View Full Version : Tech / Misc
- Need DIY Link, Help please
- which o2 to get?
- Rebuilding an Egine!
- Will a D16Y8 vtec head fit on my 00 lx civic? 1.6 non-vtec
- exhaust question.... i need to be kill the sound
- Now i thought i had crazy ideas LOOK
- smog and cel question
- pieceing together a turbo kit?
- pieceing together a turbo hit?
- Do Hondas enter into "SAFE MODE"?
- What year axels do I use?
- shops in socal
- How to make my angel eyes BRIGHT?
- ABS Code help
- what causes this?
- tranny noise problem, please help troubleshoot!
- turbo????
- exhaust paint!
- Piston to valve clearance. Need your help guys!!!!!!
- 5spd swap work up. HELP
- new car need ideas
- Vafc question......
- CROWER ROD BEARING SIZES
- Early Shifting!
- JAPANESE INTEGRA SI '94 SPEEDOMETER / WIRING PROBLEMS!
- help me with swappping engine(h22)
- checking codes on a obd1 motor and harness with obd0 car?
- vafc version #2 question -->
- help on springs.
- female spade connector
- ITR Tranny.."Dual Synchro's"..??? Need help ASAP
- Need Help on VAFC Tunning
- Catalytic Converter temporary swap
- d16z6 swap in 88 dx hatchback
- will this cause a problem on my tranny?
- Will milling the head change the cam timing? (retard)
- Tuning N20
- cold start bouncing idle???
- baffled valve cover??? necessary???
- bad..ECU ??
- any difference between the itr (stock) oil pan and any other teg oil pan? besides it saying p72?
- Brake calipers similar?
- Bad Sputtering, Frustration!!!!!!!!!! Im going to drive my car off a cliff!
- s-afc help please...
- b16 differential ?
- Help! Can't figure out what's wrong with my car....
- DIY motor mounts
- 93 Civic Coupe bushings and shocks
- hondata??? i had boost but now i dont need help + no vtec
- Need knowledge about suspension
- Quality of JG VTEC Valvetrain?
- How do you hook up a coolant temp gauge??? need help
- DIY How to: Take off transmission and Inspect Input Shaft Bearing
- which prelude injector for 95 gsr ( already searched)?
- Electrical experts please help!!!
- Identifying b16b cams
- Paxton Fuel Pump Leaking?
- over heating problem....
- Interior wiring woes??? help
- setting timing without belt cover
- What if I continue to drive my car with "low oil pressure"?
- valve cover gasget honda part number help!
- Torque loss in knife-edging?
- which wire is knock sensor wire on safc II?
- A/F Gauge
- Part number for Greddy AF O2?
- Just installed jimfab motor mounts
- Clicking sound
- exhaust problem or what..?
- h23 crank w/h22 rod
- Replacing Crossmember
- Toda B = less power ?
- Do all B-series use the same oil filter?
- t-belt frustration...yes i searched
- Piston Rings or Valve Seals
- testing water pump??
- Help troubleshoot noise for me !
- anyone run a turbo with a milled head?
- NEED HELP....wiring harness
- how much stock injectors worth?
- Coolant Flow To IAC and TB (FITV) Purpose. (Intake Manifold Gasket Phenolic Hondata OutlawEngineerin
- Rebuilding Stock Brake Calipers
- Weight of transmissions
- need help with o2 sensor
- VAFC II install into IVTEC - Write Up
- bolt patterns
- What Engine Is This???
- tranny part pic request
- PR3 mugen program problems?
- Whats the difference....?
- Eagle Rods...
- SOHC Fuel Pump VS. DOHC Fuel Pump
- how much oil does a b16a need?
- also need dc/md/va machine shop...for H22a4 buttom end rebuild
- EF Suspension On My EG?
- Wierd Alignment Issue - Left Toe Will Not Stay in Spec - PLEASE Help.
- Hondabond on oil pan gasket?
- Engine shop in VA/MD/DC?
- Anyone in FL Area want to do Valve Adjustment?
- Plugs look lean but fuel pressure is at 45psi
- How to install Autometer gauge - voltage meter?
- tranny noise
- Crower 403 cams or JG 301 cams B18b1 LS
- Possible alternator probelm? Need Help!!!!
- blitz sbc-ID & powerID
- What could i do to fix the tranny grinds without getting a new one?
- If a motor falls to the ground while on the car will it hurt the tranny or linkage?
- Car wont start! ECU fuse keeps blowing up
- Possibly hydrolock the motor???!!!
- Popping and Stuttering in boost, need opinions
- Oil pump gear a weak link on H22A and UR crank pulley?
- What do you guys think about this header?
- MSD Digital SCI+ Ignition Problem
- Can you switch 02 sensors?
- how much do shift linkage cost
- What size socket?
- I put my life in the hands of the Honda-Tech A/C gods...HELP!!!!!
- Cant find the IAT?
- hesatation
- S-AFC help.......
- anyone know anything about towbars????
- What is the max amount of variance in compression between cylinders?
- does valve adjustment alter a/f ratio?
- Balancer-shaft blockoffs
- Vouch for EXEDY clutches?
- funny mid engine rattle after forged internals where put in
- 88 dx... spark but no fuel??s
- Will a b-pipe from an EK Coupe fit an EK Hatch?
- Need answer quick pleez help
- My oil change experiences!
- odd headstud torque dilemma //knowledge is needed
- CD player from a 96 integra fit a 1993 dx civic?
- B16A2 clutch in a B18C??
- clutch problem
- Running lean...HELP!
- just got back wire harness from place racing
- over heating problem....HELP
- A/C problems! Help...
- Fly Wheel and Pulleys HELP!
- need help from the suspension gods
- iacv ( what color wires)
- Got my alignment done, now car wanders (suspension gurus - help!)
- OBD0 CRX si ignition issues
- has anybody have skunk stage 2 cams and done a compression check?
- Please help with HG issues.... Burning coolant like crazy after install... (long)
- suspension problem
- Soon as my clutch started slipping shifting became bad?
- OEM Cluster & instruments lighting dimming ?
- Pictures of my new engine being assembled.
- b20 vtec timong belt and tensioner
- Premature fuel pump failure what causes it?
- Cooling issues
- Air Compressor
- temperature sending unit?
- Compression Check= low compression?
- Clear VAFC settings???
- Cheap Horsepower
- Transmission Grinding
- 59300 cam in y8 head-simple cam timing question that i can't figure out...
- ***Seem to be having problems with the Alternator or battery Need help!**
- jdm headers 4 into 1
- Shock question
- 97 type r coolant line diagrams please help
- SRR Final Drive D series 4.7 or 4.9???
- oil catch can setup for Ls/Vtec
- Identifying cams
- Looking for someone to do my harness !!!!
- Headlight plug melting! Anyone else had this happen?
- Clutch doesn't disengage
- 9,000 RPM =I
- Replacing a bent valve
- no compression..car bogs below 2k
- B16 tranny in integra ??
- woo woo, compression test turned out good!
- HELP! Broke vacuum tank on cruise control unit, WTF is that for anyway
- Oil Pressure Light
- swap = no start
- tranny final drive
- Blockguard bent my cylinder wall (heeelp)
- j's racing pillar bar won't fit!!!~
- integra gsr camber kits?
- pressure loss in clutch system
- Anyway to order the brass synchro only?
- where to run nitrous fuel line
- T/O Bearing Question
- HELP Will a jdm gsr motor...
- s-afc compatability
- D16y7 IACV question?
- Tech Edge Ver. 2.0
- HELP!!! car wont start after camshaft instalation
- cams are scratched up... help!
- crx hf to b16a1 vacuume problems?? please help
- Piston Ring Gap
- Greddy Turbo Kit on a 99-00 Honda Civic Si
- Size in MM of bolts on H22a1 CRANK PULLEY (may be same as other Hondas?)
- h22 vtec problem
- msd modified cap d16z6
- consuming oil bigtime on a rebuilt b16a2
- What to ask when tuning?
- Help me decide on a Welder...
- Differences in ctr, skunk2, and crower cams ?
- What to Use HondaBond On?
- If i was aloud to post in the "General Discussion and Debate" i would
- TPS Problem: Inverted Voltage
- WHERE TO FILL TRANNY FLUID
- Need help....!!!!!
- Running Nitrous please help!
- Injector Duty Cycle
- toda cams on a d16z6?
- Alignment ??
- Knock Sensor acting fool after Zex install!
- tranny problems (long)
- DOHC valve adjustment ???'s
- B16 throwing code
- Power Steering Fluid!?
- quick valve adjustment question
- grinding 3rd gear!! what to do to fix??
- B16 with lots of BLOWBy= bad valve seals?
- jdm engine legit in S.Cali
- How to safly remove my DYNA MAT ????
- Some serious help need from the motor/ecu experts
- keep blowing fuses, what's the problem!?!
- need help how to change headgasket on b18
- Price Difference in Camber Kits
- H22 : engine noise during starting/shutdown...?
- B16 LSD Install
- Speedo Cable Not Going In
- which motor oil to go with rebuild zc
- KYB AGX shock fitment
- signs of bad head gasket???
- Looking for good lug locks to buy, any suggestions
- Underdrive Pulleys?
- wtf: how do i....
- AC removal
- clutch problem
- idle surging!???
- Cable Transmission Difference
- Corner Valve Cover Bolt Broke off
- Hoist points for pulling a B16a out of a CRX
- changing cam seals, help me out
- Fuse keeps blowing
- WHat is a safe rev range on my setup
- Door Locking issue after replacing the "main" problem
- jdm vacume line help please
- does sci w/ out rev limiter disable your factory need to know fast
- piston rings (help please)
- Is it safe to run all greens on Crower rods?
- Using quick fasteners to attatch bumpers?
- Having trouble starting my car...
- which type of oil to use?
