0 pr3 b16????'s
- Help!! Z6 mini-me swap idles at 3500 RPM.
- code 6 help
- my brake question
- Best suspension for 92-95 civic coupe
- D16Z6 Distributor on B16A1
- EVAP question Use one or don't (JDM)!! Tell me what you did.
- type r into eg quick question
- Accord H2U5-5017423 5sp Tranny in 5th gen Prelude?
- Warm weather headlights?
- I need Injector Clips for my 99 civic Si for 450 DSM Injectors
- pistons in ls/vtec
- Engine trouble
- quick look what is an ecu
- 96-98 Wire Harness
- Shaving pistons
- throwing a code 16 fuel injection
- cel after driving
- Best Plug Wire Combo on All Motor????
- Hf distributer to B16a distributer conversion
- mainshaft bearing or input shaft bearing?
- car idles very low and dies sometimes with headlights on?
- limp mode / 2500 rev-limit after skunk2 intake manifold install
- clutch pedal stays on ground
- code 7,9,16 please help
- car just shuts off..why
- jdm b16 in a LS ?
- HELP!! I heve the infomous loopy/high idle in my obd1 B18c!!
- new prelude and suspension
- why am i burning so much oil
- Extrude Porting....
- Where to get a set of Venom injectors flow tested?
- Bogging at low rpm of the line
- Bad Tranny Noise.......
- dizzy question. thanx for lookin ahead of time
- Recomended engine oil for 10,000rpm
- how manny OHMS for TDC sensor?
- Integra gauge cluster odometer
- need help with suspension techniques sway bars
- Where to get Valve grind gasket set and valves
- Partial Fuel?
- Welded diff in RWD application?
- building my own catback ...any opinions?
- Need Help throwing a 16 code
- 1993 H22 Accord question
- All HID Owners, Sign HID Petition!
- Took out back seat to install kill switch, now it won't go back in right
- anyone ever purchase used tires from a used tire store?
- Another idle problem question. Please read....
- 7th Gen Swap??
- best d series to turbo in an ef?
- spark plugs
- Bad gas??
- action clutches?
- 97 JDM ITR ECU questions????
- OOOOPS! help! is this bad?
- More Cooling Troubles....PLEASE HELP
- car noobie help
- Fuel Tank Pressure Sensor low input?
- Assembling my 2.0l b18c5 12:8:1 compression with 50 shot nitrious.
- knocking sound in reverse
- fuel regulator fitment question...
- Civic Coupe - Coilover upgrade
- Suspension 95 / 96 civic front shocks ???
- ls vtec ?
- Help! Code 10?? Can't fix.
- Keep blowing the ECU fuse....
- leaving car in garage for school year... disconnect battry?
- Need some of these words/parts definitions
- Fake cat- would fool just about anyone, no performance loss
- OBDII-->OBDI idle question
- GSR Idle sound.. dosnt sound good!
- How do I Connect a Toggle Switch To The Clutch Switch For the HONDATA?
- Does a Gsr header fits a Rs motor ?
- Welding an o2 bung on downpipe...
- codes 12 and 21
- Whats P30?
- 2001 Integra Type-R engine Mounts for 92-95 civic with b20
- bad short... turbo d16z zdyne 89 si...
- Using a cable tranny on a hydro car?
- Which exhaust cut out is better.
- Intake or Exhaust cam
- camber question
- no spark
- Can't figure out my smoke problem
- CEL Code 91 Issues...
- Final Gear Ratio
- State Ref?
- Did a 5spd swap, bled clutch, now clutch seems to not disengage.
- aem ems
- hey how much would this cost?
- D series head codes
- Are the MAP sensors the same?
- ls retainers same as b16/gsr retainers????????
- What's the difference between h22 auto blocks and h22 manual blocks?
- B16 Blues
- razy wierd o2 sensor? 3 wire?
- main bearing clearences at service limit.......
- ls motor into a crx
- who sells OBD2 to OBD1 injector clips?
- Where to buy: Bosch LSU
- O ring gasket in thermostat housing
