View Full Version : Tech / Misc
- TDC Sensor No Signal
- What happens to your odometer when you swap in a different guage cluster???
- small crack on sidewall okay?
- * How to clean carbon build up in the combustion chambers?? *
- Help Me Please! Header Stud stripped. Now what?
- Did OHM meter test on my ignition coil - replace coil???
- Just bigger injectors a performance mod?
- Problem on 92 Si - Metallic grinding/scraping noise, rear brakes.
- Is it safe to put a Mugan ECU chip upgrade into a stock D16z6 motor
- help with msd digital 6 plus install
- Less turbo lag on high compression?
- Blowing ECU fuse constantly
- Uberdata map's
- ive got a full cell. the engine is a obd1 b16 in a 88 hf. i don't really know where to start looking
- 6000rpm bog....help!
- pressure plate problem
- How good is this muffler?
- Full Titanium exhaust Vs. Full Stainless Steel exhaust
- where do you recommend buying a new car battery?
- Just got 05 Honda accord coupe 4cyl
- 05 Accord coupe 4 cyl
- are these b16 cams or itr?
- P13-P72-blahblah, someone explain this to me
- causes of lower fuel cut / rev limiter?
- Warped head+milling+vitara pistons=?
- Spoon stroker kit
- stiff auto shifter
- Coolant Temperature Sensors - 91LS and 95LS - Do they operate the same??
- 2001 civic dx?
- Buying Prelude off Ebay
- need suggestions
- obd1 ecu p61 vs p28
- Intake air tempature (IAT) sensor circuit high voltage, and TPS circuit low input, need help
- Profab Intake gasket
- bogart back spaceing?
- HELP ME identify this Aftermarket H22A cam PLEASE
- Fastbrakes Wilwood Brakes
- power limit of b16a tranny
- B series Transmission Syncronizers
- LOW IDLE AFTER CAR WARMS UP
- confused about which parts to buy for
- idle
- low voltage to o2 sensor=bad sensor?
- Install rod bolt with engine in car?????
- i need OMNI pOwER adviCE!
- h22a in 92 accord PRBLEMS
- CTR pistons on B16A Rods - those NOVA who've done it please look!
- would a bad cap and rotor make my car misfire?
- vafc2 is "semi-frozen/stuck"
- tranny side motor mount b series in a 99 ex
- Speedo Fuse keeps blowing
- Crank Sensor
- who has sucessfully done a DX to SI wire harness conversion???
- Propane powered Honda?
- Spoon Flywheel Resurfacing...
- Air / Fuel controllers and OBD-II
- tailights problem
- ITR pistons w/ GSR rods?
- HELP ON B20
- I need engine!!!
- What Fuel Rail and FPR on a JG Edelbrock Intake Manifold?
- Have a prelude but really need some tech advice w/ pathfinder
- H22 Idle Surge
- Hubcentric rings with Rota GT3's???
- Code 4 - Crank Angle HELP!!
- apexi ws coilovers?
- 6 puck and aluminum flywheel question
- injector wiring issues....electricians help please!!!
- Blueprint/balancing??
- proper oil weight for new berings
- Just making sure. How do I use a compression tester?
- Automatic tranny slipping in 94 Integra LS ???
- DSM LSD: stupid question, but can't pass up the offer...
- Are stock Koni Yellows shorter than stock struts for an EF Hatchback?
- F22B DOHC Vtec??????????????????
- whats wrong with my ls vtec?
- D16y6 swap PLZ HELP
- What are Brembo "fixing screws"
- THE MOST ANNOYING SOUND EVER
- What rods can i use
- question about valve adjustment
- car has no ba...pull
- What are the SW288 made out of
- b16 swap header?
- AN-R Headers????????
- Oil Pump ?'s
- BUILT GSR turbo
- OBD1 GSR Turbo Hatch - VTM Signal for VAFC Installtion
- SMOG help
- HELP: IDENTIFYING PISTON (NO PART#)
- crx project back under way need advice
- b16a build up questions
- Koni Adjustable coilovers.......Pros and Cons?
- TDC code? and dumb timing question
- Valve spring seat shims....
- A question for the moderators.....
- Why isn't the K-Pro compatible with the K24A2?
- Help! ECU Problem
- Header glowing, car dying?
- which M.C. should I get to increase braking ability?
- Shakey Idle PLEASE HELP
- PA sensor code 13
- B16 vs GSR cylinder head: torque specs?
- Rod knock or lma's?
- Reversing the polarity on a battery
- over heating problem with motor
- Helms has no answers for this ??
- i had a bad engine experience
- Recommendations to any Suspension / alignment shop NJ/NYC/CT !?
- Greddy E-manage Problems
- OBD-2 JDM GSR Motor Question
- B18B2 questions
- VAFC Question
- Weak/no spark???
- rebuilding a D16Z6
- 2gen integ turns over but will not start.
- nedd help with ngk plug wires
- What wire is this? Please help..
- APEXI V-AFC TUNING HELP......!!!!!!
- str throttle body
- tranny gear ratio
- stock shocks w/ H&R springs
- Air Suspension ???
- Dumb Question on Transmission Fluid
- throwing code 10, help!
- Header an exhaust system install what do i need?
- Occupant Position Detection System
- Anyone have the measurements from a 2.5" donut gasket??
- Need help ASAP!!!
- gsr block w/b16 head?
- Fuel Pressure Regulator Drilling help.
- Autometer oil psi guage questions.
- O2 sensor problems, code 41, help..
- Is it bad to use tapered (aftermarket) lug nuts with Honda steelies?
- D16y5, D16y8?
- EG...cluster lights and license plate lights don't work
- Replacing VC gasket??
- '96-00 Civic Rear Lower Control arms - Replacing - recommendations/Advice?
- I need help with Torque spec's
- can h22a in a civic or integra pass state ref with BAR?
- only a valve cover ground?
- JE Piston help
- Cusco Sway bar Help
- throttle body question..
- car wont start until its cooled down alittle. ignitor problem?
- need help tuning the greddy profec b2... anyone have one or know how to work with it?
- Need a good shop in Orange County to install a wheel stud - Any suggestions?
- Internals For DOHC ZC Engine.
- Mandrel VS Crush Bent Exhaust (3" Turbo Nitrous Ef)
- Acceleration stuttering Please Help
- Rigid 3Pt. Fr. Tower Struct Installed. A little rough tho..
- srr rear toe kit install question "washer"
- Ground Wire Kit...Does it really add power?
- shreaded timing belt
- under the valvecover.
- ITR Oil pump on B16A... which belt cover to use?
- New Tranny swap from CVT
- using a 4.2cfm compressor, with a 5.4cfm gun
- 12.5 Cr ,Fuily Built lsvtec
- How do these alignment settings look?
- head help cant idle no codes!!!
- HELP ME ASAP BUDDIES CAR WONT START
- sparkracing.com
- b16 swap problem...
- vafc vtec crossover
- Do All Honda's Use the Same Clutch Alignment Tool?
- does any one a wiring diagram for wiring up a odb2 alternator to a obd1 harness
- rear caliper piston fell out.
- flywheel resurface.. spec is .065" recess how do i measure this?
- ebay H brace bar
- cable to hydrolic in a DA
- will 97 integra pass. axle fit 00 si
- b16a2 head cam journal damage? anyone know how bad this is...
- New sway/tie bar combo, another alignment??
- OBDII TB on OBD I GSR?
- Where's the best place for cipping ECU's?
- Bore diameter conversion table
- how to figure out where a vacuum leak is?
- Need quick help about Sard thermostat
- uberdata, tps configuring?
- gs-r ej1...werd my homies?
- what size it the jdm ITR non-srs steering wheel
- how hot does a downpipe get for heat wrap
- why can't you jsut put a filter on teh throttle bosy and run off of the throttle body?
- anyone have problems with Skunk2 IM on GSR?
- Tachometer Wirings Diagrams
- * * *My How to: HOW TO RESET YOUR CLUSTER MILEAGE* * *
- dowl pins need help
- Oil on top of plugs in new motor
- im trying to put a momo stearing wheel on
- TPS adjustment .45 -.50 idle ???
- S2000 parts interchangeability?
- anyone with a JDM B16 - help, look
- JDM ITR 5 lug info?
- Greddy multi switing module wiring
- D-series PPLZ - need help
- Need help, car is stuggling
- Hooking up the Vtec to 2nd Gen. Integra
- Is LS Crank Pulley same as GSR Crank Pulley?
- Power delivery questions. Experiance needed.
- HELP..........H22 accord issue: strange check engine light and start problem
- Mustang injectors into a B series fuel rail
- B-Series Axle Interchangability Question...
- Strange noise while driving.
- wierd noise in my crv what is it?
- Cooling Fan Issue
- VAFC Sensor Setting
- Timing Values
- safc and btm
- Comptech sway bar squeak noise information
- Bose Suspension
- H22 in an 02ACC
- Question about sleeves? swapping between blocks
- HELP!!!!-Why is the sound still breaking up in 4th gear in VTEC??-HELP!!!
- Quick Dizzy question.
- Spoon Sports tie bar???????
- Bore Spacing?
- After installing obd-1 GSR cluster, Gas Gauge doesn't work-- help.
- Quick question on springs install on ek hatch... help!!
- Exhaust compatability question *searched*
- Brake Prop Valve Part
- where to buy coolant hose with built in water temp bung ???
- cam gear adjustment with skunk2 stage 1 cams???
- Swapped out obd-1 injectors for obd-2, car idles differently
- Eibach Goldlines on an EK... camber problems?
- wierdest SRS light ever
- Towing A RWD Auto
- Hesitation/Bogging/Stumbling w/ B18C1 in CRX
- Anyone heard of RXP The Emission Reducers ?
- IACV, IAT, idle problems, MAP experts! - need help
- need a block !!!
- Distributor fin
- steering wheel Civic/Teg
- engine and tranny swap
- Where is the AC thermo Switch?
- found gas in my oil, i wanna check my injectors and Ignition system...how?
- How to charge AC (SEARCHED) NEED HELP ASAP! Picture of gauge inlcluded
- tuner shops near nashville
- Cat converter???
- rex: have a question
- B series rocker ratio
- Problems with Speedometer after New Tranny Install.............
- Help Identify cams please!!!
- Buddy Club Spec III Camshafts specifications?
- Erradic idle with new ECU?
- B18C5 crank versus B18C1 crank
- wtf is wrong wit my stupid pos IDLE!
- need p28 ecu pinouts baddly...........
- rust in the cylinder walls..
